Author Topic: where is closed filled arrow?  (Read 2723 times)
Notsober
« on: December 12, 2007, 09:39:11 AM »
It's gone!
I had this problem once before, and it's back and I can't remember for the life of me how to fix it again! The answer was posted in the Autodesk Discussion forum, but their server is down right now.
Could someone help? It happens when I simply change the arrow type for a leader line. Then when I go to change it back to closed filled arrow, it stays on the previous arrow type. I can change to anything else BUT a closed filled.
Why does it do this in the first place?
Re: where is closed filled arrow?
« Reply #1 on: December 12, 2007, 09:53:56 AM »
Notsober
« Reply #2 on: December 12, 2007, 10:10:20 AM »
This didn't help?
http://www.theswamp.org/index.php?topic=19720.msg240343#msg240343
now how the heck did you find that and I couldn't?
I always do a search before posting a new topic! I thought I posted that in Autodesk forum...
And I guess, no it didn't permanently fix the problem, cuz I forgot to actually add it to my startup suite... silly me!
thanks for the help!
« Reply #3 on: December 12, 2007, 10:30:49 AM »
You're welcome.
I remembered it was LE who gave the help so I searched on leader posted by LE.  :-)
Guest
« Reply #4 on: December 12, 2007, 02:30:34 PM »
You're welcome.
I thought that post was deleted?   :wink:
Speaking of LE, has he moved on?  Again??
Josh Nieman
« Reply #5 on: December 12, 2007, 02:43:44 PM »
You're welcome.
 :-D
http://www.theswamp.org/index.php?topic=20177.0
