Author Topic: slice solid with polyline ?  (Read 2732 times)
dussla
« on: January 16, 2008, 07:33:54 AM »
hello
today , i will have to ask a favor of you ?
all friend  . always  thank you ~
i worked work 3d solid .
in my process , i have  to  slice for  my wanted  object .
1 .autocad slice function is limited   , there is  only  plane slice
2. with polyline slice , i have to work  4-5 process (  polyline -> closed polyline -> make solid -> subtrace ....)
   i have to work many process . also i have many object ~ . some bored
i thought   profile line slice for solid
if you see attached image , you can understand my process
is that routine is possible ?
dussla
Re: slice solid with polyline ?
« Reply #1 on: January 18, 2008, 06:45:48 AM »
hello , friend  , i found  some good idea
can you see my attatched image file ?
MickD
« Reply #2 on: January 18, 2008, 04:23:41 PM »
Yes, that would be the only way, you need to use 'closed' polylines, extrude them and then subtract them from the solid.
have fun :)
- John Carmack
- J.R.R. Tolkien
dussla
« Reply #3 on: January 19, 2008, 05:24:45 AM »
thank you
but still , it is difficult to me  to write   difficult code
i am beginner ~
i don;t know well about  vector  point  about  start and end point
so i can't make colsed polyline~
sorry for my many ask ~
pls help me ~
