Author Topic: How to use "Editor.PointToScreen " ?  (Read 5336 times)
itcad
« on: December 18, 2007, 08:34:14 PM »
Re: How to use "Editor.PointToScreen " ?
« Reply #1 on: December 18, 2007, 10:31:54 PM »
What have you tried ?
itcad
« Reply #2 on: December 19, 2007, 02:22:44 AM »
I want to  put cursor to a point3d.
David Hall
  • Automatic Duh Generator
« Reply #3 on: December 20, 2007, 09:49:14 AM »
POst your code you have tried and we can see whats wrong
itcad
« Reply #4 on: December 20, 2007, 07:55:34 PM »
My code:
  Point3d pt = new Point3d(100, 200, 0);
Autodesk.AutoCAD.ApplicationServices.Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
 Editor ed = doc.Editor;
int viewPortNumber = Convert.ToInt32(Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("cvport").ToString());
Cursor.Position = ed.PointToScreen(pt, viewPortNumber);
Run my code,Position of cursor  is different from the pt(100, 200, 0).
why?
« Reply #5 on: December 21, 2007, 02:04:22 AM »
Is this what you are looking for?
   [CommandMethod("Hola", CommandFlags.Modal)]
    public static void MyCommanderIsMyWife()
      Editor ed = AcAp.Application.DocumentManager.MdiActiveDocument.Editor;
      int viewPortNumber = Convert.ToInt32(AcAp.Application.GetSystemVariable("CVPORT"));
      Point3d ToThePoint = ed.PointToWorld(System.Windows.Forms.Cursor.Position, viewPortNumber);
      ed.WriteMessage(ToThePoint.ToString());
    [CommandMethod("Mola", CommandFlags.Modal)]
    public static void MyCommanderIsMyDaughter()
      System.Drawing.Point ToThePoint = ed.PointToScreen(new Point3d(0, 0, 0), viewPortNumber);
« Last Edit: December 21, 2007, 02:16:39 AM by Daniel »
sinc
« Reply #6 on: December 21, 2007, 08:59:59 PM »
I seem to be getting almost the correct result with the following.  Not exactly right, but close.  It also attempts to put the cursor on the point even if the point is not visible on-screen, which may result in a cursor that is way off the visible screen.
            System.Drawing.Point ptOffset = ed.PointToScreen(pt, viewPortNumber);
            System.Drawing.Point windowLocation = doc.Window.Location;
            Cursor.Position = new System.Drawing.Point(windowLocation.X + ptOffset.X, windowLocation.Y + ptOffset.Y);
