Author Topic: plotstyle.ctb "problem"  (Read 19018 times)
M-dub
Re: plotstyle.ctb "problem"
« Reply #30 on: February 13, 2008, 05:19:03 PM »
I don't know... It sounds like it could be something like "Use Object Lineweight" or "Use Object Colour" on one or the other machines.
Don't mean to ask stupid questions but when you're changing the settings, you're selecting all of the colours, right?  Not just the top one?
Notsober
« Reply #31 on: February 13, 2008, 05:21:52 PM »
i haven't changed any of the settings.
M-dub
« Reply #32 on: February 13, 2008, 05:23:07 PM »
Maybe you should  :?
M-dub
« Reply #33 on: February 13, 2008, 05:23:37 PM »
Have you copied the ctb file from one of the good computers to the bad one?
Josh Nieman
« Reply #34 on: February 13, 2008, 05:24:27 PM »
What's in your startup LSP routine?
Yes, it is a long shot, but at this point I'm grasping at straws :\
Notsober
« Reply #35 on: February 13, 2008, 05:26:32 PM »
yes, i copied the ctb file. All 4 machines are supposedly exactly the same.
I even checked the "screening"... all 255 colors are 100%.
M-dub
« Reply #36 on: February 13, 2008, 05:28:34 PM »
In the table view of your ctb file, do any of them have "enable dithering" on?
Notsober
« Reply #37 on: February 13, 2008, 05:28:51 PM »
In Startup suite, I have loaded:
COPYROT.lsp
fix_qleader_reactor.lsp
revspline.lsp
steel.lsp
Notsober
« Reply #38 on: February 13, 2008, 05:30:15 PM »
no. none are checked.
Josh Nieman
« Reply #39 on: February 13, 2008, 05:34:01 PM »
COPYROT.lsp
revspline.lsp
steel.lsp
What do you have at the bottom of your acaddoc.lsp or acaddoc2008.lsp (or w/e version) ?
M-dub
« Reply #40 on: February 13, 2008, 05:34:59 PM »
I'm pretty sure I'm out of guesses.
You know the sound when you're sucking at a straw when there's no pop left in the cup?  Yeah... that's what I'm getting.  :)
Notsober
« Reply #41 on: February 13, 2008, 05:36:30 PM »
here are some screenshots of my plot settings, this is also exact the same on all 4 machines...
« Last Edit: February 13, 2008, 05:39:46 PM by Robert Holland »
Notsober
« Reply #42 on: February 13, 2008, 05:38:29 PM »
i did a search on my comp of acaddoc.lsp
no matches.
my bad... i needed to look for acad2004doc.lsp
« Last Edit: February 13, 2008, 05:45:20 PM by Robert Holland »
M-dub
« Reply #43 on: February 13, 2008, 05:41:04 PM »
Just out of curiosity, have you tried re-adding the printer on the machine that isn't like the others?
(Sorry... I instantly had this pop in my head....)
Notsober
« Reply #44 on: February 13, 2008, 05:54:33 PM »
HOLY CARP is appropriate here...
now, why the hell did this work?
Edit: (sorry dude, it wasn't)
M-dub
« Last Edit: February 13, 2008, 05:56:31 PM by M-dub »
