I use '06, but I have '08, so I can test it. Thanks for the offer Michael. Looking at the stuff now. Seems really weird, as the dictionary with the most items is called "Ks_GroupDataDictionary", but there are no groups within the drawing, but I just started looking into stuff.
That is not really surprising, to me.
Kiwi uses AutoCAD groups, but then adds its own data, as you've seen.
So, it maintains its own data dictionary, which evidently doesn't get purged (at least, in this case).
"Zombie" is the original (now obsolete) name for "Proxy" entities, which suggests to me that the original drawing from which this was derived goes back aways, like ACAD 2000.
The fact that the dwg contains only piping & no structural is no real surprise either.
Kiwisoft (ProSteel) has been the structural component of Autoplant for about the same time frame.
So, I surmise the bloated drawing has been through many "reincarnations" as a "blank" drawing, with file size growing every time, due to the unpurged dictionary detritus.
Ever get a hugely bloated file from someone using ACAD LT, only to find there are thousands (or even tens of thousands) of empty GROUPS in the dwg?
This looks to me like an analogous situation with different (3rd party) dictionaries.
This junk is definitely Kiwisoft, as Michael pointed out.
Speaking from memory - I haven't used PS in awhile, & don't have it currently installed - I believe there _may_ be a software setting to do a proper cleanup upon exit, but it has to be set (IIRC). So, if someone didn't do that, it would lead to the accumulation of trash which you describe.
