Author Topic: fatal error C1902:  (Read 8459 times)
Re: fatal error C1902:
« Reply #15 on: November 18, 2007, 09:56:00 PM »
I usually do not add global paths to the ARX SDKs. I have mine setup as Owen suggests on his website.
Thanks Daniel ... I was having a look at that this morning .. knowing that you'd been using the System Variables :-)
By any chance did you install VS2008B2 then uninstall VS2008B2?
I do have VS2008B2 installed (express)
C:\Program Files\Microsoft Visual Studio 9\Common7\IDE\mspdb80.dll (File ver 9.0.20706.1)
« Last Edit: November 18, 2007, 10:04:23 PM by Kerry Brown »
--> Donate to theSwamp<--
It's Alive!
  • BricsCAD
  • AKA Daniel
« Reply #16 on: November 18, 2007, 10:42:22 PM »
Just taking shots, I had read uninstalling the beta may affect VS2005.
