Author Topic: Stationing Lisp  (Read 11441 times)
Scott
Re: Stationing Lisp
« Reply #15 on: November 25, 2007, 05:15:07 PM »
Fatty
You are the man!!!
This works perfect.
Thanks for the help.
Scott
Fatty
Re: Stationing Lisp
« Reply #16 on: November 25, 2007, 05:34:12 PM »
Always happy to help, but I have not have
a time to varnish it
Change to your suit by yourself
Cheers :)
~'J'~
Re: Stationing Lisp
« Reply #17 on: November 25, 2007, 05:44:44 PM »
As usual I'm a bit late to the party. :-( Anyway, here's my offering which allows the beginning station to be any number, which happens often for me when tying to existing designs. I also use the existing STA block, if it exists in the drawing but does not have an attribute for the Station then I add it to the block def.
(defun c:station (/ ANG ATT ATTS BLK BLKREF DERV DOC ENT LINE PAD PARM SPACE STA TMPSTA)
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  (if (not (tblsearch "block" "sta"))
      (setq blk (vlax-invoke (vla-get-blocks doc) 'add '(0.0 0.0 0.0) "sta"))
      (setq line (vlax-invoke blk 'addline '(0.0 31.25 0.0) '(0.0 -31.25 0.0)))
      (vla-put-layer line "0")
      (vla-put-color line acbylayer)
      (setq att (vlax-invoke blk 'addattribute
  15.0
  acAttributeModeNormal
  "Station number?: "
  '(0.0 35.0 0.0)
  "STATION"
  "0+00"))
      (vla-put-layer att "0")
      (vla-put-color att acbylayer)
    (if (and (setq blk (vla-item (vla-get-blocks doc) "sta"))
     (= (vla-get-count blk) 1)
  15.0
  "Station number?: "
  '(0.0 35.0 0.0)
  "STATION"
  "0+00"))
(vla-put-rotation att (* pi 1.5))
(vla-put-alignment att acAlignmentMiddleRight)
(vlax-put att 'TextAlignmentPoint '(0.0 35.0 0.0))
  (while (and (setq ent (car (entsel)))
      (setq sta (getreal "Starting station: "))
    (setq tmpsta (fix (/ sta 100))
  pad (- sta (* tmpsta 100.0))
  space (vla-get-modelspace doc)
    (if (/= pad 0.0)
      (setq tmpsta (1+ tmpsta))
    (while (<= (* tmpsta 100) (vlax-curve-getdistatparam ent (vlax-curve-getendparam ent)))
      (setq parm (vlax-curve-getparamatdist ent (- (* tmpsta 100.0) pad)))
      (setq derv (vlax-curve-getfirstderiv ent parm))
      (if (= (car derv) 0.0)
(setq ang (/ pi 2))
(setq ang (atan (/ (cadr derv) (car derv))))
      (setq blkref (vlax-invoke space 'insertblock (vlax-curve-getpointatparam ent parm) "sta" 1.0 1.0 1.0 ang))
      (setq atts (vlax-invoke blkref 'getattributes))
      (setq att (car atts))
      (vla-put-textstring att (strcat (itoa tmpsta) "+00"))
Fatty
Re: Stationing Lisp
« Reply #18 on: November 25, 2007, 06:07:58 PM »
Huh,
You beat me again
Brilliance one, Jeff
Regards
 :kewl:
~'J'~
