Author Topic: Insertion Point Cycling  (Read 4285 times)
Guest
« on: January 08, 2008, 10:52:20 AM »
I've got a number of blocks in which I'd like add "multiple insertion points" and I'd like to use the Point, but I can't find a way to "lock" the point from moving around.  *CAN* the point be "locked" into place?  I just want to use the point as an insertion point for the block - nothing else.
Kate M
Re: Insertion Point Cycling
« Reply #1 on: January 08, 2008, 12:43:24 PM »
Two options:
1. If you turn off the grip display, can you still use it for inserting? Haven't tried it, but it might work.
2. Add a move action to each point that includes everything in the block. Then they act like regular ol' insertion points.
whdjr
« Reply #2 on: January 08, 2008, 12:46:17 PM »
Two options:
1.  Would be interesting if it worked that way.
2.  I would go this route.
whdjr
« Reply #3 on: January 08, 2008, 12:51:04 PM »
Ok, I just tried turning off the grip display and the base point no longer works.  So it looks like option 2 is your best bet for now.
