Author Topic: Groups in vba  (Read 8646 times)
MickD
Groups in vba
« on: January 08, 2008, 09:53:31 PM »
Does anyone have any examples of using groups in vba? This is a bit of a mystery, I can create and add items no problem but to select them on screen is another matter, I'd imagine you would have the same issues with other collections also.
The help doc's are very thin on this, any tidbits at all will help. In the meantime I'll keep searching for other collection examples.
Thanks,
Mick.
- John Carmack
- J.R.R. Tolkien
Re: Groups in vba
« Reply #1 on: January 08, 2008, 11:04:22 PM »
Don't have vb group code, would lisp code from an old guy be of any (translation) use?
cadanalyst@gmail.com • http://cadanalyst.slack.com • http://linkedin.com/in/cadanalyst
MickD
Re: Groups in vba
« Reply #2 on: January 08, 2008, 11:41:06 PM »
Thanks Michael but I can barely grasp the basics of lisp although now I wish I had stuck at it when I tried years ago, perhaps I should be heading that way??
I have some C# code that does what I need that I can either update or convert but I'm not sure that the methods I need are exposed to vba though. If I need to go that way I'll write it in arx.
I'm having a bit of a dilemma in that I want to avoid .net so I can use the code in icad as well. The goal would be to port it to arx/drx in C eventually once I get the 'tools' side of things worked out, this way I can 'invoke' it from nearly any language to be used for scripting/automation.
This is the reason I'm using vba, it's easy to write, fast, easy to debug and fix on the fly, lisp is probably just as good if you know it and I'm not sure I have the patience/time to learn it all though it's probably better suited to the task.  :roll:
- John Carmack
- J.R.R. Tolkien
Bryco
Re: Groups in vba
« Reply #3 on: January 09, 2008, 01:46:41 AM »
I gave up on them Mick, as I prefer blocks anyway.
If they were an entity it would be easier.
I think making a Group class would make them fairly easy to use in vba,once you have the collection of its entities you can move them, select them etc
Re: Groups in vba
« Reply #4 on: January 09, 2008, 03:09:48 AM »
Mick, Have a play
this is the only way I know of ...
Sub GrpNameTest()
   Dim acadUtility As Object
   Set acadUtility = ThisDrawing.Utility
    ' Select an entity
   Dim returnObj As Object
   Dim basePnt As Variant
   ThisDrawing.Utility.GetEntity returnObj, basePnt, "Select an object: "
   ' Get the groups
   Dim acadGroups As Object
   Dim group As Object
   Dim groupEntity As Object
   Dim isInGroup As Boolean
   Dim length As Integer
   Dim i As Integer
   Set acadGroups = ThisDrawing.Groups
   isInGroup = False
   ' Iterate all available groups
   For Each group In acadGroups
      length = group.Count
          ' Get every entity from a group
       For i = 0 To length - 1
          Set groupEntity = group.Item(i)
          If groupEntity.Handle = returnObj.Handle Then
             MsgBox "Entity is from Group " + group.Name
             isInGroup = True
          End If
       Next i
    Next
    If  isInGroup = False Then
       MsgBox "Entity is in not in a group."
    End If
 End Sub
« Last Edit: January 09, 2008, 03:14:35 AM by Kerry Brown »
MickD
Re: Groups in vba
« Reply #5 on: January 09, 2008, 04:39:48 AM »
Thanks Kerry, looks good and pretty much what I was afraid of - looping through the whole collection. After thinking about it, from memory I had to do this in C# too (I'm pretty sure I used Alex's code snippet for that one).
I guess a short cut would be to store the group's name on the entity and retreive it by name from the collection, this will do for now though.
I'll give it a spin tomorrow and see how it goes and I'll post some group routines when done, thanks again.
- John Carmack
- J.R.R. Tolkien
It's Alive!
  • Retired
  • AKA Daniel
Re: Groups in vba
« Reply #6 on: January 09, 2008, 08:55:56 AM »
Hey Mick, Sorry to highjack your thread... I got pretty far in making .NET wrappers for SDS. Far enough to do this.
   //intellicad COM
    [CommandMethod("Test")]
    public static void Test1()
      try
        IntelliCAD.Application application =
          (IntelliCAD.Application)Marshal.GetActiveObject("Icad.Application");
        IntelliCAD.Document document = application.ActiveDocument;
        IntelliCAD.ModelSpace modelspace = document.ModelSpace;
        IntelliCAD.Library library = application.Library;
        IntelliCAD.Point point1 = library.CreatePoint(0,0,0);
        IntelliCAD.Point point2 = library.CreatePoint(100,100,0);
        IntelliCAD.Line line = modelspace.AddLine(point1, point2);
        line.Update();
        Marshal.ReleaseComObject(application);
      catch (SystemException e)
        DWM.Cad.RuntimeServices.Utilities.WriteMessage(e.Message);
    //through the lisp engine
    [CommandMethod("TestLine1")]
    public static void Testline1()
      using (Line myLine = new Line())
        myLine.Layer = "0";
        myLine.StartPoint = new Point3D(0, 0, 0);
        myLine.EndPoint = new Point3D(100, 100, 0);
        myLine.Update();
While this built for SDS, We/I may be able to put something together for Bricscad/Drx.
I was holding off until the ITC release it’s version of the SDK, but it’s killing me to see someone with your C/C++ talents having to use VBA.  :evil:
Anyway, it might be possible to access DRX,SDS and COM all from C#..
Cathy
Re: Groups in vba
« Reply #7 on: January 09, 2008, 01:17:07 PM »
'...snip
    'Group everything together for the move
    Set objGroup = ThisDrawing.Groups.Add("textbox")
    objGroup.AppendItems objEnts
    ThisDrawing.SendCommand ("-group rename textbox textbox" & vbCr)
    ThisDrawing.SendCommand "move g textbox " & Str(dBoxVert(0)) & "," & LTrim(Str(dBoxVert(1)) & vbCr)
I found this.  I think the rename was some kind of hack to get the group recognized in Acad.
MickD
Re: Groups in vba
« Reply #8 on: January 09, 2008, 05:15:50 PM »
Thanks Cathy, something else to look at, you're right, the rename thing is a bit 'odd'.
It's kinda hard to explain, essentially I want to be COM, .net et al independent, I also want to build my own geometry routines and methods for modifying objects, mainly 3d solids independent of any particular platform.
This is possible, once I have what I need worked out I'll code it in C and I'll only need thin wrappers to use the lib in nearly any language that can call a C method from a dll.
Bricscad are working very hard at developing a true native linux version and I don't think COM and .net will be a priority for quite a while so I want to remain 'neutral' if you like.
The hard part is working out what I need, I've been down this road too many times in C/C++/C# and I have found I have wasted quite a lot of time in development of what I need only to find it won't suit the end goal and it gets re-written or tossed. This is where vba comes in (oh how I wish acad had Python :) ), I can throw something together, run and debug it on the fly and then attack another problem. If I have to throw something out it hasn't cost me near as much time which I don't have a lot of anyway, it's all proof of concept at this stage.
- John Carmack
- J.R.R. Tolkien
MickD
Re: Groups in vba
« Reply #9 on: January 09, 2008, 09:42:49 PM »
Here's what I come up with, it's a modified version of the code Kerry posted, it just loops through the groups and if it finds it, it exits and returns the group to add to or whatever. I was going to post some code for creating etc. but it's pretty trivial to do on the fly.
Any improvements/comments welcome.
Public Sub GroupFromEnt(group As AcadGroup, strprompt As String)
    ' Select an entity
   ThisDrawing.Utility.GetEntity returnObj, basePnt, strprompt
   ' Get the groups
   Dim acadGroups As acadGroups
   Dim groupEntity As AcadEntity
   Dim i As Integer
   Set acadGroups = ThisDrawing.groups
   isInGroup = False
             ThisDrawing.Utility.Prompt "Entity is from Group " + group.Name
             isInGroup = True
             'let's go, we got it:
             Exit Sub
          End If
       Next i
    Next
       ThisDrawing.Utility.Prompt "Entity is in not in a group."
    End If
 End Sub
- John Carmack
- J.R.R. Tolkien
Bryco
Re: Groups in vba
« Reply #10 on: January 09, 2008, 10:35:57 PM »
Other than adding xdata that seems as good as you'll need mate. I looked at using vbassoc to find the reactor attached to each ent and it does work but I never could figure out a lisp entity name comparison to vba objectid.
Anyway it has kludge.
If you could add the xdata as you make the groups, I think you could use a selection set.
MickD
Re: Groups in vba
« Reply #11 on: January 09, 2008, 10:44:31 PM »
Yep, that's what I figured too, it will be interesting to see how the speed is once I get a fair few groups in the db though. Once I get the main bits sorted out I will be looking at data storage, mainly an ecs for length extraction and things like group name's etc to keep track of assemblies and parts, I may look at storing these outside the db though...I'll have to think about that a bit.
- John Carmack
- J.R.R. Tolkien
Bryco
Re: Groups in vba
« Reply #12 on: January 10, 2008, 12:07:20 AM »
I'ld still like to hear your argument for groups over blocks.
MickD
Re: Groups in vba
« Reply #13 on: January 10, 2008, 01:53:31 AM »
Well, with structural steel we start with a simple beam (the main shaft which will most likely be the group's 'parent'), as we model we need to add a cleat here or another part there as the model develops, we may also need to drill or cut the parts/main member along the way. If I used blocks I'd have to explode them to carry out modifications and re-create as far as I can see it, I'm open to new solutions though, a block would be better for a lot of reasons, att's being just one.
A group also gives you the ability to move parts as well, you can move the whole group at once by turning groups on or move a single part of the group after turning groups off (ctrl+shift+a or something, it's a reflex action these days ;) )
At it's simplest, a group is just a selection set and that's fine, you can add and delete objects as you like, I'd just use the acad group dlg only it's very inadequate from a user's point of view, the groups list box is non sizable and only has 3/4 groups visible at once just for starters.
- John Carmack
- J.R.R. Tolkien
MickD
Re: Groups in vba
« Reply #14 on: January 10, 2008, 02:17:45 AM »
Actually Bryco, you just gave me an idea, before when I used groups I had to deepclone them and create another group in a new drawing or the drawing I was exporting to to keep the group and it's name intact, creating blocks out of the groups once the model is done would solve quite a few issues here, both for updates and export/import into other drg's (I could just use design centre for this too).
- John Carmack
- J.R.R. Tolkien
