Author Topic: Sset Move and make basepoint 0,0  (Read 6968 times)
ML
« on: December 06, 2007, 12:44:23 PM »
Hello,
I have a bit of code that simply allows me to pick (my objects) on screen, then pick a point.
With that:
 I was wondering if anyone has a way or method that I can take the selection set's picked point and move the sset to 0,0
 Also, I would like to make 0,0 the basepoint
Any ideas?
David Hall
  • Automatic Duh Generator
Re: Sset Move and make basepoint 0,0
« Reply #1 on: December 06, 2007, 12:54:11 PM »
Here is a simple sub for moving something
Sub Example_Move()
    ' This example creates a circle and then performs
    ' a move on that circle.
    ' Create the circle
    Dim circleObj As AcadCircle
    Dim center(0 To 2) As Double
    Dim radius As Double
    center(0) = 2#: center(1) = 2#: center(2) = 0#
    radius = 0.5
    Set circleObj = ThisDrawing.ModelSpace.AddCircle(center, radius)
    ZoomAll
    ' Define the points that make up the move vector
    Dim point1(0 To 2) As Double
    Dim point2(0 To 2) As Double
    point1(0) = 0: point1(1) = 0: point1(2) = 0
    point2(0) = 2: point2(1) = 0: point2(2) = 0
    MsgBox "Move the circle 2 units in the X direction.", , "Move Example"
    ' Move the circle
    circleObj.Move point1, point2
    ZoomAll
    MsgBox "Move completed.", , "Move Example"
End Sub
David Hall
« Reply #2 on: December 06, 2007, 12:56:27 PM »
Post what you have and we can change it.  It seems like your almost there.
dim ZeroZero(2) as Double
ZeroZero(0)=0:ZeroZero(1)=0:ZeroZero(2)=0
For each Obj in SS
obj.move YourPickedPoint, ZeroZero
next obj
deegeecees
« Reply #3 on: December 06, 2007, 12:58:41 PM »
The only way I know to make 0,0 your base point in VBA is this:
ThisDrawing.SendCommand "base" & vbCr "0,0" &vbCr (not tested)
It's crude but effective. Add it to CmdrDuhs' code, and there you go.
ML
« Reply #4 on: December 06, 2007, 12:59:29 PM »
Yes right from the help screen :)
I was already looking at that
I need to move a selection set and there is no method that I know of for doing that
I tried something weird like
Dim Ent as Acadentity
Ent = Sset
Ent.move Pnt1, Pnt2
Because Entities can be moved however that may not be the best method either.
Anymore suggestions?
ML
« Reply #5 on: December 06, 2007, 01:02:45 PM »
Ahhhhhh, I was almost there LOL
Here is your code CM
For each Obj in SS
next obj
I tried using the object.move method but I did not loop through each obj in the sset
Let me go try
Thanks,
David Hall
« Reply #6 on: December 06, 2007, 01:04:19 PM »
what about setvar INSBASE?
ThisDrawing.SetVariable "INSBASE", "0,0,0"
ML
« Reply #7 on: December 06, 2007, 01:06:17 PM »
Hey deegeecees
Sometimes we have to do it! :)
deegeecees
« Reply #8 on: December 06, 2007, 01:06:38 PM »
Yup. That too.
ML
« Reply #9 on: December 06, 2007, 01:06:45 PM »
Yes sir!
CM! You the man!
David Hall
« Reply #10 on: December 06, 2007, 01:09:43 PM »
glad it worked
ML
« Reply #11 on: December 06, 2007, 01:17:12 PM »
The move is working great, thanks guys!
Now I know how to move an sset but still the inbase variable is not setting ?
Here is what I got
Sub MoveSsettoZeroZero()
 On Error Resume Next
 ThisDrawing.SelectionSets.Item("Selection1").Delete
 Dim Sset As AcadSelectionSet
 Dim Obj As AcadObject
 Dim ZeroZero(0 To 2) As Double
 Dim Pnt As Variant
 ZeroZero(0) = 0: ZeroZero(1) = 0: ZeroZero(2) = 0
 Set Sset = ThisDrawing.SelectionSets.Add("Selection1")
 Sset.SelectOnScreen
 Debug.Print "Selection Set " & "("; Sset.Name; ")" & " was created"
 Pnt = ThisDrawing.Utility.GetPoint(, vbCrLf & "Pickpoint")
 Debug.Print "Point = "; Pnt(0) & " , " & Pnt(1)
 For Each Obj In Sset
  Obj.Move Pnt, ZeroZero
 Next Obj
 ThisDrawing.SetVariable "INSBASE", ("0, 0, 0")
End Sub
ML
« Reply #12 on: December 06, 2007, 01:18:44 PM »
Ooops
Forget the parenthesis
I am not using them and it is still not working?
David Hall
« Reply #13 on: December 06, 2007, 01:25:45 PM »
what happens if you type INSBASE at the command line?
ML
« Reply #14 on: December 06, 2007, 01:30:25 PM »
It returns the base point
However, if you want to set a base point (at least by picking)  in a drawing, you now use base
