Author Topic: _pasteclip problem  (Read 6653 times)
Notsober
_pasteclip problem
« on: January 29, 2008, 10:58:43 AM »
Could someone please help me with this...
http://discussion.autodesk.com/thread.jspa?messageID=5509864
I never did get it resolved.
hudster
Re: _pasteclip problem
« Reply #1 on: January 29, 2008, 11:19:25 AM »
I opened the two test drawings on the post and can cut and paste between them with no errors, the plot styles go a bit nuts but thats it.
**edit**
plot styles didn't go nuts, I pasted to one of my drawings with the same plot style name but different text size
and I'm using Vanilla 2008.
« Last Edit: January 29, 2008, 11:23:47 AM by Andy Hudson »
Notsober
« Reply #2 on: January 29, 2008, 11:23:26 AM »
well this is a problem with 2004 I think. I can open the same two dwgs in 2007 or 2008, and have NO problem copying and pasting. Open the same dwgs with 2004, no chance.
I tried the supposed "hotfix" but to no avail.
hudster
« Reply #3 on: January 29, 2008, 11:25:35 AM »
do both your 2007 and 2008 versions have the current service packs installed?
Notsober
« Reply #4 on: January 29, 2008, 11:28:35 AM »
probably not. I say that only cuz our IT isn't much of a CAD manager, and we don't have a CAD manager. So updates from Autodesk are blocked. Installation is on HD and not from the server.
hudster
« Reply #5 on: January 29, 2008, 11:31:21 AM »
I would definitely recommend you download and install the service packs.
Weblink - http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9240618
Notsober
« Reply #6 on: January 29, 2008, 12:09:20 PM »
i don't have permission to install service pack. And I'd rather keep my arm and leg to get that permission, if ya know what I mean.
you do mean the servicepack 1a for 2004, right?
hudster
« Reply #7 on: January 29, 2008, 12:17:53 PM »
You need to service pack all autocad versions.
The service packs are to fix bugs with the software, to not install them is just not worth it, any IT person worth their salt would see the benefit of having all software running correctly, if they won't service pack software they are nuts.
Service pack one for 2008 fixes this issue
Copy/paste now works in the drawings saved as 2000 and then resaved in AutoCAD 2004, AutoCAD 2005, or AutoCAD 2006
Service pack two for 2007 also fixes the same issue
# The following operations now perform correctly in files saved in AutoCAD 2000 and Release 14 file formats from AutoCAD 2007:
    * Copy and Paste
    * Cut and Paste
« Last Edit: January 29, 2008, 12:20:58 PM by Andy Hudson »
« Reply #8 on: January 29, 2008, 12:25:06 PM »
I used TrueConvert and saved back to ver 14 then opened in ACAD2000.
It will not allow any copy & paste within the DWG.
Also opened in ACAD2006, stil no Copy & Paste.
The Copy showed 1 object found bur no paste,
I noticed thet there is a DXF code 370 in most objects, even when I add a LINE the code is there.
(370 . -1)
This in not in my other drawings & something is adding it within this drawing.
That's all I have time for..
Oh, I used MP's (c:getproxies  and it generated an error.
hudster
« Reply #9 on: January 29, 2008, 12:36:01 PM »
copy and paste is a known issue, but you need to service pack to overcome it.
Notsober
« Reply #10 on: January 29, 2008, 01:11:34 PM »
okay, I just got finished talking with IT, and she said soon I'm having to upgrade from 2004 to 2007 anyways. So that will just send me back to the drawing board  :lol:
hope that don't make my custom menu obsolete!
hudster
« Reply #11 on: January 30, 2008, 03:42:28 AM »
your upgrading to 2007, just as 2009 is about to come out.
That's some IT department you've got there.
diarmuid
« Reply #12 on: February 01, 2008, 05:44:23 AM »
I feel i have encontered this problem before, and i have alos found a solution.
When drawings have been created in AuotCAD 2006 or higher, and have been backsaved to an older version say 2000, certain "reactors" (excuse my terminology here, i am not a software guy, ironically i'm a CAD manager, so i suppose i am).  this means that some drawings bieng worked on in that lower version of AuotCAD (say 2002) copy and past AND wblock and block creation is disabled/blocked in laymans terms "broken"
Solution:
Download True drawing convert (or what ever they call it now).  open the affected drawings save them back up to 2007/2008 and then resave them back down to the version/format you require.
Below is an older link to the very topic on the Autodesk website:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7450124&linkID=9242019
hope this helps, just trying to give something back
If you want to win something run the 100m, if you want to experience something run a marathon
Notsober
« Reply #13 on: February 04, 2008, 02:37:41 PM »
don't get me started on our "IT" department...
she does think she's it... the shiznit, that is. Somebody lied to her, and told her she's somethin else.
Notsober
« Reply #14 on: February 04, 2008, 02:40:16 PM »
Solution:
thanks for the info...
that would work for me, but only once. Just as soon as I close the dwg, someone else with 2007 or 2008 opens and saves it again, rendering it useless to me again. I'm having to keep TrueConvert open and running, with the engine already runnin hot as it is!!
