Author Topic: RootNamespace  (Read 24499 times)
It's Alive!
  • Retired
  • AKA Daniel
Re: RootNamespace
« Reply #45 on: December 31, 2007, 11:59:12 AM »
Except for the failure to use the "using" keyword.  That isn't exactly an error - the "using" keyword is really just a syntactical shortcut - but if the code doesn't use "using", then it should use a try-finally block, and put the Dispose() calls in the Finally block.
OK, so if I understand what your saying, IF you use a "using" statement there is no need for a Try/Catch ?
The “using” statement it for IDisposable Objects. It does not replace try catch
See http://msdn2.microsoft.com/en-us/library/yh598w02.aspx
David Hall
  • Automatic Duh Generator
Re: RootNamespace
« Reply #46 on: December 31, 2007, 12:48:32 PM »
        [CommandMethod("DL2")]
        public void DrawLine2()
            PromptPointOptions PPO = new Autodesk.AutoCAD.EditorInput.PromptPointOptions("\nSelect Point");
            PromptPointResult PPR ;
            Point3d sp;
            Point3d ep = new Point3d(4, 5, 0);
            Database DB = Application.DocumentManager.MdiActiveDocument.Database;
            using (Transaction tr = DB.TransactionManager.StartTransaction())
                try
                    PPR= Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.GetPoint(PPO);
                    if (PPR.Status = Autodesk.AutoCAD.EditorInput.PromptStatus.OK)
                        Line lineEnt = new Line(sp, ep);
                        ((BlockTableRecord)tr.GetObject(SymbolUtilityServices.GetBlockModelSpaceId(DB), OpenMode.ForWrite, false)).AppendEntity(lineEnt);
                        tr.AddNewlyCreatedDBObject(lineEnt, true);
                finally
                    tr.Commit();
I cant seem to make this work.  It is crashing on the if PPR.Status line
« Last Edit: December 31, 2007, 02:00:44 PM by CmdrDuh »
David Hall
Re: RootNamespace
« Reply #47 on: December 31, 2007, 12:49:18 PM »
Im typing out fully qualified names to help myself learn where things are, thus the LOOOONG lines above
David Hall
Re: RootNamespace
« Reply #48 on: December 31, 2007, 12:52:08 PM »
it says
Cannot implicitly convert type 'Autodesk.AutoCAD.EditorInput.PromptStatus' to 'bool'
which I understand, but what I dont get is why is it trying to?  Im just asking if PPR.Status=Autodesk.AutoCAD.EditorInput.PromptStatus.OK  Shouldn't that eval as True or False?
David Hall
Re: RootNamespace
« Reply #49 on: December 31, 2007, 12:55:27 PM »
Nevermind, I just pulled a Duhism!  I needed
if (PPR.Status == Autodesk.AutoCAD.EditorInput.PromptStatus.OK)
Note the ==
It's Alive!
  • Retired
  • AKA Daniel
Re: RootNamespace
« Reply #50 on: December 31, 2007, 12:59:51 PM »
Note the ==
 :laugh:
      PromptPointOptions PPO = new Autodesk.AutoCAD.EditorInput.PromptPointOptions("\nSelect Point");// \n not /n
      PromptPointResult PPR = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.GetPoint(PPO);
      if (PPR.Status == Autodesk.AutoCAD.EditorInput.PromptStatus.OK) //== not =
        Point3d sp = PPR.Value;
          try
            tr.Commit();
          catch (System.Exception ex)
            Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
            ed.WriteMessage(ex.Message);
edited code again
« Last Edit: December 31, 2007, 01:35:10 PM by Daniel »
sinc
Re: RootNamespace
« Reply #51 on: December 31, 2007, 01:07:18 PM »
I'm used to always either committing or aborting a transaction.
I notice in your code, Daniel, you commit the transaction if it succeeds.  But if an exception is thrown, the transaction is neither closed nor aborted.
Is this OK?  Does the implicit Dispose() call (from the "using" statement) automatically abort the transaction?
It's Alive!
  • Retired
  • AKA Daniel
Re: RootNamespace
« Reply #52 on: December 31, 2007, 01:43:03 PM »
I think so, could be wrong about this. But if this transaction it not committed before the transaction object goes out of scope it will be aborted by default.
So if an exception is thrown the transaction will abort, which is probably the best course of action.
David Hall
Re: RootNamespace
« Reply #53 on: December 31, 2007, 02:00:19 PM »
Daniel, I noticed you rearranged my code a little, which is cool.  Question is why? Wouldn't you want
inside the try?  My thinking that if the user hits ESC inside the try, it aborts
BTW, I caught the \n but I guess you posted before I updated my code
David Hall
Re: RootNamespace
« Reply #54 on: December 31, 2007, 02:09:13 PM »
updated code
                try
                        Line lineEnt = new Line(PPR.Value , ep);
                        tr.Commit();
                    else
                        tr.Abort();
It's Alive!
  • Retired
  • AKA Daniel
Re: RootNamespace
« Reply #55 on: December 31, 2007, 02:12:16 PM »
The way I have the code, if the user hits escape the transaction is never opened  I.e.
if (PPR.Status == Autodesk.AutoCAD.EditorInput.PromptStatus.OK)Then run the rest of the code. You could put an else statement and write a nice little message to the user
David Hall
Re: RootNamespace
« Reply #56 on: December 31, 2007, 02:15:39 PM »
Good way to look at it.  Thanks
Bryco
Re: RootNamespace
« Reply #57 on: December 31, 2007, 04:08:32 PM »
I've been using if (PPR.Status != PromptStatus.OK) return;
before the try, it saves those long if statements and indents.
