Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
Code Red
ARX Programming
Topic:
Unable to load
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Unable to load (Read 2223 times)
A_LOTA_NOTA
Bull Frog
Unable to load
on:
February 22, 2008, 12:16:10 PM »
We have been using AutoCAD 2006 & are in the process of upgrading to 2008. I have an arx file that works fine in 2006 but unable to load in 2008.
I any ideas why, or how to fix it?
Logged
Chuck Gabriel
Guest
Re: Unable to load
Reply #1 on:
February 22, 2008, 12:19:09 PM »
If you have the source code and the required compiler and libraries, you can recompile it. Otherwise, you'll have to contact the original developer.
Logged
A_LOTA_NOTA
Bull Frog
Re: Unable to load
Reply #2 on:
February 22, 2008, 12:33:20 PM »
I was thinking that's what I would have to do. This is an add on package that is no longer supported. So guess I'm out of luck.
Is it the way it is coded or just needs recompiled?
Thanks for the reply.
Logged
Chuck Gabriel
Guest
Re: Unable to load
Reply #3 on:
February 22, 2008, 03:32:06 PM »
AutoCAD 2008 is linked with newer versions of MFC and the ObjectARX Libraries. Then there is the Unicode issue. There are probably other factors I'm not even aware of.
Logged
Glenn R
Water Moccasin
What idiot child of married cousins wrote this?!
Re: Unable to load
Reply #4 on:
February 22, 2008, 04:37:34 PM »
Chuck,
That pretty much sums it up...recompilation by the original author(s) for 2008.
Cheers,
Glenn.
Logged
Me
Print
Pages: [
1
Go Up
« previous
next »
Code Red
ARX Programming
Topic:
Unable to load
