Author Topic: how to find a selected entity is Xref or not  (Read 2716 times)
sub
« on: August 11, 2004, 02:32:14 AM »
« Reply #1 on: August 11, 2004, 03:07:33 AM »
This should get you started ..
  (vlax-for blk (vla-get-blocks doc)
    (if (= (vla-get-isxref blk) :vlax-false)
     < snip >
daron
« Reply #2 on: August 11, 2004, 08:22:52 AM »
Sub, if you're not familiar with ActiveX, you might also look in the help file under DXF reference. That should help you find the dxf codes to look for in an entity or block table selection.
