Author Topic: move attrib lisp modification  (Read 2522 times)
Least
« on: February 08, 2008, 07:08:57 AM »
hi
i am hoping somebody could help me modify this lisp which a kind fellow posted on this website a few months ago.
This lisp allows you to move a single attrib with 2 clicks, i'd like to modify it so that it will also move unattributed text.
I could use the move command but the reason is that often i have this lisp running so it will be a lot quicker to use this rather than cancel and start a new command.
here is the lisp:
(defun C:MOVEATT (/ Ent EntProps LastPoint LastEnt *error*)
  (defun *error* (msg)
    (if LastEnt
      (entdel LastEnt)
    (vl-cmdf "._UNDO" "_END")
    (if (or (= msg "Function cancelled") (= msg "quit / exit abort"))
  (setvar "CMDECHO" 0)
  (vl-cmdf "._UNDO" "_BEGIN")
    (and
      (progn (while (not
      (and (setq Ent (nentsel "\nSelect an attribute: "))
   (= (cdr (assoc 0 (setq EntProps (entget (car Ent))))) "ATTRIB")
     Ent
      (setq LastPoint (cadr Ent)
    LastEnt   (entmakex
(cons
  (cons 0 "TEXT")
  (subst
    (cons 73 (cdr (assoc 74 EntProps)))
    (assoc 74 EntProps)
    (subst
      (cons
10
(cdr
  (assoc
      (= 0 (cdr (assoc 72 EntProps)) (cdr (assoc 74 EntProps)))
       10
       11
    EntProps
      (assoc 10 EntProps)
      (vl-remove-if
(function (lambda (g)
    (vl-position (car g) '(-1 0 2 5 70 73 100 280 330))
EntProps
(setq os ( getvar "osmode")) ;;Get current osnap
(setvar "OSMODE" 0) ;;Osnaps off
       (setvar "LASTPOINT" LastPoint)
       (command "._MOVE" LastEnt "" (cadr Ent) PAUSE)
       (if (not (equal LastPoint (getvar "LASTPOINT")))
(progn (entmod
  (subst (assoc 11 (entget LastEnt))
(assoc 11 EntProps)
(subst (assoc 10 (entget LastEnt)) (assoc 10 EntProps) EntProps)
(entupd (car Ent))
       (entdel LastEnt)
(setvar "osmode" os) ;;Set Osnap back to original
Code tags added
Original posting: <I think - CAB>
http://www.theswamp.org/index.php?topic=19881.msg242230#msg242230
« Last Edit: February 08, 2008, 12:28:08 PM by CAB »
VovKa
  • Ukraine
Re: move attrib lisp modification
« Reply #1 on: February 08, 2008, 12:02:47 PM »
(defun C:MOVEATTXT (/ CE OS Ent EntProps LastPoint LastEnt *error*)
    (if OS
      (setvar 'OSMODE OS)
    (if CE
      (setvar 'CMDECHO CE)
    (if LastEnt
      (entdel LastEnt)
  (setq OS (getvar 'OSMODE)
CE (getvar 'CMDECHO)
  (setvar 'CMDECHO 0)
  (setvar 'OSMODE 0)
    (and
      (progn (while (not (and (setq Ent (nentsel "\nSelect an attribute/text: "))
      (= (length Ent) 2)
      (wcmatch (cdr (assoc 0 (setq EntProps (entget (car Ent)))))
       "ATTRIB,TEXT"
     Ent
      (= (cdr (assoc 0 EntProps)) "ATTRIB")
    LastEnt   (entmakex
(cons
  (cons 0 "TEXT")
  (subst
    (assoc 74 EntProps)
    (subst
      (cons
10
(cdr
  (assoc
       10
       11
    EntProps
      (assoc 10 EntProps)
      (vl-remove-if
EntProps
(progn (entmod
(assoc 11 EntProps)
(entupd (car Ent))
       (entdel LastEnt)
     (command "._MOVE" (car Ent) "" (cadr Ent) PAUSE)
  (setvar 'OSMODE OS)
« Last Edit: February 08, 2008, 01:03:34 PM by VovKa »
« Reply #2 on: February 08, 2008, 12:29:04 PM »
Thanks, link updated.
Least
« Reply #3 on: February 08, 2008, 12:37:44 PM »
Thanks again Vovka for your lisp
I've been doing a fair bit of head scratching.
With the prevoius lisp i just slotted in:
and then reset the osmode variable at the end.
With this lisp i cannot find the correct place to put these commands.
Thanks again
VovKa
  • Ukraine
« Reply #4 on: February 08, 2008, 01:04:19 PM »
my previous post updated to suit your needs :)
daron
« Reply #5 on: February 08, 2008, 01:05:35 PM »
Usually you gather information at the Beginning of your program.
This is usually done at the end of your program. It also can be placed in an error function.
This or any other "mode" you want it to be is placed anywhere you wish to alter these settings.
Least
« Reply #6 on: February 08, 2008, 01:17:35 PM »
Thanks again Vovka, you're a star.
Daron, that is how i have previously gone about it but with this lisp it resulted in a syntax error.
I'm not sure why..
Its working just how i want it now, so many thanks.  :-)
Pad
« Reply #7 on: May 15, 2015, 04:59:06 AM »
Hi
I have recently upgraded to 2015 and this lisp now doesn't work for attributes.
It wont let me select an attribute,  it works fine for text.  Any idea of a fix please?
; Vovka http://www.theswamp.org/index.php?topic=21303.0
;;; move single attribute AS
(defun c:AS nil (C:MOVEATTXT))
    (if OS
      (setvar 'OSMODE OS)
    (if CE
    (if LastEnt
      (entdel LastEnt)
  (setvar 'CMDECHO 0)
  (setvar 'OSMODE 0)
    (and
      (= (length Ent) 2)
       "ATTRIB,TEXT"
     Ent
    LastEnt   (entmakex
(cons
  (cons 0 "TEXT")
  (subst
    (assoc 74 EntProps)
    (subst
      (cons
10
(cdr
  (assoc
       10
       11
    EntProps
      (assoc 10 EntProps)
      (vl-remove-if
EntProps
(progn (entmod
(assoc 11 EntProps)
(entupd (car Ent))
       (entdel LastEnt)
  (setvar 'OSMODE OS)
