Author Topic: multi extend at one time  (Read 20072 times)
Re: multi extend at one time
« Reply #15 on: February 13, 2008, 04:28:28 AM »
Yes, very nice Ron !
Joe Burke
« Reply #16 on: February 13, 2008, 07:19:28 AM »
Ron,
I guess I should mention this, which you probably already know. I think the fix you applied was to temporarily close an open pline. This may cause a line to be broken at the temporary closing segment which doesn't make sense once the pline is set back to open and the routine ends.
I'll post an example if this isn't clear.
« Reply #17 on: February 13, 2008, 09:28:43 AM »
xiaxiang
« Reply #18 on: November 11, 2010, 10:31:55 PM »
A little late to the show, but here is my contribution to do multiple boundaries:
(defun c:mextend (/ ang c d1 d2 e l lines lwp lyr pl ptlst pts ss)
ronjonp ,Need your help
I've loaded your routine"mextend",But it didn't work.
Is there Any Operational errors?
« Reply #19 on: November 11, 2010, 11:13:40 PM »
xiaxiang,
Download the code again and try it .... I'm not sure why it ever worked in the first place  :oops:
xiaxiang
« Reply #20 on: November 12, 2010, 12:38:23 AM »
xiaxiang,Download the code again and try it .... I'm not sure why it ever worked in the first place  :oops:
Mr Ninja
I try my best again and again .Anxious,and I can't use your code.woking with 2006,maybe version?
« Reply #21 on: November 12, 2010, 10:13:25 AM »
Are the objects you're trying to extend lines? What errors are you seeing?
cmwade77
« Reply #22 on: November 12, 2010, 11:23:25 AM »
Ron,
I noticed that the results change to layer 0, shouldn't this check to see what layer the lines are drawn on, as well as what color, to match them? Just a thought, but very cool routine.
Edit: Actually, it was the color, if it is hard coded that would change.
« Last Edit: November 12, 2010, 11:49:49 AM by cmwade77 »
« Reply #23 on: November 12, 2010, 11:34:59 AM »
Ron,
I can't duplicate your results?
(while ptlst
  (entmakex (list '(0 . "LINE")
  (cons 8 lyr)
  (cons 10 (car ptlst))
  (cons 11 (cadr ptlst))
  (setq ptlst (cddr ptlst))
« Reply #24 on: November 18, 2010, 11:33:07 AM »
cmwade77,
Did you get the layer issue sorted out?
cmwade77
« Reply #25 on: November 18, 2010, 12:55:41 PM »
Yes, it turned out the layer wasn't changing, but the color (hard coded was).
xiaxiang
« Reply #26 on: November 25, 2010, 08:07:21 AM »
I have two questions:
1.Did it take all the "LWPOLYLINE,LINE,SPLINE,CIRCLE" that have been selected as multiple boundaries when I extend the lines? Or if there were some system variables that I can set the extend option of boundaries to "all"? So everything is boundary.
2. Did i have  included "trim" and "extend" inside in this routine?
Thanks!
« Reply #27 on: November 27, 2010, 10:45:06 PM »
I'm not sure I understand your questions. Can you post a sample drawing with the desired results?
xiaxiang
« Reply #28 on: November 29, 2010, 01:14:01 AM »
At first,feeling so sorry foy my bad EN. :oops:
I just want the result like this(see attached) ,and when I use your mextend.lsp......
(defun c:mextend (/ ang c e lines lwp lyr ptlst pts ss)It have been Shown as the Effect like "x1.gif".
I think that there is some matter with multi extend boundaries which selected.
Help!and this is a sample
« Last Edit: November 29, 2010, 01:29:46 AM by xiaxiang »
« Reply #29 on: November 29, 2010, 01:24:29 PM »
xiaxiang,
If you want the lines to be within the circles, don't included the polyline in your selection. Just select the circles and one line.
