Author Topic: LINE WITH TEXT ABOVE  (Read 1805 times)
CADEC70
« on: February 07, 2008, 12:49:06 PM »
Can please someone, create a lisp for me that when you draw a line (on any angle) it will have a text above it (will follow the angle of the line) above it. Thanks
Re: LINE WITH TEXT ABOVE
« Reply #1 on: February 07, 2008, 01:22:13 PM »
This place is more of a learning environment than a give environment, so if you start something people will help you more.
If that doesn't help, then you can use a dimension line, and turn off both extension lines, and change the arrow head to a line, so that it will look like a regular line.
« Reply #2 on: February 07, 2008, 01:30:06 PM »
There are several versions of this type of routine around.
You may want to modify one to fit your needs.
http://www.theswamp.org/index.php?topic=3489.0
« Reply #3 on: February 08, 2008, 09:20:59 AM »
Tim,
That's a great tip for text attached to a line.
