Is there any way to get the center of a selection set of entities?(lines, text, plines, blocks)
(defun c:zss (/ count ent ll ll-ent ll-ss ur ur-ent ur-ss llx lly urx ury) (if (or (setq zz_ss (cadr (ssgetfirst))) (setq zz_ss (ssget))) (progn (setq count -1) (while (< (setq count (1+ count))(sslength zz_ss)) (setq ent (vlax-ename->vla-object (ssname zz_ss count))) (vla-getboundingbox ent 'll 'ur) (vla-highlight ent :vlax-true) (setq ll-ent (vlax-safearray->list ll) ur-ent (vlax-safearray->list ur)) (if (not ll-ss) (setq ll-ss ll-ent ur-ss ur-ent) (progn (if (< (car ll-ent)(car ll-ss)) (if (< (cadr ll-ent)(cadr ll-ss)) (setq ll-ss ll-ent) (setq ll-ss (list (car ll-ent) (cadr ll-ss)) ) ) (if (< (cadr ll-ent)(cadr ll-ss)) (setq ll-ss (list (car ll-ss) (cadr ll-ent)) ) ) ) (if (> (car ur-ent)(car ur-ss)) (if (> (cadr ur-ent)(cadr ur-ss)) (setq ur-ss ur-ent) (setq ur-ss (list (car ur-ent) (cadr ur-ss)) ) ) (if (> (cadr ur-ent)(cadr ur-ss)) (setq ur-ss (list (car ur-ss) (cadr ur-ent)) ) );if );if );progn );if );while (setq ll (vlax-3d-point ll-ss) ur (vlax-3d-point ur-ss) llx (car ll-ss) lly (cadr ll-ss) urx (car ur-ss) ury (cadr ur-ss) );setq (vla-zoomwindow (vlax-get-acad-object) ll ur) (vla-zoomscaled (vlax-get-acad-object) 0.9 acZoomScaledRelative) (grvecs (list -7 (list llx lly)(list llx ury) (list llx ury)(list urx ury) (list urx ury)(list urx lly) (list urx lly)(list llx lly) ) ) );progn );if (princ) );defun
;| Routine to create a selection set and zoom to the extents of the ss.Jeff Mishler Jun 2003|;(defun zss (/ count ent ll ll-ent ll-ss ss ur ur-ent ur-ss llx lly urx ury) (if (setq ss (ssget)) (progn (setq count -1) (while (< (setq count (1+ count)) (sslength ss)) (setq ent (vlax-ename->vla-object (ssname ss count))) (vla-getboundingbox ent 'll 'ur) (setq ll-ent (vlax-safearray->list ll) ur-ent (vlax-safearray->list ur) ) (if (not ll-ss) (setq ll-ss ll-ent ur-ss ur-ent ) (progn (if (< (car ll-ent) (car ll-ss)) (if (< (cadr ll-ent) (cadr ll-ss)) (setq ll-ss ll-ent) (setq ll-ss (list (car ll-ent) (cadr ll-ss) ) ) ) (if (< (cadr ll-ent) (cadr ll-ss)) (setq ll-ss (list (car ll-ss) (cadr ll-ent) ) ) ) ) (if (> (car ur-ent) (car ur-ss)) (if (> (cadr ur-ent) (cadr ur-ss)) (setq ur-ss ur-ent) (setq ur-ss (list (car ur-ent) (cadr ur-ss) ) ) ) (if (> (cadr ur-ent) (cadr ur-ss)) (setq ur-ss (list (car ur-ss) (cadr ur-ent) ) ) ) ;if ) ;if ) ;progn ) ;if ) ;while (setq ll (vlax-3d-point ll-ss) ur (vlax-3d-point ur-ss) llx (car ll-ss) lly (cadr ll-ss) urx (car ur-ss) ury (cadr ur-ss) ) ;setq (vla-zoomwindow (vlax-get-acad-object) ll ur) (grvecs (list -1 (list llx lly) (list llx ury) (list llx ury) (list urx ury) (list urx ury) (list urx lly) (list urx lly) (list llx lly) ) ) ) ;progn ) ;if (princ)) ;defun(defun c:zsscall() (zss) )
