Author Topic: create Layers, is there a better way  (Read 23268 times)
David Hall
  • Automatic Duh Generator
Re: create Layers, is there a better way
« Reply #45 on: January 15, 2008, 04:12:14 PM »
Glenn, do you have an example of reading or writing XML?
David Hall
« Reply #46 on: January 15, 2008, 04:12:56 PM »
Kerry thanks.  I'll start looking into that.  MSDN for info?
« Reply #47 on: January 15, 2008, 04:30:51 PM »
a simplistic starter
http://www.theswamp.org/index.php?topic=20033.0
.. and yes, MSDN !
there are heaps of articles and samples.
Glenn R
« Reply #48 on: January 15, 2008, 04:58:28 PM »
Apart from Kerry's excellent link, you might try searching for XmlReader and XmlWriter, until you get accustomed to serialising your classes to and from XML.
« Last Edit: January 15, 2008, 05:02:22 PM by Glenn R »
David Hall
« Reply #49 on: January 15, 2008, 05:02:08 PM »
I'm reading Kerry's post now.  Thanks guys
« Reply #50 on: January 16, 2008, 08:34:30 PM »
David, have a play ...
don't let the using statements scare you, they are not ALL needed :-)
// CodeHimBelongaKwb ©  Dec 2008
using System;
using System.Collections;
using System.Text;
using System.Data;
using System.Linq;
using System.Runtime.InteropServices;
using AcAp = Autodesk.AutoCAD.ApplicationServices;
using AcDb = Autodesk.AutoCAD.DatabaseServices;
using AcEd = Autodesk.AutoCAD.EditorInput;
using AcGe = Autodesk.AutoCAD.Geometry;
using AcRx = Autodesk.AutoCAD.Runtime;
using AcCm = Autodesk.AutoCAD.Colors;
using AcGi = Autodesk.AutoCAD.GraphicsInterface;
using AcLy = Autodesk.AutoCAD.LayerManager;
using AcPl = Autodesk.AutoCAD.PlottingServices;
using AcUi = Autodesk.AutoCAD.Windows;
using WinForms = System.Windows.Forms;
[assembly: AcRx.CommandClass(typeof(LayersFromXML.TestCommands))]
namespace LayersFromXML
    public class TestCommands
        [AcRx.CommandMethod("Cmd2")]
        static public void test2()
            Util.GetLayerXMLData();
    public class Util
        public static void GetLayerXMLData()
            Editor ed = AcadApp.DocumentManager.MdiActiveDocument.Editor;
            PromptStringOptions ops = new PromptStringOptions("\nLayer name: ");
            ops.AllowSpaces = true;
            PromptResult res = ed.GetString(ops);
            if (!(res.Status == PromptStatus.OK && res.StringResult != string.Empty))
                return;
            string layerName = res.StringResult;
            DataSet dsLayerData = new DataSet();
            dsLayerData.ReadXml(@"c:\LayerDefinitions.xml");
            DataView dsLayerDefinition = new DataView(dsLayerData.Tables["Layer"]);
            dsLayerDefinition.Sort = "LayerName";
            int rowIndex = dsLayerDefinition.Find(layerName);
            if (rowIndex == -1)
                // The LayerName was not found in our LayerData
                ed.WriteMessage("\nSpecified layer not found in the file.");
                return;
            ed.WriteMessage("\nLayerName : {0}", dsLayerDefinition[rowIndex]["LayerName"]);
            ed.WriteMessage("\nDesc      : {0}", dsLayerDefinition[rowIndex]["Description"]);
            ed.WriteMessage("\nColor     : {0}", dsLayerDefinition[rowIndex]["Color"]);
            ed.WriteMessage("\nLineType  : {0}", dsLayerDefinition[rowIndex]["LineType"]);
            ed.WriteMessage("\nAlias     : {0}", dsLayerDefinition[rowIndex]["Alias"]);
and the XML file   c:\LayerDefinitions.xml
<?xml version="1.0" encoding="utf-8"?>
<LayerData>
  <Layer>
    <Description>Outlines 0.90mm</Description>
    <LayerName>ST90</LayerName>
    <Color>5</Color>
    <LineType>CONTINUOUS</LineType>
    <Alias>ST90</Alias>
  </Layer>
  <Layer>
    <LayerName>ST70</LayerName>
    <Description>Outlines 0.70mm</Description>
    <Color>3</Color>
    <Alias>ST70</Alias>
  </Layer>
  <Layer>
    <LayerName>ST50</LayerName>
    <Description>Outlines 0.50mm</Description>
    <Color>5</Color>
    <Alias>ST50</Alias>
  </Layer>
  <Layer>
    <LayerName>ST35</LayerName>
    <Description>Outlines 0.35mm</Description>
    <Color>2</Color>
    <Alias>ST35</Alias>
  </Layer>
  <Layer>
    <LayerName>ST25</LayerName>
    <Description>Outlines 0.25mm</Description>
    <Color>1</Color>
    <Alias>ST25</Alias>
  </Layer>
  <Layer>
    <LayerName>ST18</LayerName>
    <Description>Outlines 0.18mm</Description>
    <Color>4</Color>
    <Alias>ST18</Alias>
  </Layer>
</LayerData>
Glenn R
« Reply #51 on: January 17, 2008, 03:40:25 AM »
Nicely done Kerry - DataView's can be very handy.
Cheers,
Glenn.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #52 on: January 17, 2008, 01:13:04 PM »
How about using a DWG file to hold your layer info? Don’t get me wrong, XML is a great idea. I just wanted to see if I could … ^-^
David Hall
« Reply #53 on: January 17, 2008, 01:17:01 PM »
I thought about that, but I was trying to come up with files that nobody would want to edit (read screw up) except me, and a dwg is too easy to open and tweak by some of my wanna-be power users.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #54 on: January 17, 2008, 01:24:13 PM »
.. too easy to open and tweak by some of my wanna-be power users.
Oh God, wanna-be power users, may I recommend a 1024 bit encryption then  :-D
David Hall
« Reply #55 on: January 17, 2008, 01:25:04 PM »
yyyeeesss please!!!
Glenn R
« Reply #56 on: January 17, 2008, 01:31:11 PM »
I use a DWS file myself which has the added bonus of being able to be used for cad standards checking.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #57 on: January 17, 2008, 01:33:07 PM »
Glenn R,  could this have been done with Clone() or DeepClone()?
Glenn R
« Reply #58 on: January 17, 2008, 01:36:44 PM »
Dan,
I would have to look up what I did exactly, but I think I used WblockClone from memory.
Cheers,
Glenn.
SomeCallMeDave
« Reply #59 on: January 17, 2008, 01:55:58 PM »
If you open a file using db.ReadDwgFile like Daniel did,  the file does not have to have a .dwg extension.   I just tested if (briefly, but I did test it)  and it works.
You could 'hide' your dwg so no one would poke at it.
