Author Topic: acedGetKWord examples  (Read 5431 times)
MickD
  • (x-in)->[process]->(y-out)
« on: January 29, 2008, 04:39:25 PM »
Does anyone have any get keyword examples, there's some tricky mojo going on in there I haven't grasped yet and I can't find very much in the doc's.
The code below (which is what's left after a fried brain cell or 2) is what I'm trying to do but the keywords are not getting picked up. I've tried moving the brackets & <>'s to all kinds of places, there's atrick to this I'm sure so any help would be great.
thanks.
void Settings()
// Allows the user to change the global variables for the drilling
// and polycut routines, offsets to be added later.
// Steps:
// ----- 1. Create the prompts and keywords for the settings:
int stat;
ads_real x = gDrillDia;
ACHAR kw[20];
// Null input is not allowed.
acedInitGet(RSG_NONULL, _T("Drill-Diameter Hole-depth Polycut-length"));
if ((stat = acedGetReal(_T("\n Enter new Drill-diameter[Hole-depth/Polycut-length]: "),&x) == RTNORM))
if (stat == RTKWORD && acedGetInput(kw) == RTNORM)
if (_tcscmp(kw, _T("Hole-depth")) == 0)
acutPrintf(_T("User entered H"));
stat = RTNORM;
else if (_tcscmp(kw, _T("Polycut-length")) == 0)
acutPrintf(_T("User entered P"));
stat = RTNORM;
if (stat != RTNORM)
acutPrintf(_T("DCS Error: in settings input.\n"));
else
gDrillDia = x;
return;
What I'd really like is to be able to just change the drill diameter as default so top avoid another 'enter' but have the other two settings as a choice which then need to be edited.
« Last Edit: January 29, 2008, 04:56:27 PM by MickD »
"First, solve the problem. Then, write the code." — John Johnson
MickD
Re: acedGetKWord examples
« Reply #1 on: January 29, 2008, 05:28:21 PM »
Ok, got something working after taking a long fresh look at it (dang'd logic :roll:)
void Settings()
// Steps:
int stat;
ACHAR kw[20];
[color=blue]stat = acedGetReal(_T("\n Enter new Drill-diameter[Hole-depth/Polycut-length]: "),&x);
if (stat == RTKWORD)
acedGetInput(kw);[/color]
stat = RTNORM;
stat = RTNORM;
if (stat != RTNORM)
else
gDrillDia = x;
return;
Glenn R
  • What idiot child of married cousins wrote this?!
« Reply #2 on: January 29, 2008, 05:57:51 PM »
And here I was thinking you were occa...shame on you Mr. Mick...shame, shame shame! :)
Me
MickD
« Reply #3 on: January 29, 2008, 06:13:01 PM »
hehe, I couldn't say what I really wanted too :D
(p.s. Thanks Derryn ;))
Here's a much better solution - and it works :)
void Settings()
// Steps:
int stat;
ads_real x;
ACHAR kw[20];
ACHAR prompt[256];
swprintf(prompt,_T("\n Enter new Drill-diameter[Hole-depth/Polycut-length]<current=%.2f>: "),gDrillDia);
acedInitGet(RSG_NONULL | RSG_NOZERO, _T("Drill-Diameter Hole-depth Polycut-length"));
stat = acedGetReal(prompt,&x);
switch(stat)
case RTKWORD:
acedGetInput(kw);
swprintf(prompt,_T("\n Enter new hole depth<current=%.2f>: "),gDrillDepth);
acedInitGet(RSG_NONULL | RSG_NOZERO, _T(""));
stat = acedGetReal(prompt, &x);
if(stat == RTNORM) gDrillDepth = x;
swprintf(prompt,_T("\n Enter new polycut length<current=%.2f>: "),gPolyCutDepth);
if(stat == RTNORM) gPolyCutDepth = x;
break;
case RTCAN: //user pressed cancel.
return;
break;
case RTNORM: // input ok from first prompt.
gDrillDia = x;
break;
default: // something went wrong!
return;
<edit> added float formatting
« Last Edit: January 29, 2008, 06:18:40 PM by MickD »
It's Alive!
  • Retired
  • AKA Daniel
« Reply #4 on: January 29, 2008, 11:39:06 PM »
Whew! Welcome back to the land of curly braces, I thought we had lost you  :lol:
Retired
MickD
« Reply #5 on: January 29, 2008, 11:55:21 PM »
Naahhh, just needed a break and nut out some things in a more user friendly environment. The downside though was that there's a LOT of functionality I need not (easily) available in vba so it's back to old faithful :)
I've actually punched out a couple of thousand lines of C/C++ over the last week or so and I'm starting to get back into the swing of it, it's re-learning the api that's the slowest part now but it's coming back pretty fast ;)
It's Alive!
  • Retired
  • AKA Daniel
« Reply #6 on: January 29, 2008, 11:59:00 PM »
Cool ARXDBG has a pretty good sample class on handling prompts,
also It might be cool to make a class that acts similar to .NET’s PromptOption classes
Retired
