Author Topic: Getting a variable in VBA from ACAD  (Read 19714 times)
ML
Re: Getting a variable in VBA from ACAD
« Reply #15 on: December 17, 2007, 10:25:27 AM »
Hi Some!
Is this a function that will work without That VLAX Class module?
ML
« Reply #16 on: December 17, 2007, 10:30:41 AM »
CM,
To answer your question;
The post started like this
This should also work.
(setq USERS1 (getfiled "Select Image File" (getvar "dwgprefix") "tif" 8))
Imgname = ThisDrawing.GetVariable("USERS1")
Instead of having to use The really long FileOpenDialog in ACAD - VBA just to browse (using Windows) and grab a lousy file; I thought that I would just use the getfiled method in LISP instead. That is when this problem occurred. With LISP, I can set my variable in CAD; however, that variable will not carry over to VBA; hence this.
God, in Excel, THe FileOpenDialog is built into VBA and it is like 4 lines.
ML
« Reply #17 on: December 17, 2007, 10:33:36 AM »
Does anyone think that they could get this method working, without VLAX? I think it is much cleaner.
I have done some research on The Net and it does look like we can effectively set a reference to The VLISP object, the question is, how do we use the VLISP methods in VBA?
Sub VBAToLisp()
Dim VL As Object
Dim strText As String
Set VL = CreateObject("VL.Application.16")
strText = "Hello!"
VL.SetLispSymbol "Test", strText
Debug.Print strText
End Sub
SomeCallMeDave
« Reply #18 on: December 17, 2007, 11:23:59 AM »
Hi Some!
Mark,
Yes, it will work without the VLAX class, but will require a reference to be set to the visual LISP activeX module
ML
« Reply #19 on: December 17, 2007, 12:40:07 PM »
Hey Some
So, the code (setting the reference) that I posted just above you last post; along with your function should work together?
ML
« Reply #20 on: December 17, 2007, 12:41:53 PM »
This is really ugly and I am not sure that I would use this approach but can anyone tell me how to get this
(setq imgname (getfiled "Select Image File" (getvar "dwgprefix") "tif" 8))
To The ACAD Command Line?
Thisdrawing.SendCommand  (setq imgname (getfiled "Select Image File" (getvar "dwgprefix") "tif" 8))
Fatty
« Reply #21 on: December 17, 2007, 04:29:53 PM »
Try this one
Sub Try()
Dim fname As String
ThisDrawing.SetVariable "USERS1", ""
     ThisDrawing.SendCommand "(setvar " & Chr(34) & "USERS1" & Chr(34) & _
                             " (setq imgname (getfiled " & Chr(34) & _
                             "Select Image File " & Chr(34) & Chr(34) & _
                             "C:\\ " & Chr(34) & Chr(32) & Chr(34) & "jpg" & Chr(34) & " 16)))" & vbCr
     If ThisDrawing.GetVariable("USERS1") <> vbNullString Then
     [color=red]fname[/color] = ThisDrawing.GetVariable("USERS1")
     MsgBox "You choosen: " & vbCr & fname
     End If
End Sub
~'J'~
Glenn R
« Reply #22 on: December 17, 2007, 06:12:11 PM »
ML,
I was going to comment, but I won't bother - you're obviously not learning.
« Reply #23 on: December 17, 2007, 07:35:07 PM »
If Matt would've typed what he meant :-) , you may not have needed to go this far.....
(setvar "USERS1" (getfiled "Select Image File" (getvar "dwgprefix") "tif" 8))
I should add, however, that I concur with what Michael, Glenn, & David have all tried to say.....stick with a VBA solution.
« Last Edit: December 17, 2007, 07:46:52 PM by Jeff_M »
« Reply #24 on: December 17, 2007, 07:55:22 PM »
Another thought, Mark, since you seem to know how to get this in Excel, why not link to Excel's ActiveX and use it's FIleDialog?
Glenn R
« Reply #25 on: December 17, 2007, 08:05:16 PM »
You're asking for trouble there Jeff  :wink:
ML
« Reply #26 on: December 17, 2007, 08:18:28 PM »
Hey Guys,
I think I got it!
Please try it out; it seems to be working very well for me.
Here are 2 short examples and the nec. functions
With this, you should be able to assign (LISP) variables to ACAD from VBA and vice versa.
Dim VL As Object
Sub Lisp2VBA()
 A = GetLispSym("M") 'In ACAD, at the command line, set your variable ie (setq M "Test")
 Debug.Print "Variable = " & A
'MsgBox A
End Sub
Sub VBA2Lisp()
'Dim Value As Double
 Dim Value As String
 Value = "Test" '(120#)
 PutLispSym "B", Value 'In ACAD, type !B. The variable (B) should return Test
End Sub
Function GetLispSym(symbolName As String) As Variant
 Dim sym As Object
 Set sym = VL.ActiveDocument.Functions.Item("read").funcall(symbolName)
 GetLispSym = VL.ActiveDocument.Functions.Item("eval").funcall(sym)
End Function
Function PutLispSym(symbolName As String, Value As Variant)
 Dim sym As Object
 VL.ActiveDocument.Functions.Item("set").funcall sym, Value
End Function
ML
« Reply #27 on: December 18, 2007, 11:07:35 AM »
Hey Glenn,
I saw your comment but I chose to ignore it. I don't have time for that kind of negativity. Sorry!
ML
« Reply #28 on: December 18, 2007, 11:25:29 AM »
Anyhow, back to better things:
I was finally able to acheive what I had set out to do:
I have a menu macro in ACAD
This mixes up VBA and LISP a bit
So, with The VBA Expression, I set PaperSpace as current, then with the getfiled method in LISP, I set my variable imgname to the name of the tif file; then run my Sub in VBA.
^c^cvbastmt;ThisDrawing.ActiveSpace = acPaperSpace;(setq imgname (getfiled "Select Image File" (getvar "dwgprefix") "tif" 8));^c^c-vbarun;"K:/Type/in your path/Projectname.dvb!Module.Macro";
Then, this is an abbreviated version of my Sub:
Sub Name ()
Dim RastImg As AcadRasterImage
Dim Imgpth As String
Dim Imgname As String
Dim InsertPnt(0 To 2) As Double, scalefactor As Double, RotAngle As Double
Imgpth = ThisDrawing.Path & "\"
Imgname = GetLispSym("Imgname") 'Here, calling the below (GetLispSym) function, I am retreiving the variable (filename) from ACAD and successfully assigning it to the Set RastImg line and so on and so on.
InsertPnt(0) = -8#: InsertPnt(1) = 0#: InsertPnt(2) = 0#
scalefactor = 1
RotAngle = 0
On Error GoTo Errorhandler
Set RastImg = ThisDrawing.PaperSpace.AddRaster(Imgpth & Imgname, InsertPnt, scalefactor, RotAngle)
  Dim VL As Object
  Dim sym As Object
End Function
ML
« Reply #29 on: December 18, 2007, 11:33:29 AM »
SomeCall
I pretty much did the same as you :)
I kind of muffled through The VLAX Class as well, saw your function and an old post that helped me to narrow it down to pretty much just want I need. Trust me, I do not know VLISP at all and very little LISP.
I do like that you test for the version and that is a good idea to Set the objects to nothing at the end.
Thanks for the help!
