Author Topic: create Layers, is there a better way  (Read 23046 times)
David Hall
  • Automatic Duh Generator
« on: January 03, 2008, 01:30:00 PM »
What Im looking for is suggestions on how to code this better, or am I doing pretty well.  I went back to some really old code from when C# first started working with acad, and tried to improve what I did back then.  Anyway, comments are welcome
namespace LayerCode
    public class LayerCode
        [CommandMethod("CL1")]
        public void CreateLayer1()
            Database DB = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database;
            using (Transaction tr = DB.TransactionManager.StartTransaction())
                LayerTable LT = (LayerTable)DB.LayerTableId.GetObject(Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite);
                if (LT.Has("DSH"))
                    tr.Abort();
                else
                    LayerTableRecord LTR = new Autodesk.AutoCAD.DatabaseServices.LayerTableRecord();
                    LTR.Name = "DSH";
                    LT.Add(LTR);
                    tr.AddNewlyCreatedDBObject(LTR, true);
                    tr.Commit();
Re: create Layers, is there a better way
« Reply #1 on: January 03, 2008, 01:33:42 PM »
I think it looks good except for one thing.  Tony T. has pointed out that the Has() method will return items that are marked to be erased, meaning that they don't really exist in the drawing, and will be lost when the drawing is closed.  So what he did was use a sub function to search the whole table checking the name and the IsErased (I think) property, and if both were correct, it would return that item.  I will see if I can find the post, as it was posted here.
Edit:  Here you go.
Glenn R
« Reply #2 on: January 03, 2008, 01:40:43 PM »
Here's how I'd do it:
[CommandMethod("CreateDuhLayer")]
static public void createduhlayer()
Document doc = acadApp.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
using (Transaction tr = db.TransactionManager.StartTransaction()) {
LayerTable lt = tr.GetObject(db.LayerTableId, OpenMode.ForRead, false) as LayerTable;
if (lt.Has("Some LayerNameGoesHere"))
return;
LayerTableRecord newLTR = new LayerTableRecord();
newLTR.Name = "SomeLayerNameGoesHere";
// set any other properties
lt.UpgradeOpen();
lt.Add(newLTR);
tr.AddNewlyCreatedDBObject(newLTR, true);
tr.Commit();
Cheers,
Glenn.
David Hall
« Reply #4 on: January 03, 2008, 01:53:40 PM »
Thanks Kerry.  I saw that thread, and I have to admit, you had so much going on, I was lost  :-(
Glenn, In your IF statement, did you forget the {} or are they not needed?  Also, when you opened the Layertable for read, what is the false for?  I'm going to see if I can find that answer, on my own, just curious if you had a quick answer
David Hall
« Reply #5 on: January 03, 2008, 01:55:28 PM »
the LayerTable.UpgradeOpen is b/c you first accessed it ForRead, now you want to ForWrite - correct?
David Hall
« Reply #6 on: January 03, 2008, 01:58:05 PM »
Also, Glenn, the code you posted is being used as a sub, and the return; sends it back to another Sub/Funcion?  If not, im confused on what the return; is doing.  I didn't see you passing a "Name" to this function to check for existence, so I guess i'm just confused
Glenn R
« Reply #7 on: January 03, 2008, 02:00:53 PM »
Duh,
Regarding the IF - you don't need {} if you're only executing one line - more than one and you need the {} (rather like lisp nad it's if statements and progn's)
The 'false' is "don't open erased records". Most code I've seen doesn't use the third argument whereas I always use it (habits from ARX I suppose).
WRT UpGradeOpen, yes you're right. The reason you do this is to minimise the time you have things open for write - other things will want to open for write as well, so always keep it as short as possible.
Dan mentioned something I was going to and what he said happens to ALL the SymbolTables and it occurs using the default indexer as well eg. lt["SomeLayerNameGoesHere"]
Cheers,
Glenn.
Glenn R
« Reply #8 on: January 03, 2008, 02:02:59 PM »
You'll notice the method has been decorated with the CommandMethod attribute, so this is the command definition. The return will just return out of this method/function and hand control back to AutoCAD.
Glenn R
« Reply #9 on: January 03, 2008, 02:05:21 PM »
One other thing: This is C#, so stop thinking of them as Sub's and forget that VB drivel  :evil:  :-D
Curly braces rule  :-D
Glenn R
« Reply #10 on: January 03, 2008, 02:18:46 PM »
BTW, happy birthday as well...get some code books did we ;)
Cheers,
Glenn.
David Hall
« Reply #11 on: January 03, 2008, 02:24:11 PM »
COOL!! I learned something new today!!!  Dont read into this more than what Im saying, but its like an internal ESC key for the function.  Its there so quit the Command(CommandMethod).  VERY nice.  I love .Net
HD
« Reply #12 on: January 03, 2008, 02:25:05 PM »
I am curious about something. By setting the third argument to false, does that negate what Tim stated about the "Has" method will return items that are marked to be erased?
Glenn R
« Reply #13 on: January 03, 2008, 02:27:08 PM »
You're welcome Duh - learning something is always good in my book.
I suppose, thinking about it, that the VB equivalent of return; (a blank return returning nothing) would be Exit Sub...
Cheers,
Glenn.
« Last Edit: January 03, 2008, 02:32:02 PM by Glenn R »
Glenn R
« Reply #14 on: January 03, 2008, 02:31:00 PM »
Nick,
No it won't. To tell the truth, it was pretty superfluous in this case because if the LayerTable ITSELF was erased, your drawing would be cactus.
You would mainly use the construct I showed when, for instance, you were looping over the layertablerecords, which is totally different to just calling the LayerTable.Has() function, which internally does a loop, but will return erased records...it's a nasty little trap which they still haven't fixed.
Cheers,
Glenn.
