Author Topic: Regular Expressions  (Read 5434 times)
HD
Regular Expressions
« on: December 21, 2007, 10:12:09 AM »
Hello,
Does anyone know of a regular expression or wildcard technique that could be used in the snippet below? Where, X is: A, B, C, D, E, or E1
BlockTableRecord btr =
     tr.GetObject(bt["BORDER-X"],
     OpenMode.ForRead, false) as BlockTableRecord;
sinc
Re: Regular Expressions
« Reply #1 on: December 21, 2007, 10:15:19 AM »
I don't think you can do that.
I think you need to walk the entire Block table, and compare the name of each block in the table to your regex, keeping a collection of the blocks that match.
Glenn R
« Reply #2 on: December 21, 2007, 10:16:59 AM »
Yep - what sinc said because of AutoCAD's transactional nature (open/close).
It's Alive!
  • Retired
  • AKA Daniel
« Reply #3 on: December 21, 2007, 10:25:41 AM »
What about a selection set? Or maybe you should ignore me  :oops:
sinc
« Reply #4 on: December 21, 2007, 09:12:28 PM »
I don't think there's any way of using a selection set to search a block table.
If you want to use something like Editor.SelectAll(), then a selection filter would work for that.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #5 on: December 21, 2007, 10:37:11 PM »
Yes, that’s what I had in mind. Maybe something like this
     [CommandMethod("test")]
      static public void test()
        Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
        //filter
        TypedValue[] values = new TypedValue[]
                        new TypedValue((short)DxfCode.BlockName, "BORDER-*") ,
        SelectionFilter filter = new SelectionFilter(values);
        PromptSelectionResult result = ed.SelectAll(filter);
        if (result.Status == PromptStatus.OK)
          ObjectId[] idarray = result.Value.GetObjectIds();
          DBObjectCollection dbobjects = new DBObjectCollection();
          AcDb.TransactionManager tm =
          Application.DocumentManager.MdiActiveDocument.Database.TransactionManager;
          Transaction tr = tm.StartTransaction();
          try
            //do something
            foreach (ObjectId id1 in idarray)
              dbobjects.Add(tr.GetObject(id1, OpenMode.ForRead, true));
            tr.Commit();
            ed.WriteMessage(dbobjects.Count.ToString());
          catch (System.Exception ex)
            ed.WriteMessage(ex.Message);
          finally
            tr.Dispose();
Fatty
« Reply #6 on: December 22, 2007, 05:45:10 AM »
Just a thoughts..
Keep in mind the dynamicblocks,
they will be use now very often  ;-)
~'J'~
sinc
« Reply #7 on: December 22, 2007, 09:44:26 AM »
Just a thoughts..
What about them?
sinc
« Reply #8 on: December 22, 2007, 09:46:04 AM »
Just keep in mind that when you use things like Editor.SelectAll(), the selection set is automatically filtered on the current space (modelspace or paperspace).  So it is not necessarily the same thing as searching a block table.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #9 on: December 22, 2007, 10:00:07 AM »
Hi Sinc,
According to the docs, it searches the whole database, as in
acedSSGet("_X",NULL,NULL,NULL,ss) but Maybe I missed somthing.
sinc
« Reply #10 on: December 22, 2007, 10:32:31 AM »
Where did you see that?
All I saw was that it "selects all items from the screen", which implies that it filters on the currently-active space.
It's a simple enough thing to test, though, by writing a little test program.  I actually find myself doing that a lot, because the developer documentation is so sparse in so many areas.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #11 on: December 22, 2007, 10:45:28 AM »
It’s in the Arx (07) docs; specifically, AutoCAD managed class reference.
I do agree the docs are sparse. I have found it very useful to looks at the unmanaged docs just to see if there’s more info.
« Last Edit: December 22, 2007, 11:01:57 AM by Daniel »
Fatty
« Reply #12 on: December 22, 2007, 04:19:37 PM »
Just a thoughts..
What about them?
Here is a part of one of my programm
that is not finished yet
Give this a try
~'J'~
Fatty
« Reply #13 on: December 23, 2007, 02:45:30 PM »
Hello,
You can try this filter for selection:
"BORDER-[A-E],BORDER-[E#]*"
or this one:
"BORDER-[A-E],BORDER-E1"
~'J'~
