Author Topic: Changing Custom Properties in Sheet Set  (Read 2191 times)
ML
« on: February 08, 2008, 03:59:36 PM »
Does anyone have any code for changing The Custom Properties in a Sheet Set?
I have  ton of code but it is not quite what I need?
Any help would be appreciated!
Thanks!
Guest
Re: Changing Custom Properties in Sheet Set
« Reply #1 on: February 08, 2008, 04:38:58 PM »
Check the other post.  Might be what you're looking for.
ML
« Reply #2 on: February 08, 2008, 06:24:32 PM »
Matt
The pdf is excellent! Thank you
I went through so much code and the code and instructions in this pdf are the most concise instructions and code I have seen yet on Sheet sets.
Matt, I am almost there.
I have a Sheet Set created with Custom Properties
I have the code returning my Sheet Set but I can not seem to get the new properties (in the example) to populate.
Do you think you could take a quick look and see what I am missing?
I'd appreciate it!
Thank you again!
Sub SheetSetCustomProps()
'Create a reference to The Sheet Manager Object
 Dim sheetSetMgr As AcSmSheetSetMgr
 Set sheetSetMgr = New AcSmSheetSetMgr
 Dim DstFile As String
 DstFile = ("I:\eng\HRSDEMO\dwg\HRSDEMO.dst")
'Open a Sheet Set file
 Dim SheetDb As AcSmDatabase
 Set SheetDb = sheetSetMgr.OpenDatabase(DstFile, False)
 Dim Ssetname As String
 Dim SsetDesc As String
 Ssetname = SheetDb.GetSheetSet.GetName
 SsetDesc = SheetDb.GetSheetSet.GetDesc
'Return the Sheet Set Name and Description
 MsgBox "Sheet Set Name: " & Ssetname & vbCrLf + _
 "Sheet Set Description: " & SsetDesc
End Sub
Private Sub SetCustomProperty(SheetDb As AcSmDatabase, strName As String, strValue As Variant, _
Optional bSheetSetFlag As Boolean = True)
'A flag for the Custom Property Value is used to determine if it is a property at the Sheet or Sheet Set level.
'The value used to refer to a Sheet property is CUSTOM_SHEET_PROP and the value used to refer to a Sheet Set value is
'CUSTOM_SHEETSET_PROP. The following procedure demonstrates how to create a reference to the Custom Property Bag
'Create a Reference to the Custom Property Bag
 Dim cBag As AcSmCustomPropertyBag
 Set cBag = SheetDb.GetSheetSet(DstFile).GetCustomPropertyBag
'Create a Reference to a Custom Property Value
 Dim cBagVal As New AcSmCustomPropertyValue
 cBagVal.InitNew SheetDb.GetSheetSet(DstFile) '' cBag
'Set the Flag for Sheet Set or Sheet Property
 If bSheetSetFlag = True Then
  cBagVal.SetFlags CUSTOM_SHEETSET_PROP
 Else
  cBagVal.SetFlags CUSTOM_SHEET_PROP
 End If
'Set the value for the Bag
 cBagVal.SetValue strValue
'Create the property
 cBag.SetProperty strName, cBagVal
'Cleat variable
 Set cBagVal = Nothing
End Sub
[color=red]'This is the part that is not working yet????[/color]
'Setup the Sheet Set's default values
 'SetSheetSetDefaults oSheetDb, "CP15-1", "AU2005 Sheet Set Object Demo for CP15-1", _
 'strSheetSetFldr, "C:\Documents and Settings\<user name>\My Documents\AutoCAD Sheet Sets\CP15-1.dwt", "Layout1"
'Create a Sheet Property
 SetCustomProperty oSheetDb, "Checked By", "LAA", False
 SetCustomProperty oSheetDb, "Complete Percentage", "0%", False
'Create a Sheet Set Property
 SetCustomProperty oSheetDb, "Project Approved By", "AU05"
End Sub
