Poll
how to updata a AcDbViewport object?
AcDbViewport
3 (75%)
FreezeLayer
1 (25%)
Total Members Voted: 1
Author Topic: how to updata a AcDbViewport object?  (Read 9964 times)
Dream.Fei
« on: December 26, 2007, 11:14:12 AM »
static void Test_x1(void)
// -- Get Layer's ObjectId for Freeze;
AcDbObjectId FrzLay = acdbHostApplicationServices()->workingDatabase()->clayer();
// -- Make to a array for freezeLayer use
AcDbObjectIdArray FrzArray;
FrzArray.removeAll();
FrzArray.append(FrzLay);
// -- get all the viewport's objectId, but not paperSpace.
AcDbObjectIdArray vps;
vps.removeAll(); // -- clear it;
Acad::ErrorStatus es = Acad::eInvalidInput;
es = acdbHostApplicationServices()->workingDatabase()->getViewportArray(vps, false);
if (es != Acad::eOk)
acutPrintf(_T("\nError(getViewportArray): %s"), acadErrorStatusText(es));
return;
if (vps.isEmpty())
acutPrintf(_T("\nError(Viewport's IdArray): none viewport in it."));
return;
for (int i = 0; i < vps.length(); i++)
AcDbViewport *pEnt = NULL;
es = acdbOpenObject((AcDbObject*&)pEnt, vps[i], AcDb::kForWrite);
acutPrintf(_T("\nError(OpenLayout): %s."), acadErrorStatusText(es));
continue; // -- skip current layout.
// -- Freeze Layer in viewPort
es = pEnt->freezeLayersInViewport(FrzArray);
acutPrintf(_T("\nError(FrzInVp): %s"), acadErrorStatusText(es));
pEnt->close();
continue;
/* UpdataDisplay? but it no work. this viewport have no change. */
pEnt->updateDisplay();
pEnt->close();
I have write this code to Freeze Current layer on all viewport. but no work as I think.
the viewport do't updata when the command complete.
but, if I copy a viewport , the layer( what I want to freezed) already Freeze on the copy....
look the Gif:
« Last Edit: December 26, 2007, 11:20:43 AM by Dream.Fei »
Glenn R
  • What idiot child of married cousins wrote this?!
Re: how to updata a AcDbViewport object?
« Reply #1 on: December 26, 2007, 02:40:01 PM »
What is 'LAYOUTREGENCTL' set to?
Also, you might have to record the graphics as modified for the viewport.
Me
Dream.Fei
« Reply #2 on: December 27, 2007, 01:19:47 AM »
I don't understand what's you mean 'LAYOUTREGENCTL' ?
updata the Layout?
about viewport:
I have try the follow code, but it's not work yet.
[color=red]pEnt->recordGraphicsModified();[/color] // -- new code for update
pEnt->close();
[color=red]acedUpdateDisplay(); [/color] // -- call graphic update
« Reply #3 on: December 27, 2007, 01:29:33 AM »
.... I don't understand what's you mean 'LAYOUTREGENCTL' ? ..........
(getvar "LAYOUTREGENCTL") and/or it's equivalent from code.
Controls the display behavior of how a layout acts when switching to it.
0   Each time you switching to a layout tab, a regeneration occurs
1   Model and the last layout tab is cached into memory
2   Initial display of the tab is the only time that a regeneration occurs and any other time that the tab is activated it is read from cache
Saved in Registry; Initial value 2
--> Donate to theSwamp<--
Dream.Fei
« Reply #4 on: December 27, 2007, 01:39:40 AM »
...(getvar "LAYOUTREGENCTL")...
Thank you.
set this var's value to "0" can see the modified.
Have any other way? don't change the sysvar's value?
« Reply #5 on: December 27, 2007, 01:54:57 AM »
perhaps a REGEN  ?
Dream.Fei
« Reply #6 on: December 27, 2007, 02:33:43 AM »
the command "regen" and "regenall" can't updata this layout or viewport.
« Reply #7 on: December 27, 2007, 03:34:59 AM »
Just a guess ..
Have you tried ( in code)
read and save the variable
set the variable to 0
do your mojo
reset the variable to the previously saved value.
sorry I can't be more help.
mjguzik
« Reply #8 on: December 27, 2007, 11:55:53 AM »
Ran into this problem some time ago with limited success updating layer changes in multiple viewports.  Then discovered what I believe is an undocumented function.  Hopefully this helps
// declarations
void __stdcall acedRegenLayers(class AcArray<class AcDbObjectId,class AcArrayMemCopyReallocator<class AcDbObjectId> > const &,int);
void applyLayerChanges();
Acad::ErrorStatus getLayerObjectIdArray();
// Implementation
// Usage applies changes to Layer Table forcing update and regen
void applyLayerChanges(void)
  applyCurDwgLayerTableChanges();
  if ( acdbHostApplicationServices()->workingDatabase()->tilemode() )
     ads_regen(); // Modelspace
  else {
    AcDbObjectIdArray layerIds;
    getLayerObjectIdArray(layerIds);
    acutPrintf(_T("Regenerating layout"));
    acedRegenLayers(layerIds, 0);
  return;
// Usage return AcDbObjectIdArray of pDb LayerTable
Acad::ErrorStatus getLayerObjectIdArray(AcDbObjectIdArray& objIds, bool External, AcDbDatabase* pDb)
if ( pDb == NULL ) pDb =acdbHostApplicationServices()->workingDatabase();
Acad::ErrorStatus es = Acad::eOk;
AcDbLayerTable* pTable = 0;
es = pDb->getSymbolTable(pTable, AcDb::kForRead);
if ( es != Acad::eOk ) return es;
// Interate layers
AcDbLayerTableIterator* pIter = 0;
es = pTable->newIterator(pIter);
if ( es != Acad::eOk ) {
pTable->close();
return es;
for (pIter->start();!pIter->done();pIter->step())
AcDbLayerTableRecord* pRecord = 0;
es = pIter->getRecord(pRecord, AcDb::kForRead);
if( es == Acad::eOk ) {
if ( pRecord->isDependent() ) {
if (External == true)
objIds.append(pRecord->objectId());
else
pRecord->close();
delete pIter;
pIter = 0;
// Close layer table
pTable->close();
pTable = 0;
return es;
Never found any information on the int call of function other than trial and error.
Regards,
MJG
It's Alive!
  • Retired
  • AKA Daniel
« Reply #9 on: December 28, 2007, 11:54:35 AM »
MJG, Thatís a great find, thanks for sharing it!
Retired
Dream.Fei
« Reply #10 on: December 29, 2007, 01:38:01 AM »
Thanks for the help.
Dream.Fei
« Reply #11 on: December 29, 2007, 02:03:14 AM »
I'm use the code in a AcDbDatabaseReactor, when a new LayerRecord append,  I want it freezed on some layout's viewport.
If I save the variable and reset it, that is very busy by the code. (for example, if I insert a Xref object, may be have 10-50 layerRecord, so, if save and reset variable........ :-D)
now, in the Arx init (On_kInitAppMsg()), set the variable to 0:
  struct resbuf rb;
  rb.restype = RTREAL;
  rb.resval.rreal = 0;
  acedSetVar(_T("LAYOUTREGENCTL"), &rb);
the problem is: if this variable set to 0, any Model or Paper switch will call GraphicModify......
MJG's code give me some inspired, Thanks.
Thanks all~
« Reply #12 on: December 29, 2007, 02:14:02 AM »
I don't use CPP but I'm sure some people would appreciate you posting your working revised code from the first post.
Happy that you have an answer.
I didn't recall you saying that earlier  ..
« Last Edit: December 29, 2007, 02:17:07 AM by Kerry Brown »
Dream.Fei
« Reply #13 on: December 29, 2007, 04:01:19 AM »
:-)That's my problem..
The project code have no change, only add "set variable" code on the Arx init.....
Now , I'm try updata viewport without change SYSVAR.
Dream.Fei
« Reply #14 on: December 29, 2007, 04:38:04 AM »
// declarations
:cry:
where this function define?
mjguzik
« Reply #15 on: December 31, 2007, 09:11:28 AM »
Just to close out the intent of the above workaround.  The problem was when manipulating the layer table -- changing frozen and off status. It would not update multiple viewports in paperspace without a REGENALL command.  The above was a workaround without requiring a regen and the litter on the command line.
The function is an EXPORT from the "acad.lib" file in the ARX library.  Both the ads_regen and acedRegenLayers need a declaration in a header file before implementing in a cpp file.
Regards,
MJG
Dream.Fei
« Reply #16 on: January 01, 2008, 01:01:04 AM »
Thank you~ MJG, and happy new year~
Dream.Fei
« Reply #17 on: January 02, 2008, 10:37:31 PM »
This's my project for freeze new layer on layout's viewport.
The layout has limit name with 1 to 5. when a new layerrecord append, freeze it on some layout.
On this project, I used "DocumentReactor" "DatabaseRector" and "LayoutReactor".
DocumentReactor: it's support for the MDI.
DatabaseReactor: when a new layerRecord append. call AcDbDatabaseReactor::objectAppend() method for freeze it.
LayoutReacotr: when rename the layout, updata the FreezeLayer's ID Array on the layout.
on this project, I have use "FeiOhter::ReadFileToArray" to get some layer's define from the text file. beacause I think it's too easy, so I don't post this function.
Thank's all help and I hope some one give me a suggest to optimization this project.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #18 on: January 05, 2008, 07:34:46 AM »
Nice Coding  8-)
Retired
ahlzl
« Reply #19 on: March 10, 2008, 10:33:00 AM »
// declarations
// Implementation
  else {
  return;
// Interate layers
pTable->close();
return es;
else
pRecord->close();
delete pIter;
pIter = 0;
pTable->close();
pTable = 0;
return es;
Regards,
MJG
Study well and make progress every day.
