Author Topic: AcRxDynamicLinker failed to load...  (Read 6576 times)
highflyingbird
  • Later equals never.
« on: January 14, 2008, 03:44:07 AM »
It has been compiled,but It's failed to load.
Command:ap
APPLOAD AcRxDynamicLinker failed to load “....\debug\step001.arx”.....
C:\Program Files\AutoCAD 2006\acad.exe can't load the step001.arx file。
I'm  using  ObjectARX 2006+Visual Studio 2005+autoCAD 2006.
I am a bilingualist,Chinese and Chinglish.
MickD
  • (x-in)->[process]->(y-out)
Re: AcRxDynamicLinker failed to load...
« Reply #1 on: January 14, 2008, 03:49:26 AM »
Command:ap
You need VS2002 for 2004-6 acad arx development (it's a binary compatabilty thing), also make sure you are using the arx sdk for 2006.
Lao Tzu: “To attain knowledge, add things
every day; to obtain wisdom, remove things every day.”
highflyingbird
« Reply #2 on: January 15, 2008, 06:14:25 AM »
Thanks for your reply.
But ...."VS2005+arx2006+autocad2006" is impossible?
It's Alive!
  • BricsCAD
  • AKA Daniel
« Reply #3 on: January 15, 2008, 06:26:13 AM »
That’s correct you *need* to have VS2002 to compile for Acad 04-06.
*IF* you have both visual studio 2002 & 2005 installed on your computer, you can use Owen’s build utility.
http://www.manusoft.com/Resources/ARXTips/Index.stm#VC8ForARX2000
MickD
« Reply #4 on: January 16, 2008, 11:41:48 PM »
Could someone load this and see if it works for me please, it's for ac2007, the test command is TEST and it justs prints hello to the command prompt.
I'm just having a bit of trouble getting it to load on another machine, it loads fine on mine??
thanks.
It's Alive!
  • BricsCAD
  • AKA Daniel
« Reply #5 on: January 16, 2008, 11:51:36 PM »
works here,
Hello from test
PS, did you install VS2005 SP1 ?
MickD
« Reply #6 on: January 16, 2008, 11:57:59 PM »
Not yet, it's a huge download, looks like I better though :roll:
thanks Dan.
MickD
« Reply #7 on: January 17, 2008, 12:00:18 AM »
Here's what I have -
It's Alive!
  • BricsCAD
  • AKA Daniel
« Reply #8 on: January 17, 2008, 12:05:55 AM »
It appears that you do have the SP1, which is the cause of the problem.
Turn off generate manifest in your project properties->linker->manifest file and see if this helps
It's Alive!
  • BricsCAD
  • AKA Daniel
« Reply #9 on: January 17, 2008, 12:15:28 AM »
Also right click on the project, select tool build order and uncheck the manifest tool
MickD
« Reply #10 on: January 17, 2008, 12:16:51 AM »
You da man Daniel!
Thanks, problem solved.
PS, I'll do the other too, it worked ok ofter turning off the manifest.
cheers,
Mick.
