Author Topic: XML_ConsoleApplication_001  (Read 4708 times)
« on: November 19, 2007, 06:53:05 AM »
Had a play tonight ..
DrivePath added:
Save as C:\ProjectStart.XML
<?xml version="1.0" encoding="utf-8" ?>
<ProjectList>
<LastProject>J1002</LastProject>
<Project>
    <ProjectID>1001</ProjectID>
    <ProjectNumber>J1001</ProjectNumber>
    <ProjectName>ALPHA</ProjectName>
    <ClientName>Us and Them</ClientName>
    <JobServer> \\\\Screamer\Drive D\TestProjects</JobServer>
    <JobSubstDrive>W:</JobSubstDrive>
    <JobFolder> \J1001</JobFolder>
    <TSDFolder>\TSD</TSDFolder>
     <StdConsSubstDrive>V:</StdConsSubstDrive>
    <StdConsFolder>\V-Drive\V-Std</StdConsFolder>
</Project>
<Project>
    <ProjectID>1002</ProjectID>
    <ProjectNumber>J1002</ProjectNumber>
    <ProjectName>BRAVO</ProjectName>
    <ClientName>Them and Co.</ClientName>
    <JobFolder> \J1002</JobFolder>
</Project>
<Project>
    <ProjectID>1003</ProjectID>
    <ProjectNumber>J1003</ProjectNumber>
    <ProjectName>CHARLIE</ProjectName>
    <ClientName>Bloggs and Assoc</ClientName>
    <JobFolder> \J1003</JobFolder>
</Project>
</ProjectList>
Then run this ..
Note the projectNumbers are J1001, J1002, J1003 ..
using System;
using System.Text;
using System.Data;
// CodeHimBelonga kwb: 2007/11/19 21:40:04
namespace XML_ConsoleApplication_001
    class Program
        static void Main(string[] args)
            DataSet dsProjects = new DataSet();
            dsProjects.ReadXml(@"c:\ProjectStart.XML");
            DataView dvProject = new
                DataView(dsProjects.Tables["Project"]);
            dvProject.Sort = "ProjectNumber";
            Console.Write("\nEnter Project Number :");
            string input = Console.ReadLine();
            int rowIndex = dvProject.Find(input);
            if (rowIndex == -1)
                // The ProjectNumber was not found in our data
                Console.WriteLine("\nProjectNumber {0} was not found.", input);
                Console.ReadKey();
                return;
            //else proceed
            string ProjectID = dvProject[rowIndex]["ProjectID"].ToString();
            string ProjectNumber = dvProject[rowIndex]["ProjectNumber"].ToString();
            string ProjectName = dvProject[rowIndex]["ProjectName"].ToString();
            string ClientName = dvProject[rowIndex]["ClientName"].ToString();
            string JobServer = dvProject[rowIndex]["JobServer"].ToString();
            string JobSubstDrive = dvProject[rowIndex]["JobSubstDrive"].ToString();
            string JobFolder = dvProject[rowIndex]["JobFolder"].ToString();
            Console.WriteLine("\nProjectID {0}"+
                    "\nProjectNumber : {1}"+
                    "\nProjectName : {2}"+
                    "\nClientName : {3}"+
                    "\nJobServer : {4}"+
                    "\nJobSubstDrive : {5}"+
                    "\nJobFolder : {6}",
                   rowIndex.ToString(),
                   ProjectNumber,
                   ProjectName,
                   ClientName,
                   JobServer,
                   JobSubstDrive,
                   JobFolder
            Console.Write("\nPress any key to proceed.");
            Console.ReadKey();
Note, this is not meant to be in the least indicative of good code .. just posting what i'm learning :-)
.. and the obligatory piccy,
« Last Edit: November 19, 2007, 08:23:12 PM by Kerry Brown »
Re: XML_ConsoleApplication_001
« Reply #1 on: November 19, 2007, 09:32:10 AM »
Cool.
I can learn from this. Thank you Kerry.
David Hall
  • Automatic Duh Generator
« Reply #2 on: November 19, 2007, 10:04:48 AM »
Very cool Kerry!
« Reply #3 on: November 19, 2007, 07:11:55 PM »
John, David ;
yep, this is fun ..
and you're most welcome.
MickD
« Reply #4 on: November 19, 2007, 07:18:02 PM »
That looks easy enough Kerry, very clean example and a very good starting point.
Gotta love text based documents :)
- John Carmack
- J.R.R. Tolkien
« Reply #5 on: November 20, 2007, 01:39:40 AM »
Wheeeee .. in VS2008  Linq in Xml has some potential.
Time to hit the books I think .. :-)
« Reply #6 on: November 20, 2007, 02:00:18 AM »
I'm wetting myself ..
[/too much information]
A piccy is enough !
It's Alive!
  • Retired
  • AKA Daniel
« Reply #7 on: November 20, 2007, 04:09:51 AM »
Well, off to buy cleaning supplies  :lol:
« Reply #8 on: November 20, 2007, 04:33:30 AM »
I'm really going to enjoy this Dan ..
Glenn R
« Reply #9 on: November 20, 2007, 07:28:04 AM »
This looks like something we were discussing not so long ago Kerry...good to see you're making progress with it.
Cheers,
Glenn.
« Reply #10 on: November 20, 2007, 08:16:39 AM »
Cheers,
Glenn.
Hi Glenn,
yep, this is the start of the beast.
Has your body clock adjusted to Greenwich Mean Time yet ?
« Last Edit: November 20, 2007, 08:18:29 AM by Kerry Brown »
joseguia
« Reply #11 on: November 20, 2007, 09:19:48 AM »
WOW, .. no way for me to bookmark this topic so I guess I'll reply so I can find it again later.
Thanks for the SAMPLE
TR
« Reply #12 on: November 20, 2007, 11:17:32 PM »
The beauty of DataSets is their ability to:
1) Hold a collection of DataTables
2) Read and Write XML data.
3) The ability to connect them to a DataGridView
I am in the process of working on a BOM program using all 3 features listed above. The nicest feature is I can write the DataSets XML to an XRecord in the drawing, which then can be loaded every time my BOM program is initiated.
I can provide code if needed when I get back on my windows laptop but unfortunately for most I do all my coding in BOO so SharpDevelop's translator would be needed.
Glenn R
« Reply #13 on: November 22, 2007, 06:29:52 AM »
Yep - all's good Kerry. Will speak to you soon.
Cheers,
Glenn.
