Author Topic: CollectionEditor's Add/Remove buttons disabled with IList implementation  (Read 3999 times)
Chumplybum
hi all, i've been struggling with this for a few hours now and just can't get it to work... i'm trying to add and remove items in a custom collection using the collectioneditor via a property grid.
i originally started out by inheriting from Generic.List(of ....) which worked, but as i want the collection to inherit from a another class i needed to implement the IList(of ....) and came up with the following:
'code start
Imports System.Drawing.Design
Imports System.Windows.Forms.Design
Public Class Person
    Private m_FirstName As String
    Public Property FirstName() As String
        Get
            Return Me.m_FirstName
        End Get
        Set(ByVal value As String)
            Me.m_FirstName = value
        End Set
    End Property
    Private m_LastName As String
    Public Property LastName() As String
        Get
            Return Me.m_LastName
        End Get
            Me.m_LastName = value
        End Set
    End Property
    Public ReadOnly Property FullName() As String
        Get
            Return Me.FirstName & " " & Me.LastName
        End Get
    End Property
End Class
Public Class PersonCollection
    'Inherits Generic.List(Of Person)
    Implements IList(Of Person)
    Protected innerList As List(Of Person) = New List(Of Person)
    Public Sub Add(ByVal item As Person) Implements System.Collections.Generic.ICollection(Of Person).Add
        CType(innerList, ICollection(Of Person)).Add(item)
    End Sub
    Public Sub Clear() Implements System.Collections.Generic.ICollection(Of Person).Clear
        CType(innerList, ICollection(Of Person)).Clear()
    End Sub
    Public Function Contains(ByVal item As Person) As Boolean Implements System.Collections.Generic.ICollection(Of Person).Contains
        Return CType(innerList, ICollection(Of Person)).Contains(item)
    End Function
    Public Sub CopyTo(ByVal array() As Person, ByVal arrayIndex As Integer) Implements System.Collections.Generic.ICollection(Of Person).CopyTo
        CType(innerList, ICollection(Of Person)).CopyTo(array, arrayIndex)
    End Sub
    Public ReadOnly Property Count() As Integer Implements System.Collections.Generic.ICollection(Of Person).Count
        Get
            Return CType(innerList, ICollection(Of Person)).Count
        End Get
    End Property
    Public ReadOnly Property IsReadOnly() As Boolean Implements System.Collections.Generic.ICollection(Of Person).IsReadOnly
        Get
            Return CType(innerList, ICollection(Of Person)).IsReadOnly
        End Get
    End Property
    Public Function Remove(ByVal item As Person) As Boolean Implements System.Collections.Generic.ICollection(Of Person).Remove
        Return CType(innerList, ICollection(Of Person)).Remove(item)
    End Function
    Public Function GetEnumerator() As System.Collections.Generic.IEnumerator(Of Person) Implements System.Collections.Generic.IEnumerable(Of Person).GetEnumerator
        Return CType(innerList, IEnumerable(Of Person)).GetEnumerator()
    End Function
    Public Function IndexOf(ByVal item As Person) As Integer Implements System.Collections.Generic.IList(Of Person).IndexOf
        Return CType(innerList, IList(Of Person)).IndexOf(item)
    End Function
    Public Sub Insert(ByVal index As Integer, ByVal item As Person) Implements System.Collections.Generic.IList(Of Person).Insert
        CType(innerList, IList(Of Person)).Insert(index, item)
    End Sub
    Default Public Property Item(ByVal index As Integer) As Person Implements System.Collections.Generic.IList(Of Person).Item
        Get
            Return CType(innerList, IList(Of Person)).Item(index)
        End Get
        Set(ByVal value As Person)
            CType(innerList, IList(Of Person)).Item(index) = value
        End Set
    End Property
    Public Sub RemoveAt(ByVal index As Integer) Implements System.Collections.Generic.IList(Of Person).RemoveAt
        CType(innerList, IList(Of Person)).RemoveAt(index)
    End Sub
    Public Function GetEnumerator1() As System.Collections.IEnumerator Implements System.Collections.IEnumerable.GetEnumerator
        Return CType(innerList, IEnumerable).GetEnumerator()
    End Function
    Public Sub AddRange(ByVal items As Person())
        For Each tmpItem As Person In items
            Me.Add(tmpItem)
        Next
    End Sub
End Class
Public Class Office
    Private m_People As PersonCollection
    <System.ComponentModel.Editor(GetType(System.ComponentModel.Design.CollectionEditor), GetType(UITypeEditor))> _
    Public Property People() As PersonCollection
        Get
            If Me.m_People Is Nothing Then
                Me.m_People = New PersonCollection
            End If
            Return Me.m_People
        End Get
        Set(ByVal value As PersonCollection)
            Me.m_People = value
        End Set
    End Property
End Class
'code end
after adding this class to a property grid and clicking on the (...) button to edit the collection, the collection editor pops up but the add / remove buttons are disabled. I've read on the codeproject website that there are 3 items that a collection must have in order for them to be persisted by the collection editor, namely implement IList, item property and an add / addrange sub... which i've done (i think)
can anyone shed some light on this, any help would be great
Cheers
[EDIT: code indented]
« Last Edit: February 25, 2008, 01:14:19 AM by Chumplybum »
Re: CollectionEditor's Add/Remove buttons disabled with IList implementation
« Reply #1 on: February 25, 2008, 12:13:26 AM »
A gentle suggestion to use an editor that supports proper indentation and post same, formally commenting code where applicable (i.e // comment). As is that is hard code to look at despite being relatively brief. In my opinion.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #2 on: February 25, 2008, 12:39:54 AM »
Maybe using the code tags would make this easier to read.
Nathan Taylor
« Reply #3 on: February 25, 2008, 01:23:23 AM »
or given it is VB 'comment
