Can anyone tell me why this isn't working? I'm inserting a block (sc1) that has an attribute and I'm using "pause" so the user can enterinformation for that attribute. For some reason the "pause" isn't being recognised. Interestingly, some of my other routines which use "pause" aren't working also. Could it be 2005 or maybe I'm missing a subroutine? Here's the code:
(defun c:scut(/ osn la dms pt1 pt2 tang angl )
(setq osn (getvar "osmode"))
(setq la (getvar "clayer"))
(setvar "osmode" 0)
(command "-layer" "s" "s-anno-bold" "")
(command "-units" "2" "2" "1" "2" "" "")
(setq dms (getvar "dimscale"))
(setq pt1 (getpoint "\nLocate secion cut: "))
(setq pt2 (getpoint "\nLocate end of section cut: " pt1))
(setq tang (angle pt1 pt2))
(setq angl (angtoc tang))
(command "pline" pt1 pt2 "")
(command "insert" "sc1" PT1 DMS "" angl pause)
(setvar "osmode" osn)
(setvar "clayer" la)
(command "-units" "4" "16" "" "" "" "")
Any help is appreciated, this has been driving me crazy all day.
