Author Topic: Why can't I join these two LWPolylines?  (Read 8921 times)
FengK
« on: February 14, 2008, 04:50:21 PM »
In the attached drawing, there are two LWPolylines. I am not able to join them with PEDIT command, even if I specify adequate fuzz. There is a very small gap between end points of these two LWPolylines. If I drag the end point of either one and move it a little, they can be joined with PEDIT. Why?
Thanks!
David Hall
  • Automatic Duh Generator
Re: Why can't I join these two LWPolylines?
« Reply #1 on: February 14, 2008, 04:55:22 PM »
Z-Values different? nvr mind, z=0
« Reply #2 on: February 14, 2008, 04:57:19 PM »
I joined them no problem:
Select objects:
Enter an option [Close/Open/Join/Width/Fit/Spline/Decurve/Ltype gen/Undo]: j
Join Type = Extend
Enter fuzz distance or [Jointype] <0.000>: 1
10 segments added to polyline
Here's part of the issue:
« Last Edit: February 14, 2008, 05:03:23 PM by ronjonp »
David Hall
« Reply #3 on: February 14, 2008, 04:58:42 PM »
Im guessing it has to do with one of the objects is an arc, and it cant figure out what to do with it
David Hall
« Reply #4 on: February 14, 2008, 05:00:08 PM »
Select objects:
Enter an option [Close/Open/Join/Width/Fit/Spline/Decurve/Ltype gen/Undo]: J
Join Type = Extend
Enter fuzz distance or [Jointype] <0.00000000>: 1
FengK
« Reply #5 on: February 14, 2008, 05:03:28 PM »
Weird. This is what I got:
Command: PEDIT Select polyline or [Multiple]: M
Select objects: P
2 found
Select objects:
Join Type = Extend
Enter fuzz distance or [Jointype] <0.0000>: 1
Plus, why do I need to specify fuzz = 1? The gap size is only 0.00003559.
« Reply #6 on: February 14, 2008, 05:04:47 PM »
Use MPEDIT rather than PEDIT.
deegeecees
« Reply #7 on: February 14, 2008, 05:05:34 PM »
I grabbed the end of the green spline, and moved it to the endpoint of the other, then joined normally through Pedit>Join
10 segments added to the polyline
I'm guessing they weren't exactly end to end.
FengK
« Reply #8 on: February 14, 2008, 05:07:45 PM »
Wow, that's a $100 tip. Thanks a lot!
« Reply #9 on: February 14, 2008, 05:10:51 PM »
You're welcome  :-)
deegeecees
« Reply #10 on: February 14, 2008, 05:11:11 PM »
I didn't know MP had his own edit function inside AutoMad, boy howdy that's sumpthin ta be proud of.
« Reply #11 on: February 14, 2008, 10:23:19 PM »
Heh, everyone knows I hath no love for express tools.
deegeecees
« Reply #12 on: February 15, 2008, 09:48:33 AM »
Let his proclamation go through out the land!
« Reply #13 on: February 15, 2008, 09:52:44 AM »
{the sound of horns spills across the land like morning's first light}
Maverick®
« Reply #14 on: February 15, 2008, 10:37:56 AM »
Ermmm..... Sorry, that was me.  :oops:
