Author Topic: ( acad 2006 vanilla ) dynamic block & hatch  (Read 21324 times)
Re: ( acad 2006 vanilla ) dynamic block & hatch
« Reply #15 on: December 07, 2007, 12:01:12 PM »
Dunno Mark. DB's are not my area of expertise. Seems to work fine on my 'puter.
{shrug} Sorry?
« Reply #16 on: December 07, 2007, 12:19:59 PM »
{shrug} Sorry?
thanks for looking! :-)
quamper
« Reply #17 on: December 07, 2007, 12:41:30 PM »
The hatch isn't part of the selection set for that action.
Your sample shows 5 items in that set.. but it should have 6.
I added the hatch in and it works fine for me now.
I've attached my "fixed" one if that helps.
quamper
« Reply #18 on: December 07, 2007, 12:42:33 PM »
Whoops I should mention I only corrected it for the up>down action not the left>right flip. But the same should apply to that.
daron
« Reply #19 on: December 07, 2007, 01:06:27 PM »
Mark, if you go into the blocks editor and erase the hatch, then redraw and reset parameters, it seems to work.
« Reply #20 on: December 07, 2007, 01:08:37 PM »
I'll try that again.
daron
« Reply #21 on: December 07, 2007, 01:10:05 PM »
Of course, I didn't see this page while posting. However, it appears that you want to only increase the size of the bubble by horizontal constraints. For that, it would be advisable to use a linear as opposed to polar parameter.
quamper
« Reply #22 on: December 07, 2007, 01:11:47 PM »
Take a look at the screen shot.. it's easy to see the hatch isn't part of the selection.. which is why it's not moving with the action.
« Reply #23 on: December 07, 2007, 01:27:46 PM »
that's weird 'cause it is in mine.
daron
« Reply #24 on: December 07, 2007, 01:31:03 PM »
Hmm. It looked like it was part of the selection on mine. On second look, you're right, it's not. I still think that polar parameter should be linear. Why would it work on other drawings? I think I can answer that, actually. Pure guess: An accurately built block is or was in the drawings that it is working on of the same name and when this one is brought in via tool palette, it doesn't redefine the old correct blocks, but gets updated itself. Find the source and fix it.
quamper
« Reply #25 on: December 07, 2007, 01:31:14 PM »
you're looking at your distance parameter.. not the flip action and what's included in it.
daron
« Reply #26 on: December 07, 2007, 01:33:52 PM »
Actually, yellow hatch is difficult to tell whether or not it's selected. What does your props window say? Mark, you're selecting the stretch object. Try selecting the flip objects, which are the offenders.
daron
« Reply #27 on: December 07, 2007, 01:34:49 PM »
Q? You and I are on the same plane with this one. I just seem to be at the back of the plane.
« Reply #28 on: December 07, 2007, 01:37:49 PM »
Now I feel about this tall. :lol:
quamper
« Reply #29 on: December 07, 2007, 01:44:11 PM »
Yeah I agree a linear parameter is probably better, as you have no reason to use a polar one.
Also make sure you set your "dist minimum value" ( in this case I think it's 1.1571) so that it can only "grow" otherwise you get goofy looking results if you stretch it the other direction.
