Author Topic: acedTrans to .NET  (Read 11150 times)
gile
  • Marseille, France
Re: acedTrans to .NET
« Reply #15 on: January 26, 2019, 03:35:17 PM »
This topic is quite old, but here's my new attempt for a Trans method working as the LISP one (it accepts either integer, ObjectId or Vector3d as argument).
The extension method uses some C# 7 functional programming features (local function and pattern matching).
Code - C#: [Select]
  1.     static class Extension
  2.     {
  3.         [DllImport("accore.dll", CallingConvention = CallingConvention.Cdecl, EntryPoint = "acedTrans")]
  4.         static extern int acedTrans(double[] point, IntPtr fromRb, IntPtr toRb, int disp, double[] result);
  5.
  6.         public static Point3d Trans(this Point3d source, object from, object to, bool disp = false)
  7.         {
  8.             ResultBuffer toResBuf(object obj)
  9.             {
  10.                 switch (obj)
  11.                 {
  12.                     case int i:
  13.                         return new ResultBuffer(new TypedValue(5003, i));
  14.                     case ObjectId id:
  15.                         return new ResultBuffer(new TypedValue(5006, id));
  16.                     case Vector3d v:
  17.                         return new ResultBuffer(new TypedValue(5009, new Point3d(v.X, v.Y, v.Z)));
  18.                     default:
  19.                         throw new Autodesk.AutoCAD.Runtime.Exception(ErrorStatus.InvalidInput);
  20.                 }
  21.             }
  22.             double[] result = new double[3];
  23.             int status = acedTrans(source.ToArray(), toResBuf(from).UnmanagedObject, toResBuf(to).UnmanagedObject, disp ? 1 : 0, result);
  24.             if (status == 5100)
  25.                 return new Point3d(result);
  26.             else
  27.                 throw new Autodesk.AutoCAD.Runtime.Exception(ErrorStatus.InvalidInput);
  28.         }
  29.     }
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #16 on: January 26, 2019, 04:03:54 PM »
Nice update Gilles.
Called Kerry in my other life
I live at UTC + 13.00
