Author Topic: Sset Move and make basepoint 0,0  (Read 7007 times)
ML
« on: December 06, 2007, 12:44:23 PM »
Hello,
I have a bit of code that simply allows me to pick (my objects) on screen, then pick a point.
With that:
 I was wondering if anyone has a way or method that I can take the selection set's picked point and move the sset to 0,0
 Also, I would like to make 0,0 the basepoint
Any ideas?
David Hall
  • Automatic Duh Generator
Re: Sset Move and make basepoint 0,0
« Reply #1 on: December 06, 2007, 12:54:11 PM »
Here is a simple sub for moving something
Sub Example_Move()
    ' This example creates a circle and then performs
    ' a move on that circle.
    ' Create the circle
    Dim circleObj As AcadCircle
    Dim center(0 To 2) As Double
    Dim radius As Double
    center(0) = 2#: center(1) = 2#: center(2) = 0#
    radius = 0.5
    Set circleObj = ThisDrawing.ModelSpace.AddCircle(center, radius)
    ZoomAll
    ' Define the points that make up the move vector
    Dim point1(0 To 2) As Double
    Dim point2(0 To 2) As Double
    point1(0) = 0: point1(1) = 0: point1(2) = 0
    point2(0) = 2: point2(1) = 0: point2(2) = 0
    MsgBox "Move the circle 2 units in the X direction.", , "Move Example"
    ' Move the circle
    circleObj.Move point1, point2
    ZoomAll
    MsgBox "Move completed.", , "Move Example"
David Hall
« Reply #2 on: December 06, 2007, 12:56:27 PM »
Post what you have and we can change it.  It seems like your almost there.
dim ZeroZero(2) as Double
ZeroZero(0)=0:ZeroZero(1)=0:ZeroZero(2)=0
For each Obj in SS
obj.move YourPickedPoint, ZeroZero
next obj
deegeecees
« Reply #3 on: December 06, 2007, 12:58:41 PM »
The only way I know to make 0,0 your base point in VBA is this:
ThisDrawing.SendCommand "base" & vbCr "0,0" &vbCr (not tested)
It's crude but effective. Add it to CmdrDuhs' code, and there you go.
ML
« Reply #4 on: December 06, 2007, 12:59:29 PM »
Yes right from the help screen :)
I was already looking at that
I need to move a selection set and there is no method that I know of for doing that
I tried something weird like
Dim Ent as Acadentity
Ent = Sset
Ent.move Pnt1, Pnt2
Because Entities can be moved however that may not be the best method either.
Anymore suggestions?
ML
« Reply #5 on: December 06, 2007, 01:02:45 PM »
Ahhhhhh, I was almost there LOL
Here is your code CM
For each Obj in SS
next obj
I tried using the object.move method but I did not loop through each obj in the sset
Let me go try
Thanks,
David Hall
« Reply #6 on: December 06, 2007, 01:04:19 PM »
what about setvar INSBASE?
ThisDrawing.SetVariable "INSBASE", "0,0,0"
ML
« Reply #7 on: December 06, 2007, 01:06:17 PM »
Hey deegeecees
Sometimes we have to do it! :)
deegeecees
« Reply #8 on: December 06, 2007, 01:06:38 PM »
Yup. That too.
ML
« Reply #9 on: December 06, 2007, 01:06:45 PM »
Yes sir!
CM! You the man!
David Hall
« Reply #10 on: December 06, 2007, 01:09:43 PM »
glad it worked
ML
« Reply #11 on: December 06, 2007, 01:17:12 PM »
The move is working great, thanks guys!
Now I know how to move an sset but still the inbase variable is not setting ?
Here is what I got
Sub MoveSsettoZeroZero()
 On Error Resume Next
 ThisDrawing.SelectionSets.Item("Selection1").Delete
 Dim Sset As AcadSelectionSet
 Dim Obj As AcadObject
 Dim ZeroZero(0 To 2) As Double
 Dim Pnt As Variant
 ZeroZero(0) = 0: ZeroZero(1) = 0: ZeroZero(2) = 0
 Set Sset = ThisDrawing.SelectionSets.Add("Selection1")
 Sset.SelectOnScreen
 Debug.Print "Selection Set " & "("; Sset.Name; ")" & " was created"
 Pnt = ThisDrawing.Utility.GetPoint(, vbCrLf & "Pickpoint")
 Debug.Print "Point = "; Pnt(0) & " , " & Pnt(1)
 For Each Obj In Sset
  Obj.Move Pnt, ZeroZero
 Next Obj
 ThisDrawing.SetVariable "INSBASE", ("0, 0, 0")
ML
« Reply #12 on: December 06, 2007, 01:18:44 PM »
Ooops
Forget the parenthesis
I am not using them and it is still not working?
David Hall
« Reply #13 on: December 06, 2007, 01:25:45 PM »
what happens if you type INSBASE at the command line?
ML
« Reply #14 on: December 06, 2007, 01:30:25 PM »
It returns the base point
However, if you want to set a base point (at least by picking)  in a drawing, you now use base
ML
« Reply #15 on: December 06, 2007, 01:33:43 PM »
As Dec. suggested
This is working fine:
ThisDrawing.SendCommand "base" & vbCr & "0,0" & vbCr
Yes, i would prefer the setvariable method but, it is not big deal to send "A" command to the command line.
David Hall
« Reply #16 on: December 06, 2007, 01:34:45 PM »
It looks like you have to use a variant to set INSBASE
David Hall
« Reply #17 on: December 06, 2007, 01:37:11 PM »
public sub SetInsBase()
Dim sysVarName As String
Dim sysVarData As Variant
Dim DataType As Integer
Dim arrayData3D(0 To 2) As Double
sysVarName = "INSBASE"
arrayData3D(0) = 1#: arrayData3D(1) = 1#: arrayData3D(2) = 0
sysVarData = arrayData3D    ' 3D array data
ThisDrawing.SetVariable sysVarName, sysVarData
end sub
David Hall
« Reply #18 on: December 06, 2007, 01:38:08 PM »
I tested that at 1,1,0 and then 3,1,0 and it worked both times
ML
« Reply #19 on: December 06, 2007, 03:15:54 PM »
WOW!
I understand what is happening there but I think in this case I will stick with
ThisDrawing.SendCommand "base" & vbCr & "0,0,0" & vbCr
Just to keep it a bit cleaner
Good to know for future reference.
Thanks for the help CM!
M
Jeff_M
  • C3D user & customizer
« Reply #20 on: December 06, 2007, 03:21:22 PM »
As CmdrDuh shows, entering the value for INSBASE as a 3dpoint value it works. Why? Well, look at the definition in help:
Type: 3D-point
Saved in: Drawing
Initial value: 0.0000,0.0000,0.0000
Why does entering "0,0,0" work at the command line and not in VBA? Because the command line version does the conversion to a 3d point array for you. When operating with any 3d point in any program language, though, you must be the one to make sure to pass the data in the format it is expected to be.
HTH for any future items of a similar nature....such as when you insert a block using InsertBlock....you wouldn't use "1,1,0" as the insertion point, would you? And just like the initial portion of this thread, you specify a true 2d/3d point to move from/to and not the string version of it.
ML
« Reply #21 on: December 06, 2007, 03:33:39 PM »
Hey Jeff
I totally understand what you are saying.
God, look at the posts we did on Raster Images; plenty of info on that subject.
I really actually learned a real lot from that post.
I was not doubting CM for one sec and I understand why it is done like that; it is just that I needed a quick down and dirty macro for this project that I may or may not use again.
However, I will keep that bit of code around for future use.
ML
« Reply #22 on: December 06, 2007, 03:37:28 PM »
Ok,
I did put that code in and it works great!
Thanks CM - Jeff!
ML
« Reply #23 on: December 06, 2007, 04:02:12 PM »
Actually
Those 8 lines of code can do the same thing with 3 lines.
The critical part was getting the 3 points into the variable.
Dim Basepnt(0 To 2) As Double
Basepnt(0) = 0#: Basepnt(1) = 0#: Basepnt(2) = 0#
ThisDrawing.SetVariable "INSBASE", Basepnt
ML
« Reply #24 on: December 06, 2007, 04:06:59 PM »
Here is the whole thing if anyone is interested:
 ThisDrawing.SelectionSets.Item("Sset1").Delete
 Dim Pnt As Variant
 Set Sset = ThisDrawing.SelectionSets.Add("Sset1")
 Sset.SelectOnScreen
 'Debug.Print "Selection Set " & "("; Sset.Name; ")" & " was created"
 Pnt = ThisDrawing.Utility.GetPoint(, "Pickpoint")
 'Debug.Print "Point = "; Pnt(0) & " , " & Pnt(1)
 Next Obj
Jeff_M
« Reply #25 on: December 06, 2007, 04:18:44 PM »
To shorten it further, when you dimension your variable as a Double, the default value for a Double is 0. SO this could be written as
However, while this CAN be done it is usually preferable to show the true intent, as you have done. Just an FYI.
ML
« Reply #26 on: December 06, 2007, 04:22:46 PM »
Cool
That is good to know, thanks Jeff!
I agree though, it is good to have the true intent incase it needs to be adjusted above 0 later
