Author Topic: Dimension reactor  (Read 12360 times)
Re: Dimension reactor
« Reply #15 on: January 24, 2008, 03:19:45 PM »
Remove this (load "vlr_command")(c:vlr_command)  from your ACADdoc.lsp
When the drawing is open, Load the lisp.
Enter vlr_command at the command line
the enter .dimlinear
Does that work?
ELOQUINTET
« Reply #16 on: January 24, 2008, 04:37:07 PM »
cab I did exactly as you said but it is not changing to the specified layer? Here's my text window
AutoCAD menu utilities loaded.
Command: AP
APPLOAD acad.lsp successfully loaded.
Command:
Command:
Command: vlr_command
#<VLR-Command-Reactor>
Command:
Command: .DIMLINEAR
and here's what's in my acad.lsp???
<Old code removed, see below for updated code>
http://www.theswamp.org/index.php?topic=21056.msg255892#msg255892
« Last Edit: April 25, 2008, 04:48:35 PM by CAB »
« Reply #17 on: January 24, 2008, 04:46:51 PM »
In the lisp remove the dot. As the dot is only needed at the Command Line to prevent the command from being redirected.
Change this
(list ".DIMLINEAR" "I_ANNO-DIMS" 14 "continuous" :vlax-true)
to this
(list "DIMLINEAR" "I_ANNO-DIMS" 14 "continuous" :vlax-true)
« Reply #18 on: January 24, 2008, 04:53:58 PM »
In fact just use this:
« Last Edit: April 25, 2008, 04:47:50 PM by CAB »
ELOQUINTET
« Reply #19 on: January 24, 2008, 04:54:16 PM »
ok cab got it working now but have a few more questions. will i have to type in vlr_command everytime and the dot too? I don't want to have to do this to get it to work. How can I automate that process?
« Reply #20 on: January 24, 2008, 05:08:14 PM »
Now that is working try to put the (load "vlr_command")(c:vlr_command)  back into the ACADdoc.lsp.
This way it will be already running.
Verify you have the correct ACADdoc.lsp by typing (findfile "acaddoc.lsp") at the command line.
ELOQUINTET
« Reply #21 on: January 24, 2008, 05:20:10 PM »
when i put it into acaddoc.lsp and open a drawing i get this:
; error: LOAD failed: "vlr_command"
keep in mnd that i am now using architectural desktop 3.3
I need to downgrade my version in my sig  :cry:
rumor is we are getting 2007 in a couple of weeks
i sure as hell hope so i'm dyin over here
« Reply #22 on: January 24, 2008, 05:28:22 PM »
Copy the lisp one more time, make sure you save it to the acad path.
Verifying the location of the file with (findfile "vlr_command.lsp")
Add this to the ACADdoc.lsp  (load "vlr_command")(c:vlr_command)(setq *user* "DAN")
The *user* gives the option for varying layer specs. You may not need that but put it in.
ELOQUINTET
« Reply #23 on: January 25, 2008, 09:41:12 AM »
cab i did like you said but when i open autocad i get this message:
then when i type findfile i get this message:
Command: (findfile "vlr_command.lsp")
nil
if i type vlr_command next and dimension it works, what's going on?
T
« Reply #24 on: January 25, 2008, 10:07:39 AM »
Beats me. :-(
can you use (findfile to loacte another file in that folder? If not maybe it's not an active path.
ELOQUINTET
« Reply #25 on: January 25, 2008, 10:37:18 AM »
i did a search on my computer for vlr_command.lsp and it found nothing. also i did a search for acaddoc.lsp which resides in the same folder as acad.lsp and it finds it?
Command: (findfile "acaddoc.lsp")
"C:\\ADT Support\\Support Files\\acaddoc.lsp"
« Reply #26 on: January 25, 2008, 10:44:54 AM »
You need to save the lisp code I posted as "vlr_command.lsp" in the support folder or in a folder in the ACAD path.
« Reply #27 on: January 25, 2008, 01:27:34 PM »
OK, Dan I modified the code again.
I added an Off feature, entering VLR_COMMAND_OFF  will turn the reactor off.
Entering VLR_COMMAND will activate or turn the reactor On.
setting *user* to DAN will produce the layers you want.
You may add additional layer choices, say for other vendors or other disciplines.
There is also a default Layer group in case *user* is nil or unrecognised.
I haven't done any reactor code to speak of so if anyone see a problem please let me know.
;  Modified by CAB 01.25.2008
;  Modified by CAB 04.25.2008 ; bug fix
; Sets the correct layer for certain commands.
; VLR_COMMAND.lsp courtesy Peter Jamtgaard 2003
; Vlr Command is a function that will switch the active layer in a drawing.
; The reactor checks the command that is starting and if it recognizes it
; it will switch to a specified layer. If the layer doesn't exist it will
; create it with the color, linetype, and plottable setting provided.
; To load and run this program add the lines (load "vlr_command")(c:vlr_command)
; to your acaddoc.lsp or another autoloading lisp routine.
; CAB added error trap for layer creator
;     added layer restore at command exit
;;    added code to test loaded status
;;    added code to turn reactors Off & back On again
;;    added code for different layers per user or task
;;    NOTE: set var *user* to use different layers per user
;;    Fixed bug in end & cancel command layer reset
(defun C:VLR_COMMAND ()
  ;; Load only once, if already loaded reactivate it if inactive
  (and *vlr-CWS (not (vlr-added-p *vlr-CWS)) (vlr-add *vlr-CWS))
  (and *vlr-CE (not (vlr-added-p *vlr-CE)) (vlr-add *vlr-CE))
  (and *vlr-CC (not (vlr-added-p *vlr-CC)) (vlr-add *vlr-CC))
  (or *vlr-CWS
     (setq *vlr-CWS (vlr-command-reactor nil '((:vlr-commandwillstart . StartCommand)))))
  (or *vlr-CE
     (setq *vlr-CE (vlr-command-reactor nil '((:vlr-commandEnded . endCommand)))))
  (or *vlr-CC
     (setq *vlr-CC (vlr-command-reactor nil '((:vlr-commandCancelled . cancelCommand)))))
  (princ "\nLayer Reactor ON")
;;  Turn the reactors off
(defun C:VLR_COMMAND_OFF ()
  (and *vlr-CWS (vlr-added-p *vlr-CWS) (vlr-remove *vlr-CWS))
  (and *vlr-CE (vlr-added-p *vlr-CE) (vlr-remove *vlr-CE))
  (and *vlr-CC (vlr-added-p *vlr-CC) (vlr-remove *vlr-CC))
  (princ "\nLayer Reactor OFF")
(defun StartCommand (CALL CALLBACK / COMLAYLST)
  ;; Examples of Command vs Layer
  ;; List of corresponding      command layerName color linetype plottable
  ;; NOTE command names must be in Upper Case
    ((and *user*(= (type *user*) 'STR)(= (strcase *user*) "DAN"))
     (setq *LayUpdt* t
      LtFname nil)
     (setq COMLAYLST
            (list
              (list "DIMANGULAR" "I_ANNO-DIMS" 14 "continuous" :vlax-true)
              (list "DIMBASELINE" "I_ANNO-DIMS" 14 "continuous" :vlax-true)
              (list "DIMCENTER" "I_ANNO-DIMS" 14 "continuous" :vlax-true)
              (list "DIMCONTINUE" "I_ANNO-DIMS" 14 "continuous" :vlax-true)
              (list "DIMDIAMETER" "I_ANNO-DIMS" 14 "continuous" :vlax-true)
              (list "DIMRADIUS" "I_ANNO-DIMS" 14 "continuous" :vlax-true)
              (list "QDIM" "I_ANNO-DIMS" 14 "continuous" :vlax-true)
              (list "LEADER" "I_ANNO-NOTE" 11 "continuous" :vlax-true)
              (list "QLEADER" "I_ANNO-NOTE" 11 "continuous" :vlax-true)
              (list "DTEXT" "I_ANNO-NOTE" 11 "continuous" :vlax-true)
              (list "MTEXT" "I_ANNO-NOTE" 11 "continuous" :vlax-true)
              (list "TEXT" "I_ANNO-NOTE" 11 "continuous" :vlax-true)
              (list "BHATCH" "I-FIXT-7" 8 "continuous" :vlax-true)
              (list "HATCH" "I-FIXT-7" 8 "continuous" :vlax-true)
              (list "MVIEW" "Z-VIEWPORT" 7 "continuous" :vlax-false)
                    ; Add your own command layer lists here....
    ((and *user*(= (type *user*) 'STR)(= (strcase *user*) "Future Use"))
     (setq COMLAYLST '())
    ((and *usermode*(= (type *usermode*) 'STR)(= (strcase *usermode*) "CAB"))
     (setq *LayUpdt* nil
      LtFname "CAB2.lin")
     (setq COMLAYLST
            (list
              (list "DIMANGULAR"  "S-DIM" 5 "continuous" :vlax-true)
              (list "DIMBASELINE" "S-DIM" 5 "continuous" :vlax-true)
              (list "DIMCENTER"   "S-DIM" 5 "continuous" :vlax-true)
              (list "DIMCONTINUE" "S-DIM" 5 "continuous" :vlax-true)
              (list "DIMDIAMETER" "S-DIM" 5 "continuous" :vlax-true)
              (list "DIMLINEAR"   "S-DIM" 5 "continuous" :vlax-true)
              (list "DIMRADIUS"   "S-DIM" 5 "continuous" :vlax-true)
              (list "QDIM"        "S-DIM" 5 "continuous" :vlax-true)
              (list "LEADER"      "A-DIM" 5 "continuous" :vlax-true)
              (list "QLEADER"     "A-DIM" 5 "continuous" :vlax-true)
              (list "DTEXT"       "A-TEXT" 2 "continuous" :vlax-true)
              (list "MTEXT"       "A-TEXT" 2 "continuous" :vlax-true)
              (list "TEXT"        "A-TEXT" 2 "continuous" :vlax-true)
              (list "BHATCH"      "A-HATCH" 8 "continuous" :vlax-true)
              (list "HATCH"       "A-HATCH" 8 "continuous" :vlax-true)
              (list "POINT"       "A-POINTS" 7 "continuous" :vlax-true)
              (list "XLINE"       "A-CONST-LINES" 9 "continuous" :vlax-true)
              (list "MVIEW"       "A-VIEWPORT" 7 "continuous" :vlax-false)
              (list "TABLE"       "A-TABLE" 2 "continuous" :vlax-true)
              (list "REVCLOUD"    "A-REVCLOUD" 7 "continuous" :vlax-true)
    (t  ; default Layer Group
     (setq *LayUpdt* nil
      LtFname "CAB2.lin")
     (setq COMLAYLST
            (list
  ;; Find the Command
  (if (setq N (assoc (strcase (car CALLBACK)) COMLAYLST))
        ;;  save current layer, restore on exit of command
        (setq *Currentlayers* (cons (getvar "CLAYER") *Currentlayers*))
    ;;  make or update layer, then make current
    (if (make_layers (cadr N) (caddr N) (cadddr N) (car (cddddr N)))
      (vla-put-activelayer
        (vlax-ename->vla-object (tblobjname "LAYER" (cadr N)))
    ;;  flag current layer so it is NOT restored on exit of command
    (setq *Currentlayers* (cons nil *Currentlayers*))
;; Make layers using activeX
;; return t if sucessful else nil
(defun MAKE_LAYERS (LAY_NAM COLOR LTYPE PLOTL / LAYOBJ LAYSOBJ LTYPESOBJ fn result LtFname NewLay)
  (or *DOC* (setq *DOC* (vla-get-activedocument (vlax-get-acad-object))))
  (setq LAYSOBJ (vla-get-layers *DOC*))
  (if (tblobjname "layer" LAY_NAM) ; layer exist
    (setq LAYOBJ (vla-item LAYSOBJ LAY_NAM))
    (setq LAYOBJ (vl-catch-all-apply 'vla-add (list LAYSOBJ LAY_NAM))
    NewLay t)
  ;;(setq LAYOBJ (vla-item LAYSOBJ LAY_NAM))
  (if (vl-catch-all-error-p LAYOBJ)
    (not (print (vl-catch-all-error-message LAYOBJ)))
      (if (= (strcase (vla-get-name LAYOBJ)) (strcase (getvar "clayer")))
        (progn ; can not change current layer so make something else current
        ;;  what if "0" is frozen?
          ;;  need to thaw it then restore old layer, and freeze if thawed.
          (setvar "clayer" "0")
      (vla-put-lock LAYOBJ :vlax-false)
      (vla-put-layeron LAYOBJ :vlax-true)
      (vla-put-freeze LAYOBJ :vlax-false)
      (if (or NewLay *LayUpdt*)  ; ok to update layer color, plot, LineType
          (if (tblobjname "ltype" LTYPE)
            (vla-put-linetype LAYOBJ LTYPE)
              (setq LTYPESOBJ (vla-get-linetypes *DOC*))
              (if (and LtFname (/= LtFname "")
                     (setq fn (findfile LtFname)))
                 (vl-catch-all-apply '(lambda ( ) (vla-load LTYPESOBJ LTYPE fn)
                                              (setq result t)  ; true only if load susceded
              (if (and (not result)
                    (setq fn (findfile (if (zerop (getvar "measurement")) "acad.lin" "acadiso.lin"))))
              (vlax-release-object LTYPESOBJ)
              (and result (vla-put-linetype LAYOBJ LTYPE))
          (vla-put-color LAYOBJ COLOR)
          (vla-put-plottable LAYOBJ PLOTL)
      ) ; end if (or NewLay *LayUpdt*)
      t
;;  Restore curent layer
(defun endCommand (CALL CALLBACK)
  (if *Currentlayers*
    (if (car *Currentlayers*)
        (vla-put-lock
          (vla-item
            (vla-get-layers
          :vlax-false
        (setvar "CLAYER" (car *Currentlayers*))
  (setq *Currentlayers* (cdr *Currentlayers*))
(defun cancelCommand (CALL CALLBACK)
  (if *Currentlayers*
        (vla-put-lock
          (vla-item
            (vla-get-layers
          :vlax-false
;------------------<The End>--------------------------
« Last Edit: April 25, 2008, 04:46:23 PM by CAB »
ELOQUINTET
« Reply #28 on: January 28, 2008, 05:14:56 PM »
thanks cab maybe the additional functionality you added will be useful later but for now only i will be using this. i am not that accustomed to using layers and the documensts i am creating need to stick to standard layers. i just started here and don't want to ruffle too many feathers with automating things. Then I'd have to explain alot of things I'm not ready to at this time but thanks for all of your help with this it saves me alot of time.
« Reply #29 on: January 28, 2008, 06:36:11 PM »
You're welcome.
I noticed there were some commands missing so here is my updated list with my layers.
     (setq CmdLayerList
            (list
              ;(list "3DFACE"
              ;(list "ARC"        "Arc" 5 "" :vlax-true)
              (list "BHATCH"      "A-HATCH" 8 "" :vlax-true)
              ;(list "BOX"
              (list "CIRCLE"      "Circle" 5 "" :vlax-true)
              ;(list "CONE"
              ;(list "CYLINDER"
              (list "DIMALIGNED"  "S-DIM"  5 "" :vlax-true)
              (list "DIMANGULAR"  "S-DIM"  5 "" :vlax-true)
              (list "DIMBASELINE" "S-DIM"  5 "" :vlax-true)
              (list "DIMCENTER"   "S-DIM"  5 "" :vlax-true)
              (list "DIMCONTINUE" "S-DIM"  5 "" :vlax-true)
              (list "DIMDIAMETER" "S-DIM"  5 "" :vlax-true)
              (list "DIMLINEAR"   "S-DIM"  5 "" :vlax-true)
              (list "DIMORDINATE" "S-DIM"  5 "" :vlax-true)
              (list "DIMRADIUS"   "S-DIM"  5 "" :vlax-true)
              (list "DONUT"       "Pline"  5 "" :vlax-true)
              (list "DTEXT"       "A-TEXT" 2 "" :vlax-true)
              (list "ELLIPSE"     "Ellipse" 5 "" :vlax-true)
              (list "HATCH"       "A-HATCH" 8 "" :vlax-true)
              (list "LEADER"      "A-DIM" 5 "" :vlax-true)
              (list "LINE"        "Line" 5 "" :vlax-true)
              (list "MTEXT"       "A-TEXT" 2 "" :vlax-true)
              (list "MVIEW"       "A-VIEWPORT" 7 "" :vlax-false)
              ;(list "OBLIQUE"
              (list "PLINE"       "Pline" 5 "" :vlax-true)
              (list "POINT"       "A-POINTS" 7 "" :vlax-true)
              (list "POLYGON"     "Pline"  5 "" :vlax-true)
              (list "QDIM"        "S-DIM"  5 "" :vlax-true)
              (list "QLEADER"     "A-DIM"  5 "" :vlax-true)
              (list "RAY"         "Ray"    5 "" :vlax-true)
              (list "RECTANG"     "Pline"  5 "" :vlax-true)
              ;(list "REGION"
              (list "REVCLOUD"    "A-REVCLOUD" 7 "" :vlax-true)
              ;(list "SOLID"
              ;(list "SPHERE"
              (list "SPLINE"      "Spline"  7 "" :vlax-true)
              (list "TABLE"       "A-TABLE" 2 "" :vlax-true)
              (list "TEXT"        "A-TEXT"  2 "" :vlax-true)
              ;(list "TOLERANCE"
              ;(list "TORUS"
              ;(list "WEDGE"
              (list "XLINE"       "A-CONST-LINES" 9 "" :vlax-true)
              ;; Add your own command layer lists here....
