Author Topic: Enhanced AutoCAD .NET Project Application Wizard  (Read 21626 times)
Dimas1
Re: Enhanced AutoCAD .NET Project Application Wizard
« Reply #15 on: June 06, 2008, 08:23:43 AM »
ok, I'll try doing this with Studio 2005
but how to install this great wizard in 2008?(
csharpbird
« Reply #16 on: June 06, 2008, 10:56:23 AM »
http://www.codeplex.com/dotnetarx/Release/ProjectReleases.aspx?ReleaseId=13734
Dimas1
« Reply #17 on: June 08, 2008, 08:17:11 PM »
great( another link to install packadge. You mean if I download it again it should magically start working?)
Chumplybum
« Reply #18 on: July 22, 2008, 06:51:24 PM »
csharpbird, i've been using your .net template flawlessly for ages now and recently had to reinstall visual studio
anyway, i downloaded that latest version of your .net application wizard (http://www.codeplex.com/dotnetarx/Release/ProjectReleases.aspx?ReleaseId=13734) and i get the following error when starting a new project with the 'AutoCAD Managed VB Application' template...
Error: this template attempted to load an untrusted component 'ArxCS2008,Version=1.0.0.0, Culture=Neutral, PublicKeyToken=18313633467130a4'.
         For more information on this problem and how to enable this template, please see documentation on Customizing Project Templates.
i'm using VB express 2008 (also get the same error in C# express 2008) with AutoCAD 2008
any thoughts?
cheers Mark
A_LOTA_NOTA
« Reply #19 on: September 13, 2008, 11:22:23 AM »
I'm getting this error during install. Anyone know why & how to fix it?
wannabe
« Reply #20 on: December 04, 2008, 02:24:44 PM »
any thoughts?
cheers Mark
Was a solution to this ever ascertained?
gile
  • Marseille, France
« Reply #21 on: December 04, 2008, 03:17:33 PM »
Hi wannabe,
I use C# 2008 Express too but with "Enhanced AutoCAD .NET Project Application Wizard For C#/VB 2008 Express" you can find on this page.
It's not the last version but fine for me (as far as I use it).
It seems that the last version require Visual Studio 2008 'plain version'.
wannabe
« Reply #22 on: December 04, 2008, 03:56:45 PM »
Hi wannabe,
thanks. It says something about a null value in an error message.
Cheers anyway.
« Last Edit: December 04, 2008, 04:23:49 PM by wannabe »
dustinthiesse
« Reply #23 on: February 23, 2009, 03:27:00 PM »
any thoughts?
cheers Mark
I get this exact same error.  Using C# express 2008 and AutoCAD 2008.
vegbruiser
« Reply #24 on: November 23, 2009, 11:06:21 AM »
any thoughts?
cheers Mark
I too am now seeing this error - I think it's something to do with the Express versions of VS 2008 - it works fine in the full version.
Glenn R
« Reply #25 on: November 23, 2009, 04:25:59 PM »
Use the Autodesk one that was released recently.
vegbruiser
« Reply #26 on: November 23, 2009, 05:40:53 PM »
I don't suppose you have a link for it - I think I remember reading about it - just not where.
EDIT: Found it: -
*removed*
:D
EDIT: seems my original link wasn't to the "latest" version - use Kerry's link instead.
« Last Edit: November 23, 2009, 05:53:22 PM by vegbruiser »
vegbruiser
« Reply #28 on: November 23, 2009, 05:53:36 PM »
Thanks Kerry.
EDIT: I apologise if someone else has already posted this (admins please remove this post if so):
Using Kerry's link I found the official AutoCAD .NET Developers Guide which will really come in handy.
« Last Edit: November 23, 2009, 06:01:06 PM by vegbruiser »
mohnston
  • CAD Programmer
« Reply #29 on: November 25, 2009, 02:07:36 PM »
One would think, but sadly it is not handy (or helpful) at all.
CAD Programming Solutions
