Sure Matt
I'd be interested to see it as well.
Thanks!
Better late than never! I didn't include everything, but I think you'll be able to figure out what's going on.
Here's what the MENU.FIL file looks like.
[MENU]
VERSION=84
[SLIDE]
VERSION=16
[ACAD]
VERSION=33
[SDSKDFM]
VERSION=2
[DVBS]
VERSION=36
[DETAILS]
VERSION=14
And here's what the update file (UPDATE.LSP) looks like.
;;; Function: LOADDOSLIB
;;; Description: Loads DosLib
(defun LoadDosLib ()
(if (= (substr (getvar "acadver") 1 2) "17")
(if (null dos_about)(arxload (strcat LSPDir "doslib17")))
(if (null dos_about)(arxload (strcat LSPDir "doslib2004")))
;;; Function: UNLOADDOSLIB
;;; Description: Unloads DosLib
(defun UnloadDosLib ()
(if (not (null dos_about)) (command "arx" "unload" "doslib17"))
(if (not (null dos_about)) (command "arx" "unload" "doslib2004"))
;;; Function: UPD8
;;; Description: Update the menu file
(defun Upd8 (menuFile / strVersion)
(setvar "cmdecho" 0)
(setvar "menuecho" 0)
(if (findfile (strcat CAD_Dir menuFile ".fil"))
; If the MENU.FIL exists...
(LoadDosLib)
(CheckMenu)
(CheckSlideFile)
(setq strVersion (vl-registry-read (strcat "HKEY_LOCAL_MACHINE\\" (vlax-product-key)) "ProductName"))
((= strVersion CAD_ACAD_LDT)
(CheckDFM)
(CheckDvbs)
(CheckDetails)
(UnloadDosLib)
(LoadDosLib)
(CreateMenu)
(dos_copy (strcat UpdDir menuFile ".fil") (strcat CAD_Dir menuFile ".fil"))
(UnloadDosLib)
(setq strVersion nil)
(defun CheckDVBs ( / mFile1 mFile2 lstFiles strFName)
(setq mFile1 (dos_getini "DVBS" "VERSION" (strcat CAD_Dir menuFile ".fil")))
(setq mFile2 (dos_getini "DVBS" "VERSION" (strcat UPDDir menuFile ".fil")))
(if (/= mFile2 mFile1)
(dos_attrib (strcat CAD_Dir "*.*") 0)
(setq lstFiles (vl-directory-files CAD_Dir "*.dvb" 1))
(foreach strFName lstFiles
(vl-file-delete (strcat CAD_Dir strFName))
(CopyDVBs)
(dos_setini "DVBS" "VERSION" mFile2 (strcat CAD_Dir menuFile ".fil"))
(defun CopyDVBs ( / )
(dos_copy (strcat DVBDir "ABSMatch.dvb") (strcat CAD_Dir "ABSMatch.dvb"))
(dos_copy (strcat DVBDir "Batch_Processor.dvb") (strcat CAD_Dir "Batch_Processor.dvb"))
(dos_copy (strcat DVBDir "Batch Binder.dvb") (strcat CAD_Dir "Batch Binder.dvb"))
(dos_copy (strcat DVBDir "Block To Device.dvb") (strcat CAD_Dir "Block To Device.dvb"))
And here's how I start the update....
(load "update")(upd8 "menu")
