Author Topic: User Arrowhead in Label Style?  (Read 1518 times)
dfarris75
« on: January 21, 2008, 10:16:23 AM »
Uhm. Is there a way to set a user arrowhead in your label styles? It doesn't show in the list.
sinc
Re: User Arrowhead in Label Style?
« Reply #1 on: January 21, 2008, 10:45:09 AM »
If there is, it is very well-hidden.
You may be able to "co-opt" one of the built-in ones...  As soon as you select one of the other options, the block used for that option is added to your block table.  So then you can go in and BEDIT it to look the way you want.  At least, I think this will work - haven't actually tried it.
