Author Topic: Come one come all - Bind my xrefs  (Read 17804 times)
David Hall
  • Automatic Duh Generator
Re: Come one come all - Bind my xrefs
« Reply #45 on: January 11, 2008, 03:49:41 PM »
yea, I know I should as well.  KB and I have had that discussion, and I just never go there.
David Hall
« Reply #46 on: January 11, 2008, 04:01:11 PM »
OK, here is version 2 which works.  Now to try and figure out how to do it without opening the dwg in the editor
        [CommandMethod("BindTep2")]
        static public void BindTitleBlocks2()
            Document Doc = AcadApp.DocumentManager.MdiActiveDocument;
            Database Db = Doc.Database;
            Editor Ed = Doc.Editor;
            XrefGraph XG = Db.GetHostDwgXrefGraph(true);
            if (XG.IsEmpty || XG.NumNodes == 1)
                return;
            using (Transaction Trans = Doc.TransactionManager.StartTransaction())
                BlockTable BT = Trans.GetObject(Db.BlockTableId, OpenMode.ForWrite) as BlockTable;
                for (int i = 0; i < XG.NumNodes; i++)
                    XrefGraphNode XGN = XG.GetXrefNode(i) as XrefGraphNode;
                    if (string.Compare(XGN.Name, "TEP", true).Equals(0) ||
                        string.Compare(XGN.Name, "UES", true).Equals(0) ||
                        string.Compare(XGN.Name, "VTEP", true).Equals(0) ||
                        string.Compare(XGN.Name, "VUES", true).Equals(0))
                        BlockTableRecord BTR = Trans.GetObject(XGN.BlockTableRecordId, OpenMode.ForWrite, false) as BlockTableRecord;
                        ObjectIdCollection BlkRefCol = BTR.GetBlockReferenceIds(true, true);
                        if (BlkRefCol.Count > 0)
                            ObjectIdCollection OIC = new ObjectIdCollection();
                            OIC.Add(BTR.Id);
                            Db.BindXrefs(OIC, true);
                        else
                            Db.DetachXref(BTR.Id);
                Trans.Commit();
            Db.SaveAs(Doc.Name , DwgVersion.Current);
« Last Edit: January 11, 2008, 04:39:35 PM by CmdrDuh »
« Reply #47 on: January 11, 2008, 04:07:18 PM »
I understand.  If you can find what you need here, no need to really go over there.
Code wise, it looks good to me.  Let see what the masters think when they log on.
David Hall
« Reply #48 on: January 11, 2008, 04:44:55 PM »
I read the thread where Glenn opened files from a dialog box, but I have never done that either.  Any ideas?  I did a search on batching, but couldn't find anything that looked close enough to make sure I was looking at the correct thing
« Reply #49 on: January 11, 2008, 05:01:55 PM »
Sure.  Here is some snippets of code that I use to open multiply drawing databases.
Autodesk.AutoCAD.Windows.OpenFileDialog OpenDia =
new Autodesk.AutoCAD.Windows.OpenFileDialog("Select drawings to update title blocks.",
"dwg",
Autodesk.AutoCAD.Windows.OpenFileDialog.OpenFileDialogFlags.AllowMultiple
if (OpenDia.ShowDialog() != DialogResult.OK) return;
foreach (string Path in OpenDia.GetFilenames()) {
try {
using (Database db = new Database(false, true)) {
db.ReadDwgFile (Path, System.IO.FileShare.Read, true, null);
[color=red]                       // Don't need the red if not updating attributes or text
if (db != HostApplicationServices.WorkingDatabase)
HostApplicationServices.WorkingDatabase = db;[/color]
GetTitleBlock(db);
//MessageBox.Show(Doc.Name);
HostApplicationServices.WorkingDatabase = Doc.Database;
db.RetainOriginalThumbnailBitmap = true;
db.SaveAs (Path, DwgVersion.Current);
catch (System.Exception ex) {
MessageBox.Show("Error in drawing: " + Path + "\n\n" + ex.Message);
David Hall
« Reply #50 on: January 11, 2008, 05:04:29 PM »
Thanks Tim, that points me in the right direction.
« Reply #51 on: January 11, 2008, 05:05:32 PM »
You're welcome.  Let us know if you need any explanation.
David Hall
« Reply #52 on: January 11, 2008, 05:20:16 PM »
Oh I need LOTS of explanation, I'm just trying to struggle through it w/o asking you to throw me a fish
