Author Topic: Bind lisp needed  (Read 4192 times)
hudster
Bind lisp needed
« on: August 04, 2004, 06:01:31 AM »
I'm looking for a lisp that will bind all xrefs in a drawing, purge it, audit it and then save it to a desired location.
I can manage the bind purge and audit bit, but it's the save as function i'm falling down on.
Can someone post a piece of code that will allow me to save a drawing with the same name to a specified folder.
Cheers In advance.
Andy
Fuccaro
Bind lisp needed
« Reply #1 on: August 04, 2004, 06:11:41 AM »
I use AutoCAD 2004 and this form is working for me:
(command "saveas" "" "c:\\test.dwg") Sure, you will replace the TEST.DWG with something like
(strcat "c:\\my_folder\\" (getvar "dwgname")) (this is untested)
hudster
Bind lisp needed
« Reply #2 on: August 04, 2004, 06:49:05 AM »
brilliant, thanks very much.
Fuccaro
Bind lisp needed
« Reply #3 on: August 04, 2004, 09:19:45 AM »
:D
burn1050
Re: Bind lisp needed
« Reply #4 on: June 22, 2017, 05:15:04 PM »
did you ever make a lisp or code for this because if you did then that would be brilliant! would you mind sharing it if you did?
ahsattarian
« Reply #5 on: May 27, 2022, 03:58:48 AM »
This might help u  :
  1. (defun c:xrbi () (setvar "bindtype" 0) (command "xref" "bind" "*") (princ))
