Author Topic: (GetEnv equivalent in C#  (Read 25420 times)
Re: (GetEnv equivalent in C#
« Reply #30 on: October 17, 2009, 02:43:21 AM »
I've coded this as an exercise in answer to a question elsewhere.
The p/Envoke for GetEnv and SetEnv seemed the easiest way to handle the Variables stored in the  Fixed Profile ->General section of the registry.
.. Other Variables are stored in Profiles->  <<UserProfile>>  -> General
any tips for improvement appreciated.
// (C) CodeHimBelonga kdub @TheSwamp 20091017
using System;
using System.Text;
using System.Runtime.CompilerServices;
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
// This line is not mandatory, but improves loading performances
[assembly: CommandClass(typeof(KDUB_testing.MyTestCommands))]
namespace KDUB_testing
    public class MyTestCommands
        // p/Envoke from Acad.exe
        [System.Security.SuppressUnmanagedCodeSecurity]
        [DllImport("acad.exe",
            CharSet = CharSet.Auto,
            CallingConvention = CallingConvention.Cdecl)]
        private static extern int acedGetEnv(string envName, StringBuilder ReturnValue);
        private static extern int acedSetEnv(string envName, StringBuilder NewValue);
        [CommandMethod("DoIt", CommandFlags.Modal)]
        public void MyGetEnv()
            Editor ed = AcadApp.DocumentManager.MdiActiveDocument.Editor;
            string mainCuiFile = AcadApp.GetSystemVariable("MENUNAME") as string;
            ed.WriteMessage("\nMenuName : {0}", mainCuiFile);
            const int maxResultLength = 1024;
            StringBuilder sbRes = new StringBuilder(maxResultLength);
            acedGetEnv("ACAD", sbRes);
            ed.WriteMessage("\nValue of ACAD environment variable: {0}", sbRes.ToString());
            acedGetEnv("AcetMoveBak", sbRes);
            ed.WriteMessage("\n\nMoveBak Variable: {0}", sbRes.ToString());
            // assume the folder exists for this exercise
            StringBuilder sbResNew = new StringBuilder("c:\\DWG-BAK\\Auto");
            acedSetEnv("AcetMoveBak", sbResNew);
            ed.WriteMessage("\n\nMoveBak Variable is Now : {0}", sbRes.ToString());
« Reply #31 on: October 17, 2009, 11:17:56 AM »
perfect!
« Reply #32 on: October 18, 2009, 10:01:01 PM »
except as Tony T pointed out ... we don't need a StringBuilder for the acedSetEnv ... a String is sufficient.
[ long distance critique appreciated :)
« Reply #33 on: October 19, 2009, 01:30:23 AM »
True, I thought of that too , but then again depends on the usage, example;
if I wanted to append search paths to the environment "ACAD" then Stringbuilder might be more efficient.
« Reply #34 on: October 19, 2009, 01:43:21 AM »
you could always make it overloaded  :-)
namespace ExecMethod
 public static class Commands
  [DllImport("acad.exe", CharSet = CharSet.Auto,
  internal static extern int acedGetEnv(string envName, StringBuilder ReturnValue);
  internal static extern int acedGetEnv(string envName, string ReturnValue);
  [DllImport("acad.exe",CharSet = CharSet.Auto,
  internal static extern int acedSetEnv(string envName, StringBuilder NewValue);
  internal static extern int acedSetEnv(string envName, string NewValue);
  [CommandMethod("doit")]
  static public void doit()
   try
    AcEd.Editor editor =
     AcAp.Application.DocumentManager.MdiActiveDocument.Editor;
    string env = new string(char.MinValue, 1024);
    acedGetEnv("ACAD", env);
    acedSetEnv("ACAD", env);
    editor.WriteMessage("{0}", env);
   catch (System.Exception ex)
      MdiActiveDocument.Editor.WriteMessage
       ("\n{0}\n{1}", ex.Message, ex.StackTrace);
« Last Edit: October 19, 2009, 02:44:45 AM by Daniel »
« Reply #35 on: October 19, 2009, 04:55:21 AM »
You're a sick puppy Fronkensteen  :wink:
