Author Topic: blocks and attributes  (Read 2044 times)
csgoh
« on: December 22, 2007, 04:13:13 AM »
I am not very familiar with blocks which has attributes and I guess i need some help in the area from the gurus here.
I created a dwg "gridcross.dwg" which has 2 attributes "N" and "S".
I trying to write a lisp program to insert this block but it gives me an error "Automation Error. Key not found"
My code is as follows :-
(defun AGD_Cal ()
  (setq GB:acadobj           (vlax-get-acad-object)
        ;; acad Object
        GB:ActivedocumentObj (vla-get-Activedocument GB:acadobj)
  ;; IAcadDocument Object
        ;; the current dwg
  ;; IAcadModelspace Collection
        GB:mSpace     (vla-get-ModelSpace GB:ActivedocumentObj)
        ;; the modelspace collection
(if (not (tblsearch "block" "GRIDCROSS"))
      (setq blkref (vlax-invoke-method GB:mSpace 'insertblock
                (vlax-3d-point '(0.0 0.0 0.0))
                "C:/GOH-LISP/DWG04-NEW/GRIDCROSS.DWG" 1.0 1.0 1.0 0.0))
      (setq atts (vlax-invoke blkref 'getattributes))
      (foreach att atts
       (if (eq (vla-get-tagstring att) "S")
        (vla-put-textstring att "S")
        (vla-put-textstring att "N")
      );foreach
);IF
);end
Also, how can I rewrite such that when i insert the gridcross blcok, it does not prompt me for the values?
thank you in advance
Fatty
Re: blocks and attributes
« Reply #1 on: December 22, 2007, 04:31:05 AM »
Just replace slashes with double backslashes here,
change this line:
on this one:
"C:\\GOH-LISP\\DWG04-NEW\\GRIDCROSS.DWG"
and it should work
~'J'~
« Reply #2 on: December 22, 2007, 08:57:39 AM »
When you use the command to insert a block with attributes you must address the following system variables.
ATTDIA
Controls whether the -INSERT command uses a dialog box for attribute value entry. See "INSERT Command Line."
0        Issues prompts on the command line
1        Uses a dialog box
ATTMODE
Controls display of attributes.
0        Off: Makes all attributes invisible
1        Normal: Retains current visibility of each attribute: visible attributes are
                displayed; invisible attributes are not
2        On: Makes all attributes visible
ATTREQ
Determines whether the INSERT command uses default attribute settings during insertion of blocks.
0        Assumes the defaults for the values of all attributes
1        Turns on prompts or dialog box for attribute values, as specified by ATTDIA
TEXTEVAL
Controls the method of evaluation of text strings.
0        All responses to prompts for text strings and attribute values are taken literally
1        Text starting with an opening parenthesis [ ( ] or an exclamation mark (!) is
            evaluated as an AutoLISP expression, as for nontextual input
(setq sysattdia (getvar "ATTDIA"))
(setq sysattreq (getvar "ATTREQ"))
(setq systxteva (getvar "TEXTEVAL"))
(setvar "ATTDIA" 0)
(setvar "ATTREQ" 1)
(setvar "TEXTEVAL" 0)
<do your lisp>
(setvar "ATTDIA"   sysattdia)
(setvar "ATTREQ"   sysattreq)
(setvar "TEXTEVAL" systxteva)
« Reply #3 on: December 23, 2007, 04:02:32 PM »
Once you get the InsertBlock method working, which Fatty's suggestion should do, you shouldn't be prompted when adding the block in this method.
csgoh
« Reply #4 on: December 26, 2007, 07:57:39 AM »
thanks guys.
just one more question, i thought that the forward slash (/) is equal to double backslash (\\) in lisp and how come it doesn't work in the first place.
