Murph
Finally! I got the result I was looking for
The only thing not working is when it checks for if a sheet set is open.
For now, that is commented out.
For whatever reason, I was thinking that the custom props needed to be changed globally in the properties dialog box.
Now, I see how this is working; we have to loop through each sheet in the sheet set, have the associated fields present in that particular layout in the sheet, then we edit our props and Regen.
Sound about right?
Very cool!
So, now it brings me back to where you probably are; that is what sheet do you (the user) want to edit?
Or, better yet, have the code recognize what sheet is open (current) prompt them with the custom props (as an attribute dialog box would) and allow them to edit accordingly.
I think (not sure) that we can use the attribute editor still with fields.
Am I more on base now?
Thank you Murph for all the help so far.
Now that I see what is going on, I may be able to understand your project better.
