Author Topic: Toggle Xref layers utility ( just give me the fish, I'm hungry )  (Read 2072 times)
« on: December 18, 2007, 01:57:13 PM »
Anyone have a app that will toggle ( freeze/thaw ) the layer(s) for every xref in the dwg? I'm talking about the layer the xref was inserted on, not every layer in the xref itself.
thanks.
David Hall
  • Automatic Duh Generator
Re: Toggle Xref layers utility ( just give me the fish, I'm hungry )
« Reply #1 on: December 18, 2007, 02:04:55 PM »
nope, but i will try to whip something up
« Reply #2 on: December 18, 2007, 02:08:10 PM »
thanks I just don't have time at the moment.
« Reply #3 on: December 18, 2007, 02:51:41 PM »
(defun c:ToggleForMark (/ ActDoc tempLay LayList LayCol LayObj)
(setq ActDoc (vla-get-ActiveDocument (vlax-get-Acad-Object)))
(vlax-for blk (vla-get-Blocks ActDoc)
(if (= (vla-get-IsXref blk) :vlax-true)
(foreach lst (entget (vlax-vla-object->ename blk))
(if (equal (car lst) 331)
(not
(vl-position
(setq tempLay (cdr (assoc 8 (entget (cdr lst)))))
LayList
(setq LayList (cons tempLay LayList))
(setq LayCol (vla-get-Layers ActDoc))
(foreach name LayList
(setq LayObj (vla-Item LayCol name))
(if (equal (vla-get-Freeze LayObj) :vlax-true)
(vla-put-Freeze LayObj :vlax-false)
(vla-put-Freeze LayObj :vlax-true)
« Reply #4 on: December 18, 2007, 03:00:21 PM »
thanks a bunch Tim.
PS I've added a "regen" on the end.
« Reply #5 on: December 18, 2007, 03:02:05 PM »
thanks a bunch Tim.
You're welcome.
