Author Topic: Arc Radius  (Read 6130 times)
jbuzbee
Arc Radius
« on: January 17, 2008, 10:37:36 AM »
Well, I searched and didn't see anything.
What I'm attempting is to creat a dynamic block for theater seating.  I need to adjust the length of the arc, the radius of the arc, and then array the seats along the arc.  Any thoughts?
Thanks.
James Buzbee
Windows 8
Guest
Re: Arc Radius
« Reply #1 on: January 17, 2008, 10:56:21 AM »
Oy!  Sounds like a job for the MEASURE command instead.
Re: Arc Radius
« Reply #2 on: January 17, 2008, 11:04:32 AM »
this suggests that you constrain the stretch of the arc to a single seat unit spacing, and then use a polar array
jbuzbee
Re: Arc Radius
« Reply #3 on: January 17, 2008, 12:39:31 PM »
Hmm.  There is no Polar Array action . . .  :x
James Buzbee
Windows 8
Re: Arc Radius
« Reply #4 on: January 17, 2008, 02:25:35 PM »
Polar
Adds a polar parameter to the current dynamic block definition. Defines custom distance and angle properties for the block reference. You associate a move, scale, stretch, polar stretch, or array action with a polar parameter.
Specify base point or [Name/Label/Chain/Description/Palette/Value set]: Specify a start point for the parameter or enter an option
Specify endpoint: Specify an endpoint for the parameter
Specify label location: Specify a location for the parameter label
Enter number of grips [0/1/2] <2>: Specify the number of grips for the parameter
If you specify one grip for the parameter, the grip is added to the endpoint of the parameter.
jbuzbee
Re: Arc Radius
« Reply #5 on: January 17, 2008, 02:28:57 PM »
There is NO Polar ACTION.  I see the parameter . . ..
James Buzbee
Windows 8
Re: Arc Radius
« Reply #6 on: January 17, 2008, 02:45:53 PM »
it's a parameter set
jbuzbee
Re: Arc Radius
« Reply #7 on: January 17, 2008, 04:01:28 PM »
Yes I know - but it isn't a Polar Array: it's a Polar Stretch parameter with a Rectangular Array action.  There is NO Polar Array action.
Thanks for the help anyway.
Matt: I took your suggestion, only changed it to divide because I wanted it too fill the arc.  Here's a quick and dirty routine:
(defun c:MakeTheaterSeats  (/ ent obj len num)
  (setq ent (car (entsel "\nSelect the arc: ")))
  (if ent
    (progn (setq obj (vlax-ename->vla-object ent)
                 len (vla-get-ArcLength obj))
           (setq num (fix (/ len 22.0)))
           (command "divide" ent "block" "seata" "Y" num))))
(defun c:qq()(c:MakeTheaterSeats))
James Buzbee
Windows 8
whdjr
Re: Arc Radius
« Reply #8 on: January 18, 2008, 08:26:55 AM »
You can do this with the traditional Array command.  Use the Polar Array option, give it a length, and then tell it how many seats to put in.  It will even allow you to rotate the seat to the center of the arc if you want it to.
