Author Topic: BLockDef Table and Layers  (Read 5367 times)
ML
Re: BLockDef Table and Layers
« Reply #15 on: February 13, 2008, 12:19:31 PM »
Hey Guys!
Thanks again! Thanks Bry for the explanation.
I'm just pinging back in to the discussion:
I am definitely more accustom to programming with arrays and that was the method that I started out using before I finally folded and decided to post for a bit of help.
If, you had just coded with an array initially, I likely would have said thanks Bry and moved on.
It was the fact that you used the collection that peaked my interest.
Recently, I saw someone bring in data from a stored procedure from SQL and assign that data to a New Collection and I just thought, that was the coolest thing.
So while I have been at VBA for a few years, there are certainly methods I have not touched yet; like New Collections, Class Modules and so on.
I guess that is one of the beauties of programming, there is always more to learn.
I will definitely examine you code closer and see if I can not apply that method with another example.
Now, after The Collection is created, you could then create properties and methods as well to those objects, couldn't you?
Thanks!
ML
« Reply #16 on: February 13, 2008, 03:46:28 PM »
Bry
I now have (with some help from CM) a Do Until Loop in the code
However, I am not sure how to handle clearing The Laycol after each loop cycle?
As a result, I am picking my first block, it is printing out the proper layer info but after I pick the next block, it is printing out the layers from the last block picked, plus the new layers.
Any suggestions?
Thanks again!
ML
« Reply #17 on: February 13, 2008, 05:26:32 PM »
OK, here is the code that Bry posted only it will now loop through and keep prompting the user for the next block until the user escapes; removing and recreating The LayCol with each loop.
Also, I want to thank CM for his help to advance the code to this point.
Sub BlocklayersLoop() 'This Sub will keep prompting for the next block until user escapes.
      Dim B As AcadBlock
      Dim Ent As AcadEntity
      Dim P
      Dim LayerCol As New Collection
      Dim slayer As String
      Dim Picked As Boolean
      Dim i As Integer
      Do
       On Error Resume Next
       ThisDrawing.Utility.GetEntity Ent, P, "Pick a blockref"
       If Not TypeOf Ent Is AcadBlockReference Then
        Picked = False
        GoTo ExitOut
       Else
        Picked = True
       End If
       If Ent Is Nothing Then
        Picked = False
        GoTo ExitOut
       Else
        Picked = True
       End If
       Set B = ThisDrawing.Blocks(Ent.Name)
       Debug.Print "The block " & B.Name & " uses the following layers:"
       For Each Ent In B
        slayer = Ent.Layer
        For i = 1 To LayerCol.Count
         If LayerCol(i) = slayer Then GoTo skip
        Next
        LayerCol.Add slayer
skip:
        Next
         Debug.Print LayerCol(i)
        Next
ExitOut:
        Dim Num As Integer
         For Num = 1 To LayerCol.Count
          LayerCol.Remove 1
         Next
        Loop Until Picked = False
        Exit Sub
End Sub
David Hall
  • Automatic Duh Generator
« Reply #18 on: February 14, 2008, 11:01:54 AM »
Your welcome, glad I could help
ML
« Reply #19 on: February 14, 2008, 11:04:09 AM »
Yes sir!
That's what it is all about
Helping each other!
Forums Kick A*s! :)
