Author Topic: EntMake'ing fields (need help)  (Read 9875 times)
« on: December 10, 2007, 01:48:33 PM »
I thought it might be fun, and a good learning experience, to figure out how to create a field though lisp.  I was not able to figure it out using ActiveX, so I went the Lisp route with dxf codes.  It seems to want to create it, but it will freeze Acad.  I have not use entmake with dictionaries, so I'm looking for any advice.  Here is the code.
Thanks in advance.
(setq ActDoc (vla-get-ActiveDocument (vlax-get-Acad-Object)))
(setq ActLo (vla-get-ActiveLayout ActDoc))
(and
(setq Sel (nentsel "\n Select object to change field value: "))
(setq EntData (entget (car Sel)))
(vl-position (value 0 EntData) '("MTEXT" "ATTRIB" "ATTDEF"))
(setq ExDict
(vlax-vla-object->ename
(vla-GetExtensionDictionary
(vlax-ename->vla-object (car Sel))
(setq FDict
(if (setq FDictData (dictsearch ExDict "ACAD_FIELD"))
(value -1 FDict)
(dictadd ExDict "ACAD_FIELD"
(entmakex
(0 . "DICTIONARY")
(100 . "AcDbDictionary")
(280 . 1)
(281 . 1)
(setq FEnt
(if (setq FEnt (dictsearch FDict "TEXT"))
(value -1 FEnt)
(dictadd FDict "TEXT"
(entmakex
(list
'(0 . "FIELD")
'(100 . "AcDbField")
'(1 . "_text")
'(2 . "%<\\_FldIdx 0>%")
'(90 . 1) ;Number of child fields
(cons 360 ;Child field ID
(entmakex
(list
'(0 . "FIELD")
'(1 . "AcObjProp")
'(2 . "\\AcObjProp Object(%<\\_ObjIdx 0>%).Name")
'(90 . 0)
'(97 . 1)
(cons 331 (vlax-vla-object->ename ActLo))
'(4 . "")
'(91 . 63)
'(92 . 0)
'(94 . 59)
'(95 . 2)
'(96 . 0)
'(300 . "")
'(6 . "ObjectPropertyName")
'(90 . 4)
'(1 . "Name")
'(7 . "ACAD_FIELD_VALUE")
'(90 . 4)
(cons 1 (vla-get-Name ActLo))
(cons 301 (vla-get-Name ActLo))
'(98 . 7)
'(97 . 0) ; Number of object IDs used in the field code
'(4 . "") ; Format string
'(91 . 63) ; Evaluation option
'(92 . 0) ;Filling option
'(94 . 5) ;Field state flag
'(95 . 1) ;Evaluation status
'(96 . 0) ;Evaluation error code
'(300 . "") ;Evaluation error message
'(93 . 1) ;Number of the data set in the field
'(6 . "ACFD_FIELDTEXT_CHECKSUM") ;Key string for field data
'(90 . 2) ;Data type of field value
'(7 . "ACFD_FIELD_VALUE") ;Key string from the evaluated cache, hard coded as is shown here
'(90 . 0) ;Data type of field value
'(91 . 0) ;Long value
'(301 . "")
'(98 . 0)
Re: EntMake'ing fields (need help)
« Reply #1 on: December 10, 2007, 03:59:12 PM »
This is working.  I took out some code that i felt didn't need to be there, and I looked in the ObjectArx docs to find out what some of the codes meant.  Now to make it better   :evil:  as it will only work on objects that don't have a field associated with it.
(and
(setq ExDict
(setq FDict
(value -1 FDict)
(entmakex
(0 . "DICTIONARY")
(280 . 1)
(281 . 1)
(setq FEnt
(value -1 FEnt)
(entmakex
(list
'(0 . "FIELD")
'(1 . "_text")
(entmakex
(list
'(0 . "FIELD")
'(1 . "AcObjProp") ; Field type
'(90 . 0) ; Number of child fields
'(97 . 1) ; Number of object ids
(cons 331 (vlax-vla-object->ename ActLo)) ; Object id
'(4 . "") ; format string
'(91 . 63) ; evaluation option
'(92 . 0) ; filling option
;'(94 . 59) ; field state flag
;'(95 . 2) ; evaluation status
;'(96 . 0) ; evaluation error code
;'(300 . "") ; evaluation error message
'(6 . "ObjectPropertyName") ; key string for the field data
'(90 . 4) ; data type of field
'(1 . "Name") ; name of property
'(7 . "ACAD_FIELD_VALUE") ; key string for the evaluated cache
(cons 1 (vla-get-Name ActLo)) ; field value
'(301 . "") ; format string
'(98 . 0) ; length of format string
;kDisable 0 Disable evaluation.
;kOnOpen (0x1 << 0) Evaluate during drawing load.
;kOnSave (0x1 << 1) Evaluate during drawing save.
;kOnPlot (0x1 << 2) Evaluate during drawing plot.
;kOnEtransmit (0x1 << 3) Evaluate during eTransmit.
;kOnRegen (0x1 << 4) Evaluate during regen.
;kOnDemand (0x1 << 5) Evaluate only on demand by the user or the API.
;kAutomatic (kOnOpen | kOnSave | kOnPlot | kOnEtransmit | kOnRegen | kOnDemand) Automatically evaluate fields during all the operations.
;kSkipFilingResult (0x1 << 0) Do not file out the cached evaluation result with the field.
;'(94 . 5) ;Field state flag
;kInitialized (0x1 << 0) Field is not yet intitalized with any field code or data.
;kCompiled (0x1 << 1) Field has been compiled.
;kModified (0x1 << 2) Field has been modified and not yet evaluated.
;kEvaluated (0x1 << 3) Field has been evaluated. Use evaluationStatus() to get the evaluation status.
;kHasCache (0x1 << 4) The field has a cache of the evaluated result.
;'(95 . 1) ;Evaluation status
;kNotYetEvaluated (0x1 << 0) Field is not yet evaluated.
;kSuccess (0x1 << 1) Field is evaluated successfully.
;kEvaluatorNotFound (0x1 << 2) Evaluator was not found.
;kSyntaxError (0x1 << 3) Syntax error in the field expression.
;kInvalidCode (0x1 << 4) Invalid field code or expression.
;kInvalidContext (0x1 << 5) Current context is invalid for evaluating the field.
;kOtherError (0x1 << 6) Evaluation has failed.
;'(96 . 0) ;Evaluation error code
;'(300 . "") ;Evaluation error message
'(140 . 33.0) ;Double value
'(98 . 0) ; format string length
« Reply #2 on: December 10, 2007, 06:06:43 PM »
Here is something I'm happy with right now.  It is a sub that will add a field to an item that has an existing field or not.  It will let you add any property that will return a string.  I'm pretty sure it will link to any object that can be converted to an ename.  Like a document won't work since you can't convert it to an ename, but a layout can be converted, so you can link to it.
Hope you like.  Any comments/ideas welcomed.
(defun AddObjectField (AddToEname LinkObj PropName / EntData ExDict FDict)
(and
(setq EntData (entget AddToEname))
(setq ExDict
(vlax-ename->vla-object AddToEname)
(dictremove ExDict "ACAD_FIELD")
(setq FDict
(entmakex
(0 . "DICTIONARY")
(280 . 1)
(281 . 1)
(entmakex
(list
'(0 . "FIELD")
'(1 . "_text")
(entmakex
(list
'(0 . "FIELD")
(cons
2
(strcat
"\\AcObjProp Object(%<\\_ObjIdx 0>%)."
PropName
(cons 331 (vlax-vla-object->ename LinkObj)) ; Object id
(cons 1 (vlax-get LinkObj PropName)) ; field value
(entupd AddToEname)
« Reply #3 on: December 10, 2007, 08:20:18 PM »
This looks like a great thread T.Willey. Let me see if i cant give this some thought in the morn.
« Reply #4 on: December 11, 2007, 11:18:36 AM »
Thanks Se7en.  I will continue to see what else I can learn with this.  I want to be able to link any property, which means I have to study what is different between the types (list, integer, real ....).
« Reply #5 on: December 11, 2007, 11:47:17 AM »
No problem; I'll help as much as i can.
First look:
I dont have a `value' function so i cant run this.
« Reply #6 on: December 11, 2007, 11:52:43 AM »
First look:
Dang!  Thought I didn't use one of the subs.  Guess I wasn't sure if I was going to post the code.  :wink:
Here you go.
(defun VALUE (num ent /)
(cdr (assoc num ent))
« Reply #7 on: December 11, 2007, 02:17:14 PM »
Here is the next version.  It will now support Integers, Reals, Lists and Strings.  It looks like fields can support more items, but I don't know which properties to test for them.  No formatting though, but I think that isn't too hard from what I see, but you will have to know what is allowed.  You will need the code above, that I forgot to post first.  I will highlight where the changes are in the code.
(defun AddObjectField (AddToEname LinkObj PropName / EntData ExDict FDict PropType PropValue)
(and
(setq ExDict
(setq PropType
(type
(setq PropValue
(setq FDict
(entmakex
(0 . "DICTIONARY")
(280 . 1)
(281 . 1)
(entmakex
(list
'(0 . "FIELD")
'(1 . "_text")
(entmakex
(list
'(0 . "FIELD")
(cons
2
(strcat
PropName
'(6 . "ObjectPropertyId")
'(90 . 64)
(cons 330 (vlax-vla-object->ename LinkObj))
(cons 1 PropName) ; name of property
[color=red](cons
90 ;data type of field
((equal PropType 'STR)
4
((equal PropType 'INT)
1
((equal PropType 'REAL)
2
((equal PropType 'LIST)
32
(cond ; field value
(cons 1 PropValue)
(cons 91 PropValue)
(cons 140 PropValue)
(cons 11 Propvalue)
)[/color]
(entupd AddToEname)
« Reply #8 on: February 09, 2011, 05:55:52 PM »
Here is a new update.  It will allow you to pass a list of objects and properties to create a single field associated with an existing valid text ( based ) entity.  It will separate each value with a space ( can be changed if desired ).
(defun AddObjectField (AddToEname objPropList / EntData ExDict FDict cnt str len )
    ; AddToEname = value ename that the field(s) will be added to.
    ; objPropList = list of lists, that have a valid vla object and property,
    ;   ie: ((#<VLA-OBJECT IAcadText 0ee928cc> . "TextString") (#<VLA-OBJECT IAcadText 0ee92764> . "TextString"))
        (and
            (vl-position (value 0 EntData) '("TEXT" "MTEXT" "ATTRIB" "ATTDEF"))
            (setq ExDict
            (setq cnt -1)
            (setq str "")
            (setq len (length objPropList))
            (setq FDict
                    (entmakex
                            (0 . "DICTIONARY")
                            (280 . 1)
                            (281 . 1)
                (entmakex
                    (append
                        (list
                            '(0 . "FIELD")
                            '(1 . "_text")
                            (cons 2 (repeat len (setq str (strcat str "%<\\_FldIdx " (itoa (setq cnt (1+ cnt))) ">%" (if (equal (1+ cnt) len) "" " ")))))
                            ;'(2 . "%<\\_FldIdx 0>%")
                            (cons 90 (length objPropList)) ;Number of child fields
                        (mapcar
                            (function
                                (lambda ( x / LinkObj PropName PropType PropValue )
                                    (setq LinkObj (car x))
                                    (setq PropName (cdr x))
                                    (setq PropType
                                        (type
                                            (setq PropValue
                                        (entmakex
                                            (list
                                                '(0 . "FIELD")
                                                (cons
                                                    2
                                                    (strcat
                                                        PropName
                                                '(90 . 64)
                                                (cons
                                                            4
                                                            1
                                                            2
                                                            32
                                                (cond ; field value
                                                        (cons 1 PropValue)
                                                        (cons 91 PropValue)
                                                        (cons 11 Propvalue)
                                                '(300 . "") ; format string for '08
                            objPropList
                        (list
            (entupd AddToEname)
Example
    (lambda ( a b )
        (AddObjectField a (list (cons b "ObjectName") (cons b "Layer")))
    (car (nentsel "\n Select entity to assign field to: "))
    (vlax-ename->vla-object (car (nentsel)))
alanjt
  • Standby for witty remark...
« Reply #9 on: February 09, 2011, 09:05:05 PM »
This is incredible Tim!
I can't wait to check it out on Monday - can't believe I never saw this.
Dropbox
