Sorry if I made it sound like I thought SP was "better" Sdeters. It was not intended. I was just chiming in with something I thought was somewhat relevant.
QuoteSorry if I made it sound like I thought SP was "better" Sdeters. It was not intended. I was just chiming in with something I thought was somewhat relevant. Which you did. I just did not put my words down very well. I am the one that should be sorry. Do you have a small example of a file that you did in softplan to share with the group? I would like to how this works. Thanks for help
K. It appears there is no "small" about it. 29mb At least a color rendered model. This is one I just happened to be working on at the moment.It can be downloaded here. The zip contains the files needed and the Softplan Review install program. http://www.theswamp.org/lilly_pond/index.php?dir=Maverick/&file=Mavs%20review.zip**Tip** Hold down the middle mouse button to orbit. Careful if you get motion sick.
Quote from: Dommy2Hotty on April 10, 2008, 03:05:25 PM...I PREFER to use DWF because of possibility of data loss or mis-translated data during the conversion to a PDF.Interesting comment. Have you ever had a client that opens the PDF (and it looks great on the screen) and prints and some stuff is missing or it doesn't appear as dark as it should be?We've had that exact thing happen recently.
Quote from: Matt W on April 10, 2008, 03:14:33 PMQuote from: Dommy2Hotty on April 10, 2008, 03:05:25 PM...I PREFER to use DWF because of possibility of data loss or mis-translated data during the conversion to a PDF.Interesting comment. Have you ever had a client that opens the PDF (and it looks great on the screen) and prints and some stuff is missing or it doesn't appear as dark as it should be?We've had that exact thing happen recently.This is EXACTLY what has happened to us in the past week and a half! Our backgrounds for MEP plot fine thru AutoCAD, plot fine from the plot files, LOOK fine thru PDF, but the PDF barely prints the background plan. I've read great things about using Ghostscript, but I haven't been able to dive into it.
What are you using to create your PDFs? We're using Bluebeam.
Did anyone dl and try this? Just curious as I had never set one up before. I'm also wondering if the hardware requirements to do the orbiting etc. would be an issue for homeowners if I gave this to them. Everyone here probably has pretty decent computers I suspect though.
http://www.theswamp.org/index.php?topic=21548.msg270660#msg270660
