Author Topic: Read file, write file  (Read 11407 times)
Re: Read file, write file
« Reply #15 on: February 07, 2008, 03:21:10 PM »
I'm such a noob I couldn't even get it to print to the command line.  Here is my donation.
using System;
using System.IO;
using System.Text;
using System.Windows.Forms;
namespace WindosApps
/// <summary>
/// Description of ReadFile.
/// </summary>
public class ReadFile
[STAThread]
public static void Main()
string FullFile;
Dictionary<char, int> Dict = new Dictionary<char, int>();
using (StreamReader sr = new StreamReader("c:/test.txt")) {
FullFile = sr.ReadToEnd();
foreach (char chr in FullFile.ToCharArray()) {
if (Dict.ContainsKey(chr))
Dict[chr] = ++Dict[chr];
else
Dict.Add(chr, 1);
StringBuilder sb = new StringBuilder();
foreach (KeyValuePair<char, int> kvp in Dict) {
//Console.WriteLine("Letter {0} appears {1} time(s).", kvp.Key, kvp.Value);
sb.Append("\n");
sb.Append(kvp.Key.ToString());
sb.Append(" [ ");
sb.Append(kvp.Value.ToString());
sb.Append(" ]");
//Console.WriteLine("\n Hit enter to continue.");
//Console.ReadLine();
MessageBox.Show(sb.ToString());
David Hall
  • Automatic Duh Generator
« Reply #16 on: February 07, 2008, 03:38:54 PM »
Autocad command line or console cmd line?
This is not inside autocad, and doesn't have the autocad references needed to print to cmd line there.
If you knew this, just ignore me
« Reply #17 on: February 07, 2008, 03:43:05 PM »
I was just doing it as a windows based program, so no Acad references.
Here is a better version.  It will only allow characters between 0-9, A-Z and a-z, and the dictionary, by definition, is sorted.
using System;
using System.IO;
using System.Text;
/// <summary>
/// </summary>
[STAThread]
string FullFile;
//Dictionary<char, int> Dict = new Dictionary<char, int>();
SortedDictionary<char, int> Dict = new SortedDictionary<char, int>();
using (StreamReader sr = new StreamReader("c:/Raster2006.log")) {
int tempInt;
tempInt = (int)chr;
if
(tempInt < 91 && tempInt > 64
tempInt < 123 && tempInt > 96
tempInt < 58 && tempInt > 47
else
Dict.Add(chr, 1);
sb.Append("\n");
sb.Append(" [ ");
sb.Append(" ]");
David Hall
« Reply #18 on: February 07, 2008, 04:02:43 PM »
OK, I can see from the submissions, I definitly need t learn how to use Dict objects.
David Hall
« Reply #19 on: February 08, 2008, 12:32:51 PM »
OK, thanks everybody for the input.  I have a working bit of code using the Console, now I would like to move to a windows form.  Let me say I have NEVER done a windows form in C# other than HelloWorld.  Im thinking this should be pretty straight forward, but I want to be able to pick a file from the form.  I'll keep you posted on my progress.
« Last Edit: February 08, 2008, 02:07:19 PM by CmdrDuh »
David Hall
« Reply #20 on: February 08, 2008, 12:33:19 PM »
For those playing along, here is my code so far
using System;
using System.IO;
using System.Linq;
using System.Text;
namespace Signage
    class Program
        public static void Main(string[] args)
            string FullFile;
            string flInput;
            string flOutput;
            Console.WriteLine("Enter File Name to process with a / slash");
            flInput = Console.ReadLine();
            Console.WriteLine("Enter File Name to Output to with a / slash");
            flOutput = Console.ReadLine();
            StreamWriter sw = new StreamWriter(flOutput);
            using (StreamReader sr = new StreamReader(flInput))
            int tempInt;
                tempInt = (int)chr;
                if
                     tempInt < 58 && tempInt > 31 //47  Changed to pick up the ()'. and space characters
                    else
                        Dict.Add(chr, 1);
                //sb.Append("\n");   Removed b/c it was not needed using WriteLine and it was creating unknown char in txt file
                sb.Append("Character: ");
                sb.Append(" - [ ");
                sb.Append(" ]");
                sw.WriteLine(sb);
                sw.Flush();
            sw.Close();
« Last Edit: February 08, 2008, 12:38:20 PM by CmdrDuh »
David Hall
« Reply #21 on: February 08, 2008, 02:04:16 PM »
Here is the windows form version
using System;
using System.IO;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
namespace SubStationSignage
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
        private void btnFileToProcess_Click(object sender, EventArgs e)
            openFileDialog1.InitialDirectory = "c:\\";
            openFileDialog1.Filter = "txt files (*.txt)|*.txt|All files (*.*)|*.*";
            openFileDialog1.FilterIndex = 0;
            openFileDialog1.RestoreDirectory = true;
            openFileDialog1.FileName = string.Empty;
            if (openFileDialog1.ShowDialog() == DialogResult.OK)
                txtFileToProcess.Text  = openFileDialog1.FileName;
        private void btnFileToCreate_Click(object sender, EventArgs e)
            saveFileDialog1.InitialDirectory = "c:\\";
            saveFileDialog1.FileName = string.Empty;
            saveFileDialog1.DefaultExt = "txt";
            saveFileDialog1.Filter = "txt files (*.txt)|*.txt";
            if (saveFileDialog1.ShowDialog() == DialogResult.OK)
                txtFileToCreate.Text = saveFileDialog1.FileName;
        private void btnBegin_Click(object sender, EventArgs e)
            if ((txtFileToProcess.Text != string.Empty) && (System.IO.File.Exists(txtFileToProcess.Text)) && (txtFileToCreate.Text != string.Empty))
                if (System.IO.File.Exists(txtFileToCreate.Text))
                    System.IO.File.Delete(txtFileToCreate.Text);
                string FullFile;
                string flInput = txtFileToProcess.Text;
                string flOutput = txtFileToCreate.Text;
                int tempInt;
                    tempInt = (int)chr;
                    if
                        else
                            Dict.Add(chr, 1);
                    //sb.Append("\n");
                    sb.Append(" - [ ");
                    sb.Append(" ]");
                    sw.WriteLine(sb);
                    sw.Flush();
                sw.Close();
David Hall
« Reply #22 on: February 08, 2008, 02:06:25 PM »
Next question, I see that the Dictionary has key/value pairs.  What I need is triplets.   Is this possible?  Where key would be the Character ie "A", Value would be Character.Count - 3, and the 3rd value would be our Stores Number (part number in warehouse) ie 5121802
« Reply #23 on: February 08, 2008, 02:21:54 PM »
I don't think so, but you maybe be able to do it.  You could define the key as a List or ArrayList, and then just add one to the first (or second) value in the List, but that is just thinking out loud.
David Hall
« Reply #24 on: February 08, 2008, 04:04:56 PM »
I have another question that is perplexing me.  I wrote this using .Net3.5, and it works on a machine w/ .Net3.0.  Is this b/c my project is so simple the form stuff hasn't changed in 3.5?  Also, using Express, how can I make a deployable exe for distribution?
Chuck Gabriel
« Reply #25 on: February 08, 2008, 04:23:59 PM »
Could you declare your container something like this:
Dictionary<char, KeyValuePair<int, int> > mrDuhsContainer = new Dictionary<char, KeyValuePair<int, int> >;
« Reply #26 on: February 08, 2008, 05:02:48 PM »
Yes.
Don't know since I use SharpDevelop, and I only code for myself really.
David Hall
« Reply #27 on: February 08, 2008, 05:30:07 PM »
Sounds good to me, will have try that on monday
David Hall
« Reply #28 on: February 08, 2008, 05:30:32 PM »
Yes.
thought so
« Reply #29 on: February 08, 2008, 07:43:50 PM »
David,
I'd handle the initialisation of the Dictionary slightly differently ; with a mind to making modifications more efficient without needing to recompile the code.
If you were to have a definition file that contained {say} one entry per item for ;
char , catalogCode
ie
a 101234583
~ 102333356
etc ..
read this file in and initialise the Dictionary , adding a zero count for each.
you could then replace the casting of chars and the testing of the resultant int value
with a simple
                            Dict[chr] = ++Dict[chr];  //<<==== or whatever :-)
being secure in the knowledge that ONLY the characters you want to count will be already in the Dictionary.
