Author Topic: dwg file 42MB, but nothing in dwg!  (Read 14638 times)
Re: dwg file 42MB, but nothing in dwg!
« Reply #45 on: December 03, 2007, 03:25:19 PM »
DGC -- Didn't know what to call it, lol.
Robert -- what's the name of that sole block instance and what's in it?
Notsober
« Reply #46 on: December 03, 2007, 03:26:34 PM »
Did you run the AnalyzeThis code snip?
Edit: Would be interesting to see the results generated from the 42MB version, rather than the 13MB version.
here's the report from 42mb file:
Indexing #<VLA-OBJECT IAcadModelSpace 0ebe4f24>
Ordered by object type:
("AcDbArc" 90)
("AcDbBlockReference" 9)
("AcDbBlockTableRecord" 1)
("AcDbCircle" 19)
("AcDbHatch" 1)
("AcDbLine" 416)
("AcDbMText" 12)
("AcDbPolyline" 11)
("AcDbRotatedDimension" 3)
("AcDbSolid" 7)
("AcDbSpline" 6)
("AcDbText" 457211)
Ordered by object count (descending):
("AcDbText" 457211)
("AcDbLine" 416)
("AcDbArc" 90)
("AcDbCircle" 19)
("AcDbMText" 12)
("AcDbPolyline" 11)
("AcDbSolid" 7)
("AcDbSpline" 6)
("AcDbHatch" 1)
Total object count: 457786
Notsober
« Reply #47 on: December 03, 2007, 03:29:49 PM »
probably just an attributed header, i.e. %%U PLAN %%U
or a Preliminary Not For Construction stamp.
craigr
« Reply #48 on: December 03, 2007, 03:30:51 PM »
On a side note....
The lines with zero length thing - I have coworkers that would say 'What's the big deal?' 'As long as you can't see them or print them they are no problem'.
I'm guessing that when cleaning their house, the just shove stuff under the bed, couch, chair, etc....
craigr
Notsober
« Reply #49 on: December 03, 2007, 03:32:45 PM »
On a side note....
craigr
hahaha... I agree.
Alot of these guys here in my office really don't know much about acad. I don't either, but I know a hell of alot more than they do.
« Reply #50 on: December 03, 2007, 03:37:23 PM »
Ummm, if it has nested, upon nested anonymous blocks it could be hiding more obesity.
Honey do begins ... off to get winter tires for wifey's car ... Michael can play no more.
:cry:
Notsober
« Reply #51 on: December 03, 2007, 03:41:38 PM »
:cry:
thanks for all your help thus far!!!
jonesy
  • SuperMod
« Reply #52 on: December 03, 2007, 04:06:21 PM »
something that deletes all "null text"
http://www.theswamp.org/index.php?topic=881.msg11693#msg11693
something that deletes zero length lines
http://www.theswamp.org/index.php?topic=7739.0
(might be worth experimenting on a "copy" of the drawing to see what, if anything, it does)
Rob...
« Reply #53 on: December 03, 2007, 05:40:48 PM »
How about "Ctrl+A" to select all objects? This will even select blank entities. You can then use the properties box to see a list of what they are and how many of them. You can even erase them.
CAD Tech
« Reply #54 on: December 03, 2007, 09:44:55 PM »
You're most welcome - truly my pleasure.
:lol:
Bob Wahr
« Reply #55 on: December 03, 2007, 10:57:19 PM »
Another tip which could help with self-diagnosing is to use quick select.  If it lists an object type, there are some in your drawing.  You can select them even if they are empty, and delete away.
Big G
« Reply #56 on: December 10, 2007, 11:55:11 PM »
bit late in getting on the bus i know....ddptype and change your points from a (virtually invisible dot) to a cross???
I thought i seen the light at the end of the tunnel. But it was just someone with a torch bringing me more work.
"You have to accept that somedays youre the pigeon and  somedays youre the statue"
Notsober
« Reply #57 on: December 11, 2007, 08:36:20 AM »
I want to thank everyone again for all your help.
qtext is what helped solve my problem with 2004, AND simply opening the same dwg with a newer version of acad, i.e. 2007, saving it and then closing it drastically reduced the dwg size!!
craigr
« Reply #58 on: December 11, 2007, 08:38:16 AM »
I too have noticed that saving dwgs to a newer rev decreases the file size.
I wonder how they do that.
craigr
Notsober
« Reply #59 on: December 11, 2007, 09:40:49 AM »
but stupid weird thing is, although we have in our office 2004 and some machines now have 2007, we all have to save our dwg formats as ACAD2000/LT2000 format.
