Author Topic: Xref Reactor Revisted!  (Read 1748 times)
Shade
« on: January 30, 2008, 04:05:44 PM »
I have previously posted about this topic, and I am having the same problem, in that the reactor will not switch the layer back to its previous state before I executed the xref command.  I have tried using the provided examples to no avail.
Refer to...
http://www.theswamp.org/index.php?topic=19056.msg231515#msg231515
http://www.theswamp.org/index.php?topic=9537.msg122497#msg122497
I would like to now if one could reverse the xref reactor, so that the code read like this.
[b]Pseudo Code:[/b]
If command is not "XREF" switch layer to "0".
If command is xref switch to "Xref Layer"
I have several other layer reactor for various other commands and they all work great thanks to all the help I received here.
I appreciate all the help, but I am still fishing for more.
 :mrgreen:
Re: Xref Reactor Revisted!
« Reply #1 on: February 01, 2008, 09:34:43 AM »
Shade,
I am still testing this code but you can give it a go.
You will be using the last layer group in the code so comment out any command you don't want a layer set for.
I plan to move the layers into a text file.
Find this "CAB2.lin" and change it to your line file if you have one or to "" if you don't.
     (setq *al_LayUpdt* nil
      LtFname "CAB2.lin")
;;  Vlr_AutoLayer.lsp by CAB 01.28.2008
;; Sets the correct layer for certain commands.
;; Vlr Command is a function that will switch the active layer in a drawing.
;; The reactor checks the command that is starting and if it recognizes it
;; it will switch to a specified layer. If the layer doesn't exist it will
;; create it with the color, linetype, and plottable setting provided.
;; To load and run this program add the lines (load "Vlr_AutoLayer")(c:Vlr_AutoLayer)
;; to your acaddoc.lsp or another autoloading lisp routine.
;;  REVISIONS
;;    added error trap for layer creator
;;    added layer restore at command exit
;;    added code to test loaded status
;;    added code to turn reactors Off & back On again
;;    added code for different layers per user or task
;;    NOTE: set var *al_user* to use different layers per user
;;    NOTE: set var *al_LayPrefix* to add a prefix to the layer name used
(defun C:AutoLayerOn () (Vlr_AutoLayer t))
(defun C:AutoLayerOff () (Vlr_AutoLayer nil))
(defun Vlr_AutoLayer (mode)
    (mode
      ;; Load only once, if already loaded reactivate it if inactive
      (and *vlr-CWS (not (vlr-added-p *vlr-CWS)) (vlr-add *vlr-CWS))
      (and *vlr-CE (not (vlr-added-p *vlr-CE)) (vlr-add *vlr-CE))
      (and *vlr-CC (not (vlr-added-p *vlr-CC)) (vlr-add *vlr-CC))
      (or *vlr-CWS
         (setq *vlr-CWS (vlr-command-reactor nil '((:vlr-commandwillstart . AlStartCommand)))))
      (or *vlr-CE
         (setq *vlr-CE (vlr-command-reactor nil '((:vlr-commandEnded . AlEndCommand)))))
      (or *vlr-CC
         (setq *vlr-CC (vlr-command-reactor nil '((:vlr-commandCancelled . AlCancelCommand)))))
      (print "AutoLayer is ON!")
    ;;  Turn the reactors off
    (t
      (and *vlr-CWS (vlr-added-p *vlr-CWS) (vlr-remove *vlr-CWS))
      (and *vlr-CE (vlr-added-p *vlr-CE) (vlr-remove *vlr-CE))
      (and *vlr-CC (vlr-added-p *vlr-CC) (vlr-remove *vlr-CC))
      (print "AutoLayer is OFF!")
(defun AlStartCommand (Call CallBack / CmdLayerList LyrDat LtFname)
  ;;  current layer restored on exit of command
  (setq *Currentlayers* (cons (getvar "CLAYER") *Currentlayers*))
  ;; Examples of Command vs Layer
  ;; List of corresponding to (command layerName color# linetype plottable plotstyle)
  ;;  LineType "" = "continuous"
  ;;  plottable for STB DWGs, nil or :vlax-false or missing = NoPlot
  ;;                          T or :vlax-true = Plot
  ;; NOTE command names must be in Upper Case
    ((and *al_user*(= (type *al_user*) 'STR)(= (strcase *al_user*) "DAN"))
     (setq *al_LayUpdt* t
      LtFname nil) ; Second LineType File to Search
     (setq CmdLayerList
            (list  ; (command layerName color# linetype plottable)
              (list "DIMANGULAR" "I_ANNO-DIMS" 14 "" :vlax-true)
              (list "DIMBASELINE" "I_ANNO-DIMS" 14 "" :vlax-true)
              (list "DIMCENTER" "I_ANNO-DIMS" 14 "" :vlax-true)
              (list "DIMCONTINUE" "I_ANNO-DIMS" 14 "" :vlax-true)
              (list "DIMDIAMETER" "I_ANNO-DIMS" 14 "" :vlax-true)
              (list "DIMLINEAR" "I_ANNO-DIMS" 14 "" :vlax-true)
              (list "DIMRADIUS" "I_ANNO-DIMS" 14 "" :vlax-true)
              (list "QDIM" "I_ANNO-DIMS" 14 "" :vlax-true)
              (list "LEADER" "I_ANNO-NOTE" 11 "" :vlax-true)
              (list "QLEADER" "I_ANNO-NOTE" 11 "" :vlax-true)
              (list "DTEXT" "I_ANNO-NOTE" 11 "" :vlax-true)
              (list "MTEXT" "I_ANNO-NOTE" 11 "" :vlax-true)
              (list "TEXT" "I_ANNO-NOTE" 11 "" :vlax-true)
              (list "BHATCH" "I-FIXT-7" 8 "" :vlax-true)
              (list "HATCH" "I-FIXT-7" 8 "" :vlax-true)
              (list "MVIEW" "Z-VIEWPORT" 7 "" :vlax-false)
                    ; Add your own command layer lists here....
    ((and *al_user*(= (type *al_user*) 'STR)(= (strcase *al_user*) "Future Use"))
     (setq CmdLayerList '())
    ((and *usermode*(= (type *usermode*) 'STR)(= (strcase *usermode*) "CAB"))
      LtFname "CAB2.lin")
     (or *al_LayPrefix* (setq *al_LayPrefix* ""))
     (setq CmdLayerList
            (list  ; (command layerName color# linetype plottable plotstyle)
              ;(list "3DFACE"
              ;(list "ARC"        "Arc" 5 "" t "Light")
              (list "BHATCH"      "A-HATCH" 8 "" t "Light")
              ;(list "BOX"
              (list "CIRCLE"      "Circle" 5 ""  t "Light")
              ;(list "CONE"
              ;(list "CYLINDER"
              (list "DIMALIGNED"  "S-DIM"  5 ""  t "Light")
              (list "DIMANGULAR"  "S-DIM"  5 ""  t "Light")
              (list "DIMBASELINE" "S-DIM"  5 ""  t "Light")
              (list "DIMCENTER"   "S-DIM"  5 ""  t "Light")
              (list "DIMCONTINUE" "S-DIM"  5 ""  t "Light")
              (list "DIMDIAMETER" "S-DIM"  5 ""  t "Light")
              (list "DIMLINEAR"   "S-DIM"  5 ""  t "Light")
              (list "DIMORDINATE" "S-DIM"  5 ""  t "Light")
              (list "DIMRADIUS"   "S-DIM"  5 ""  t "Light")
              (list "DONUT"       "Pline"  5 ""  t "Light")
              (list "DTEXT"       "A-TEXT" 2 ""  t "Light")
              (list "ELLIPSE"     "Ellipse" 5 ""  t "Light")
              (list "HATCH"       "A-HATCH" 8 ""  t "Light")
              (list "LEADER"      "A-DIM" 5 ""  t "Light")
              (list "LINE"        "Line" 5 ""  t "Medium")
              (list "MTEXT"       "A-TEXT" 2 ""  t "Light")
              (list "MVIEW"       "A-VIEWPORT" 7 "" nil "Light")
              ;(list "OBLIQUE"
              (list "PLINE"       "Pline" 5 ""  t "Medium")
              (list "POINT"       "A-POINTS" 7 ""  t "Medium")
              (list "POLYGON"     "Pline"  5 ""  t "Light")
              (list "QDIM"        "S-DIM"  5 ""  t "Light")
              (list "QLEADER"     "A-DIM"  5 ""  t "Light")
              (list "RAY"         "Ray"    5 ""  t "Light")
              (list "RECTANG"     "Pline"  5 ""  t "Light")
              ;(list "REGION"
              (list "REVCLOUD"    "A-REVCLOUD" 7 ""  t "Light")
              ;(list "SOLID"
              ;(list "SPHERE"
              (list "SPLINE"      "Spline"  7 ""  t "Light")
              (list "TABLE"       "A-TABLE" 2 ""  t "Light")
              (list "TEXT"        "A-TEXT"  2 ""  t "Light")
              ;(list "TOLERANCE"
              ;(list "TORUS"
              ;(list "WEDGE"
              (list "XLINE"       "A-CONST-LINES" 9 ""  t "Light")
              (list "XREF"        "Xref" 7 "" t)
              ;; Add your own command layer lists here....
    (t  ; default Layer Group
      LtFname "CAB2.lin")
     (setq CmdLayerList
              ;(list "3DFACE"
              ;(list "BOX"
              ;(list "CONE"
              ;(list "CYLINDER"
              ;(list "OBLIQUE"
              ;(list "REGION"
              ;(list "SOLID"
              ;(list "SPHERE"
              ;(list "TOLERANCE"
              ;(list "TORUS"
              ;(list "WEDGE"
  ;; Find the Command
  (if (setq LyrDat (assoc (strcase (car CallBack)) CmdLayerList))
    ;;  make or update layer, then make current
    (if (MakeLayer (cdr LyrDat))
      (vla-put-activelayer
        (vlax-ename->vla-object (tblobjname "LAYER" (cadr LyrDat)))
;; Make layers using activeX
;; return t if sucessful else nil
(defun MakeLayer (DataLst / LayName LayColor LineType LayPlot PltSty LayObj LayObjLst
LineTypeSOBJ fn result NewLay)
  (mapcar '(lambda (x y)(set (read x) y))
          '("LayName" "LayColor" "LineType" "LayPlot" "PltSty") DataLst)
  (or *DOC* (setq *DOC* (vla-get-activedocument (vlax-get-acad-object))))
  (and *al_LayPrefix* (setq LayName (strcat *al_LayPrefix* LayName)))
  (setq LayObjLst (vla-get-layers *DOC*))
  (if (tblobjname "layer" LayName) ; layer exist
    (setq LayObj (vla-item LayObjLst LayName))
    (setq LayObj (vl-catch-all-apply 'vla-add (list LayObjLst LayName))
    NewLay t)
  ;;(setq LayObj (vla-item LayObjLst LayName))
  (if (vl-catch-all-error-p LayObj)
    (not (print (vl-catch-all-error-message LayObj)))
      (if (= (strcase (vla-get-name LayObj)) (strcase (getvar "clayer")))
        (progn ; can not change current layer so make something else current
        ;;  what if "0" is frozen?
          ;;  need to thaw it then restore old layer, and freeze if thawed.
          (setvar "clayer" "0")
      (vla-put-lock LayObj :vlax-false)
      (vla-put-layeron LayObj :vlax-true)
      (vla-put-freeze LayObj :vlax-false)
      (if (or NewLay *al_LayUpdt*)  ; ok to update layer color, plot, LineType
           (if (or (null LineType) (= LineType ""))
             (setq LineType "continuous")
           (if (tblobjname "ltype" LineType)
            (vla-put-linetype LayObj LineType)
              (setq LineTypeSOBJ (vla-get-linetypes *DOC*))
              (if (and LtFname (/= LtFname "")
                     (setq fn (findfile LtFname)))
                 (vl-catch-all-apply '(lambda ( ) (vla-load LineTypeSOBJ LineType fn)
                                              (setq result t)  ; true only if load susceded
              (if (and (not result)
                    (setq fn (findfile (if (zerop (getvar "measurement")) "acad.lin" "acadiso.lin"))))
              (vlax-release-object LineTypeSOBJ)
              (and result (vla-put-linetype LayObj LineType))
          (if (and PltSty (/= PltSty ""))
            (vl-catch-all-apply '(lambda(lay) (vla-put-plotstylename LayObj PltSty)))
          (vla-put-color LayObj LayColor)
          (vla-put-plottable LayObj (cond ((null LayPlot):vlax-false)
                                          ((= LayPlot t):vlax-true)
                                          (LayPlot)))
      ) ; end if (or NewLay *al_LayUpdt*)
      t
(defun RestoreCurrentLayer()
  (if *Currentlayers*
      (vla-put-lock
        (vla-item
          (vla-get-layers
          (car *Currentlayers*)) :vlax-false)
      (setvar "CLAYER" (car *Currentlayers*))
      (setq *Currentlayers* (cdr  *Currentlayers*))
;;  Restore curent layer
(defun AlEndCommand (Call CallBack)
  (RestoreCurrentLayer)
(defun AlCancelCommand (Call CallBack)
;---------------=<  E N D   O F   F I L E  >=------------------
Shade
« Reply #2 on: February 20, 2008, 11:25:26 AM »
Thanks CAB, I will look at what you got and adapt it.
What I have seen it looks like a nice piece of code:  :mrgreen:
